Continue Discussion 83 replies
August 2018
dshokouhi Amazing contributor
Just a heads up to zwave users that this release has a PyOZW update so it will take time for that to build in addition to the database migration. Have patience during first boot especially if you are on a pi.
1 reply
August 2018
Hitesh_Singh
I updated to 0.76 and now my configuration says invalid for all the entities, help please !!
August 2018
Jtmoore81
I added the authorization in my config file and now i’m getting the below message every time I refesh the website and the ios app. Is this normal?
config:
# add this part for authorization
auth_providers:
 - type: homeassistant
 # uncomment this to enable backwards compatible API password support
 # - type: legacy_api_password
August 2018 ▶ Hitesh_Singh
Hitesh_Singh
As instructed in the error log maintaining the following in config fixed my problem.
mqtt:
username: USER
password: PASSWORD
August 2018
awarecan
Read the release note
MQTT embedded broker will no longer rely on HTTP API password to automatically configure itself. You need to set own password. (@awarecan - #15929)
1 reply
August 2018
awarecan
Only password need, username is not.
to keep everything in backward compatibility, you can use http.api_password as mqtt.password, e.g.
http:
  api_password: !secret http_password
mqtt:
August 2018 ▶ awarecan
Mariusthvdb
could #15929 be a wrong link?
think you had a paste-error.
this would be the correct one https://github.com/home-assistant/home-assistant/pull/15929
thx!
1 reply
August 2018
J_IO_B
This release doesn’t seem to be playing nice with my MySQL DB will not load history or recorder.
1 reply
August 2018 ▶ Mariusthvdb
awarecan
60 <-> 59, shift one column on keyboard :smile:
August 2018
Notvans
How do webhooks work now with this new authentification system? Will it break ifttt applets?
1 reply
August 2018 ▶ J_IO_B
mspinolo
Can you confirm this? I am on mysql as well and in case I won’t upgrade until solved
Edit: actually on MariaDB10.0.3 but it should be the same
August 2018 ▶ Notvans
awarecan
You need to enable legaci_api_password auth_provider for now. We are working on decouple REST API with HTTP api_password, please check https://github.com/home-assistant/home-assistant/issues/15376 for more details.
August 2018 ▶ mspinolo
VDRainer
I’m on 10.1.30-MariaDB-1~jessie (Docker) and had no issues with the migration.
August 2018
LaStrada
The logger / recorder are not working after upgrading to this version :frowning:
I’m running a MariaDB on another server on my local network.
db_url: mysql://USERNAME:PASSWORD@IP-ADDRESS/hass_db?charset=utf8l
aug. 18 00:52:20 hass hass[24522]: 2018-08-18 00:52:20 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
aug. 18 00:52:21 hass hass[24522]: 2018-08-18 00:52:21 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
aug. 18 00:52:22 hass hass[24522]: 2018-08-18 00:52:22 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
aug. 18 00:52:22 hass hass[24522]: 2018-08-18 00:52:22 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
aug. 18 00:52:22 hass hass[24522]: 2018-08-18 00:52:22 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
aug. 18 00:52:22 hass hass[24522]: 2018-08-18 00:52:22 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
aug. 18 00:52:22 hass hass[24522]: 2018-08-18 00:52:22 INFO (MainThread) [homeassistant.setup] Setting up logger
aug. 18 00:52:25 hass hass[24522]: 2018-08-18 00:52:25 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:25 hass hass[24522]: 2018-08-18 00:52:25 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:25 hass hass[24522]: 2018-08-18 00:52:25 WARNING (MainThread) [homeassistant.components.http] Experimental auth api enabled and legacy_api_password support enabled. Please use access_token instead api_password, although you can still use legacy api_password
aug. 18 00:52:31 hass hass[24522]: 2018-08-18 00:52:31 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:31 hass hass[24522]: 2018-08-18 00:52:31 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:34 hass hass[24522]: 2018-08-18 00:52:34 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
aug. 18 00:52:34 hass hass[24522]: 2018-08-18 00:52:34 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:34 hass hass[24522]: 2018-08-18 00:52:34 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:37 hass hass[24522]: 2018-08-18 00:52:37 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:37 hass hass[24522]: 2018-08-18 00:52:37 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:41 hass hass[24522]: 2018-08-18 00:52:41 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:41 hass hass[24522]: 2018-08-18 00:52:41 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:44 hass hass[24522]: 2018-08-18 00:52:44 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:44 hass hass[24522]: 2018-08-18 00:52:44 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:47 hass hass[24522]: 2018-08-18 00:52:47 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:47 hass hass[24522]: 2018-08-18 00:52:47 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:50 hass hass[24522]: 2018-08-18 00:52:50 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:50 hass hass[24522]: 2018-08-18 00:52:50 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:53 hass hass[24522]: 2018-08-18 00:52:53 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:53 hass hass[24522]: 2018-08-18 00:52:53 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:57 hass hass[24522]: 2018-08-18 00:52:57 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8)
aug. 18 00:52:57 hass hass[24522]: 2018-08-18 00:52:57 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (_mysql_exceptions.OperationalError) (1060, "Duplicate column name 'context_id'") [SQL: 'ALTER TABLE events ADD COLUMN context_id CHARACTER(36)'] (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
aug. 18 00:52:57 hass hass[24522]: 2018-08-18 00:52:57 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Component failed to initialize.
