Should the entity registry ignore entity_namespace? (I am using entity_namespace to append “plex” & “sonos” to media_players but this was ignored by the entity registry)
Also, in hue I use the setting to allow_hue_groups and although they show as entities in the frontend these groups don’t show up in the registry - wondered if that’s expected behaviour?
Great work as always,
Thanks,
James
Seems like this release broke OpenZWave, according to this issue. I’m seeing the same here, with both Python 3.5 and 3.6.
4 replieshi,
thanks for testing this.
The shown number is the latest trip id. I’ve used this as a “travel book” in the last month and not as a real indicator. If you would like to get the “distance traveled” you could use a template sensor
For the fuel range issue, could you please click here, logon with your mercedesme account and search for fuelRangeKm
Thanks for your feedback and help to make this component better.
BR
Rene
How do use the travel book in general?
Ok, logged on, strange that it’s not reporting the value in the api:
“fuelRangeKm”:"NOT_PRESENT
“fuelRangeKm”:null
Can you make like a formula to calculate based on the latest consumption data if data is ‘not_present’ or ‘null’?
“liquidConsumptionReset”: 7.599999904632568,
“liquidConsumptionStart”: 8.800000190734863,
I’ll add a fix to make sure we can register them taking entity namespace into consideration. For the ones that are already registered you’ll need to update the entity id yourself.
If it doesn’t work for Hue groups, it means that we don’t have a unique ID set for them yet.
Same here. openZwave is broken. Reinstalling the previous version now.
I’m exporting the results out of the states table currently.
Example: select state, attributes, last_changed from states where entity_id = 'sensor.latest_trip' group by state
The idea for the future is:
To the fuelRange problem:
availabilities
and hide unavailable sensorsThx
Rene
no issues with open zwave on a raspbian install coming from 0.61
Hi there,
Thanks for another version, and this one fixed the xiaomi power strip. Great. But I did find something like a breaking changing: I use to write my automations directly by editing files in a automation folder and use to write a file for each xiaomi wireless button that I have. So, I ended with a few automations with the same alias, like “toggle hall light” for the single click of the buttons on each end of the hall. After upgrading to the 0.63 some of these automations just stopped to work!
After a lot of checks of buttons, batteries, etc, I thougth about the entity registry thing and had the idea of adding unique IDs for each automation with the “id:” and it seems to solve the problem (there was one that I had to change the alias too, but I’m not sure… should be another mistake). Should a note be added to the breaking changes?
Unfortunately Cython is not missing. If I remove all “zwave” files from the libs, HA installs them and I don’t see any difference between those used by 0.62.1 and 0.63
Edit:
For some reason, if I do a make update && make build && make install-api
on the python-openzwave checkout (with my venv active) it is working just fine.
My Xiaomi vacuum is not working either. Downgrading back to .60 right now. Same error as others here
TypeError: subcon should be a Construct field
No problems with zwave though.
edit: and after downgrading, it’s back
I also came from 0.62.1, but can’t discover the vacuum now [I also couldn’t on 0.62.1].
I’m assuming that you did not change anything in configuration? just plain update and it works out-of-the-box?