aug. 18 00:52:57 hass hass[24522]: 2018-08-18 00:52:57 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for dependencies: recorder
aug. 18 00:52:57 hass hass[24522]: 2018-08-18 00:52:57 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not setup all dependencies.
aug. 18 00:52:59 hass hass[24522]: 2018-08-18 00:52:59 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history_graph. Setup failed for dependencies: history
aug. 18 00:52:59 hass hass[24522]: 2018-08-18 00:52:59 ERROR (MainThread) [homeassistant.setup] Setup failed for history_graph: Could not setup all dependencies.
aug. 18 00:52:59 hass hass[24522]: 2018-08-18 00:52:59 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for dependencies: recorder
aug. 18 00:52:59 hass hass[24522]: 2018-08-18 00:52:59 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies.
1 reply
August 2018 ▶ LaStrada
awarecan
Your db migration failed for some reason, and the migration process is not protected by transaction, so you either modify the database schema by yourself (see: 0.76 Migration Fails against MSSQL), or delete the database and home-assistant will recreate one for you.
August 2018
gbboy
Upgraded to 0.76 fine using docker homeassistant image and running latest mariadb image. Took about 5-10 minutes to do the database migration.
1 reply
August 2018 ▶ gbboy
kirpat
can you please explain how did you migrate data?
i am using maridadb on venv.
Please guide
thanks in adv.
1 reply
August 2018 ▶ kirpat
just update HA and wait until it is done and your front end loads.
1 reply
August 2018 ▶ dshokouhi
kirpat
frontend will load but i am getting errors with recorder as i am using mysql/mariadb as my database
Please someone guide
thanks in adv.
1 reply
August 2018 ▶ Jtmoore81
Tribune
I am getting the same popup every time I reload the page on my Mac. Even without adding the auth part to my config.
Edit: I am using the lovelace UI
1 reply
August 2018
ktpx
Unable to click any sensors in the web UI after the update, nothing pops up. Also missing stuff from the config sections. It does work in the mobile browser however…not PC. Also getting the save password popup every time (have not added the new auth config).
August 2018
dimagoltsman
nothing works, log is full with syntax errors. wtf
2018-08-18 12:54:27 ERROR (MainThread) [homeassistant.components.notify] Unknown notification service specified
Aug 18 12:54:27 raspberrypi hass[3005]: (standard_in) 1: syntax error
Aug 18 12:54:28 raspberrypi hass[3005]: 2018-08-18 12:54:28 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.mqtt. Setup failed for dependencies: mqtt
Aug 18 12:54:28 raspberrypi hass[3005]: 2018-08-18 12:54:28 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.mqtt: Could not setup all dependencies.
Aug 18 12:54:28 raspberrypi hass[3005]: (standard_in) 1: syntax error
Aug 18 12:54:30 raspberrypi hass[3005]: 2018-08-18 12:54:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
1 reply
August 2018 ▶ dimagoltsman
gbboy
Did you update your configuration? There was a breaking change for the embedded MQTT broker
August 2018
dimagoltsman
yes, all updated
August 2018
ktpx
x.0 releases…never works :wink:
nicke
I have not added anything to configuration.yaml, but I have still the same problem as you.
1 reply
August 2018 ▶ nicke
awarecan
This problem has been fixed. Will be in next update.
1 reply
August 2018
jakelancaster12
Please can someone help me?
I have updated using Hassio however the version still shows as 0.75.2 and i get the following error:
The following components and platforms could not be set up:
hassio
Please check your config.
August 2018
mnl1121
Is it just me or is Rename Node gone from the Zwave control panel?
EDIT: Also the question marks in the zwave control panel are broken too. They don’t display any help text.
EDIT2: Reverting back to 0.75.3 didn’t work either. I know this was just working too. And I’m still getting the save login popup like i didn’t properly revert back to 0.75.3 but the info screen says 0.75.3. Anyone have any ideas?
August 2018
PierreScerri
Updating to 0.76.0 gave this:
IInvalid%20Config
And I’ve lost the ‘History’ tab.