Xiaomi purifier and vacuum both not working here either 0.63
2018-02-11 18:39:28 ERROR (MainThread) [homeassistant.components.vacuum] Error while setting up platform xiaomi_miio
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 84, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/homeassistant/components/vacuum/xiaomi_miio.py", line 90, in async_setup_platform
from miio import Vacuum
File "/usr/lib/python3.6/site-packages/miio/__init__.py", line 2, in <module>
from miio.protocol import Message, Utils
File "/usr/lib/python3.6/site-packages/miio/protocol.py", line 179, in <module>
Const(0x2131, Int16ub),
File "/usr/lib/python3.6/site-packages/construct/core.py", line 1894, in __init__
super(Const, self).__init__(subcon)
File "/usr/lib/python3.6/site-packages/construct/core.py", line 291, in __init__
raise TypeError("subcon should be a Construct field")
Zoneminder not working on 0.63 as docker container
1 replyError while setting up platform zoneminder
File “/usr/src/app/homeassistant/helpers/entity_platform.py”, line 84, in async_setup
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/local/lib/python3.6/asyncio/futures.py”, line 243, in result
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 180, in _step
File “/usr/local/lib/python3.6/asyncio/coroutines.py”, line 212, in coro
File “/usr/src/app/homeassistant/components/camera/zoneminder.py”, line 56, in async_setup_platform
monitors = zoneminder.get_state(‘api/monitors.json’)
File “/usr/src/app/homeassistant/components/zoneminder.py”, line 124, in get_state
return _zm_request(‘get’, api_url)
File “/usr/src/app/homeassistant/components/zoneminder.py”, line 104, in _zm_request
cookies=ZM[‘cookies’], timeout=DEFAULT_TIMEOUT)
KeyError: ‘cookies’
Getting the same zoneminder errors in Ubuntu with python 3.5.
It’s not working for me too. Still the same error.
My custom components are loosing their friendly name (and other attributes) have I missed a breaking change?
Initially came from 0.61, but works fine on 0.62.1
Netatmo weather station not working after 0.63.x update.
Error while setting up platform netatmo
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 84, in async_setup
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/camera/netatmo.py", line 42, in setup_platform
for camera_name in data.get_camera_names():
File "/usr/src/app/homeassistant/components/netatmo.py", line 84, in get_camera_names
self.update()
File "/usr/src/app/homeassistant/util/__init__.py", line 306, in wrapper
result = method(*args, **kwargs)
File "/usr/src/app/homeassistant/components/netatmo.py", line 115, in update
self.camera_data = lnetatmo.CameraData(self.auth, size=100)
File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 78, in __init__
self.default_camera = list(self.cameras[self.default_home].values())[0]
IndexError: list index out of range
1 reply
Unfortunately the xiaomi wifi plugs are still not working since version 61.1:
2018-02-12 23:21:48 WARNING (MainThread) [homeassistant.components.recorder] From version 0.64.0 the ‘recorder’ component will by default purge data older than 10 days. To keep data longer you must configure ‘purge_keep_days’ or ‘purge_interval’.
2018-02-12 23:22:07 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform efergy is taking over 10 seconds.
2018-02-12 23:22:07 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform xiaomi_miio
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 84, in async_setup
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
File “/usr/lib/python3.6/asyncio/tasks.py”, line 180, in _step
File “/usr/lib/python3.6/asyncio/coroutines.py”, line 210, in coro
File “/usr/lib/python3.6/site-packages/homeassistant/components/switch/xiaomi_miio.py”, line 41, in async_setup_platform
from miio import Device, DeviceException
File “/usr/lib/python3.6/site-packages/miio/init.py”, line 2, in
File “/usr/lib/python3.6/site-packages/miio/protocol.py”, line 179, in
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 1894, in init
super(Const, self).init(subcon)
File “/usr/lib/python3.6/site-packages/construct/core.py”, line 291, in init
raise TypeError(“subcon should be a Construct field”)
2018-02-12 23:22:08 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform xiaomi_miio
return fut.result()
So is it safe to check the entity_registry.yaml into GitHub? Is there a security concern here or are these IDs unique to my system?
I did not changed my configuration. I just upgraded from 0.62.1 and it worked.
Limitless led still doesn’t work in 0.63.1
The following fixed the issue with Netatmo. Wasn’t aware needed to remove entities from the new entity_registry.yaml
https://github.com/home-assistant/home-assistant/issues/12355#issuecomment-365375135
Update seems to broke up the aiohttp again.
Tryed the version aiohttp-3.0.1 and aiohttp-2.3.10.
Any ideas?