1 reply
August 2018 ▶ PierreScerri
awarecan
Your database migration not success, if nothing important in history, you can just delete the db file. HA will recreate one in next startup.
Or, you have to manual modify your database schema.
1 reply
mspinolo
So do you suggest to wait until 0.76.1 is released before upgrading from 0.75.x?
1 reply
awarecan
Only to avoid annoying SAVE LOGIN popup if you don’t enable new auth
PierreScerri
I reverted to 0.75.3 and now I can’t log on.
My duckdns url says ‘404 file not found’ and https://hassio.local:8123 hangs on ‘loading data’
1 reply
PierreScerri
OK it sorted itself out after I did the update to 0.76.0 from the terminal.
August 2018 ▶ Tribune
mw-white
Same here - seeing a “Do you want to save this login” popup on every page refresh. Doesn’t matter what I click it comes back every time.
And I’m not using embedded mqtt (using mosquitto running on its own).
1 reply
August 2018 ▶ mw-white
awarecan
As I answered in previous comment, this is bug and have been fixed. Please wait next update.
jaymelweston
Confirmed here too, running Maria DB on Synology and no problems then i upgrade to 0.76 and recorder is now broken and any other component using recorder!!! :angry:
2018-08-19 11:58:01 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (_mysql_exceptions.OperationalError) (1296, “Got error 64 ‘Temp file write failure’ from InnoDB”) [SQL: ‘ALTER TABLE events ADD COLUMN context_id CHARACTER(36)’] (Background on this error at: http://sqlalche.me/e/e3q8)
August 2018
aidbish
mine upgraded fine and also using mariadb.
August 2018
Crhass
Anyone having tracker issues with this version?
My ddwrt router trackers are not showing correct status now.
1 reply
August 2018
awarecan
Your problem is lack of temp space.
No, we didn’t tested this scenario.
1 reply
BullFrog
How did you forget about that? People using HA for more than 1 year have 8++ gb of db. I have 20+gb space left on the SD cart yet my DB is corrupted and lost 1 year of data…
August 2018
VDRainer
No one can think about all the possibilities that can happen.
It’s always wise to have a good backup bevor updating.
August 2018
awarecan
There are lots of DB engines people are using, different DB has different way to do schema update. As an open source project, we would not be able to test all possible scenario, especially home-assistant is not a database focus application.
Welcome to join us as beta tester, if you have special setup and want to make sure it works in next release.
August 2018 ▶ BullFrog
awarecan
I just told jaymelweston his problem is lack of temp space. I didn’t saw your error log, didn’t know what happens during your upgrade process.
You can always modify the schema by yourself, I posed in previous comment a link that people are doing manual DB migration, you can look at it.
touliloup
If your DB is only on an SD without backup it was anyway something due to happen… and you can always correct it manually…
August 2018
moskovskiy82
How long could the update take on a RPi
1 reply
August 2018 ▶ moskovskiy82
probably 20-30 minutes in addition to DB migration
August 2018
dvdavide
After updating, the developer tools were not working.
After rebooting the Pi, everything is back to working order.
August 2018
jamesking
I am running hassio (Resin OS) and I have had
Invalid Config.  The following components and platforms could not be set up:
recorder
history
logbook
I understand the conversion of DB might have failed? I don’t think I need my history or anything, so happy to delete database and start again. What do I need to do? Stop Home Assistant - delete home-assistant_v2.db and then restart home assistant?
Thanks,
James
1 reply
August 2018 ▶ jamesking
Yep, that would solve it.
1 reply
August 2018
bakerbug
I’m having issues with the Tuya component. All was working well in 0.75.3 and with 0.76.1 I am getting the following exception:
2018-08-20 13:28:24 ERROR (MainThread) [homeassistant.setup] Error during setup of component tuya
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tuya.py”, line 65, in setup
tuya.init(username, password, country_code, platform)
File “/srv/homeassistant/lib/python3.5/site-packages/tuyapy/tuyaapi.py”, line 44, in init
self.get_access_token()
File “/srv/homeassistant/lib/python3.5/site-packages/tuyapy/tuyaapi.py”, line 68, in get_access_token
raise TuyaAPIException(message)
tuyapy.tuyaapi.TuyaAPIException: Get accesstoken failed. Username or password error!
I have verified that my credentials are valid (they didn’t change since I upgraded). I have also tried adding the new platform option to my tuya config set to both smart_life and tuya. All combinations result in the same exception.
August 2018
Jefe
I’m experiencing one issue with the Auth: component. I activated auth_providers: once I installed v 0.76 on my Hass.io system. All works well, including add-ons, except that doing a Snapshot Download to my iMac fails. I’ve tried it with Safari, Firefox, and Chrome. No file is transferred, and this error is generated:
“Please change to use bearer token access /api/hassio/snapshots/20379af5/download”
Any ideas? Thanks in advance.