2018-02-14 11:56:59 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed
File “/usr/local/lib/python3.5/dist-packages/homeassistant/loader.py”, line 142, in get_component
module = importlib.import_module(path)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 958, in _find_and_load_unlocked
File “”, line 673, in _load_unlocked
File “”, line 673, in exec_module
File “”, line 222, in _call_with_frames_removed
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/history.py”, line 20, in
from homeassistant.components.http import HomeAssistantView
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/init.py”, line 15, in
from aiohttp import web
File “/root/.homeassistant/deps/lib/python3.5/site-packages/aiohttp/web.py”, line 15, in
from . import (hdrs, web_exceptions, web_fileresponse, web_middlewares,
File “/root/.homeassistant/deps/lib/python3.5/site-packages/aiohttp/web_middlewares.py”, line 5, in
from aiohttp.web_urldispatcher import SystemRoute
File “/root/.homeassistant/deps/lib/python3.5/site-packages/aiohttp/web_urldispatcher.py”, line 21, in
from yarl import URL, unquote
ImportError: cannot import name ‘unquote’
2018-02-14 11:56:59 ERROR (MainThread) [homeassistant.loader] Unable to find component history
2018-02-14 11:56:59 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Component not found.
2018-02-14 11:56:59 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.frontend. Make sure all dependencies are installed
File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/frontend/init.py”, line 14, in
2018-02-14 11:56:59 ERROR (MainThread) [homeassistant.loader] Unable to find component frontend
Oh…
Beginning with version 0.62 Mirobo/xiaomi-philips don’t work.
[homeassistant.components.vacuum.xiaomi_miio] Got exception while fetching the state: Unable to discover the device 192.168.1.10
[miio.device] error while reading discover results: _decode() takes 3 positional arguments but 4 were given
Since moving to 0.63.2 this morning, I now have an entity_registry.yaml file with my hue lights in it, but none of those lights are now available in the states view (and thus I can’t see or interact with them, breaking my groups, automations etc.) was I suppose to add anything new to configuration to make these visible?
Is the entity registry automatically created by home assistant when one updates to this version?
MQTT, XiaoMi Vacuum and XiaoMi fan not working after upgrading from 63.2 to 63.3. Anybody facing the same issues?
I have downgraded back to 63.2. XiaoMi fan & Vacuum works again, but MQTT is still not working. Later today I’m going to wipe out my virtualenv seutp and reinstall 63.3 fresh and see if that works better.
1 replyStrange… I’m getting a SSL error when connecting to my CloudMQTT instance. HomeAssistant can’t connect, but my android client works. CloudMQTT port isn’t blocked (I can telnet to it).
Error during setup of component mqtt
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/__init__.py", line 399, in async_setup
success = yield from hass.data[DATA_MQTT].async_connect()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/mqtt/__init__.py", line 506, in async_connect
self._mqttc.connect, self.broker, self.port, self.keepalive)
File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py", line 768, in connect
return self.reconnect()
File "/srv/homeassistant/lib/python3.5/site-packages/paho/mqtt/client.py", line 927, in reconnect
sock.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 988, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.5/ssl.py", line 633, in do_handshake
socket.timeout: _ssl.c:629: The handshake operation timed out
Connection lost. Reconnecting…
1 reply
Thanks keithh666…
Wiped my /srv/homeassistant folder, and created a new virtualenv… Installed a fresh copy of 63.3, both MQTT and XiaoMi is working (and so is everything else).
Not too sure what happens when I upgraded from .2 to .3… But thankfully a fresh 63.3 instance fixed it all :).
Hi all!
I am a newbie here and after 0.63.3 update I can`t reach frontend. It gives me 404 error.
I found this from log:
2018-02-22 19:37:21 ERROR (MainThread) [homeassistant.setup] Error during setup of component frontend
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component
File “/usr/lib/python3.6/site-packages/homeassistant/components/frontend/init.py”, line 319, in async_setup
import hass_frontend
ValueError: source code string cannot contain null bytes
I am very thankful if someone could give me a hint what is wrong with this.
2 repliesSeems like something went wrong when the frontend was being downloaded. Remove your <config>/deps
folder.
Reverted to 0.63.2 and the problem is gone.
I also reverted to previous version. I tried to delete deps-folder but it didn`t help.