1 reply
August 2018 ▶ balloob
jamesking
Thanks, this worked.
R_V
No web interface. I still have access to the file system via configurator on port 3218 after about 20 minutes.
I have a monitor attached.
any suggested command I should run
August 2018 ▶ Jefe
teachingbirds
My system is giving these errors for lot’s of things. Also appdaemon keeps getting ip-banned because of wrong password…
1 reply
August 2018
cxlwill
Finally user system is coming :slight_smile:
August 2018 ▶ teachingbirds
Jefe
My system was getting these errors for several things also prior to v0.76, so I never left Auth activated. Now I’m leaving Auth activated since I only get the error when trying to download the Snapshot file.
Thanks for the reply.
August 2018
ptdalen
Is anyone having issues with Magic Seaweed since updating? I installed it last update, because…why not, and noticed today that it was not working any more. Log gets the following error
Update for sensor.virgia_beach_surf_report_forecast fails
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 199, in async_update_ha_state
    yield from self.async_device_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 322, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/magicseaweed.py", line 148, in update
    self.data.update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 325, in wrapper
    result = method(*args, **kwargs)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/magicseaweed.py", line 195, in _update
    self.currently = forecasts.data[0]
IndexError: list index out of range
August 2018 ▶ Crhass
nikechristo
Same issue for me, ddwrt presence detector does not work anymore. I had to downgrade to 0.76.0 for it to work again.
1 reply
August 2018
evanrich
read the part about mqtt password, but i never used built in:
mqtt:
broker: 192.168.1.20
#port: 1883
protocol: 3.1
client_id: home-asssistant-1
keepalive: 60
username: hass
password: pass
and now with 76.2 i get errors about mqtt
edit: rolled back to 0.75.3, working again.
August 2018 ▶ nikechristo
Crhass
Ddwrt tracking eventually started to show the correct status again on my system after a few days. Don’t think it was due to any minor updates. Maybe it just got lost. Could it be that the database changes altered something?
August 2018
Beach
Hi all,
I use the ios app and since some upgrades I always get this when starting the app:
Login attempt failed
Login attempt or request with invalid authentication from 192.xxx.xxx.xxx
Does anyone know how to solve that?
Thanks in advance
August 2018
masterkenobi
May I know how to change the default username for the embedded MQTT broker?
legoracers
Did you add a password to the intergrated mqtt server, setting a password is required by the last update.
August 2018
ReidarK
Suddenly my SONOS wont work anymore in HA and it cant be found anymore in hass??? Work really well in all version until now. Any idea?
1 reply
August 2018 ▶ ReidarK
dickcollier
I don’t mean to sound flippant but sometimes a hard, I mean pull the power cord hard, reboot solves all kinds of “things that just mysteriously quit working”.
August 2018 ▶ dickcollier
Tinkerer Solution Institution
Doing that on a Pi though runs a real risk of corrupting the SD card.
teachingbirds
Really bad advice. Pulling the cable should only be the very last thing you try after trying everything else and you can’t reboot or shutdown in any other way. Likely to corrupt the sd card if they’re running on one.
1 reply
Mariusthvdb
tbh i had to do that once or twice too… felt really bad, but no other way was possible.
no issues, or so it seems, related to the sd card, luckily.
still, is there a way to check these sd cards for errors, while in the Pi? a check every once in a while cant hurt?
1 reply
teachingbirds
I did it too when there was no other way, but I would never advice someone to.
Fsck can only be done when not mounted I think, and that’s the only way I know of checking.
1 reply
Mariusthvdb
thank you, will adhere to the policy all-is-well-if-nothing-complains then. :wink:
August 2018
mchinery
I have upgraded from 75.3 to 76.2 without any problems. MariaDB add-on upgraded fine and no problems with MQTT running Mosquitto broker add-on. Maybe this upgrade path may help others that have a similar configuration.
August 2018
BTC
Hi there,
Since the update to 0.76, the Velbus component as it is defined on its page doesn’t seem to work anymore.
Downgrade?
1 reply
August 2018 ▶ BTC
nickrout Solution Institution
Did you read the first post, including the “breaking changes”?
August 2018 ▶ nickrout
BTC
Hi Nick!
I did, I read the following:
So, it seems I still need the Velbus component, but the bugger doesn’t seem to be recognized :slight_smile:
BR
August 2018
finity
I’m not sure if this will go very far but…
I haven’t upgraded yet but I’ve heard that some of the z wave config page functionality has been removed with the new release. specifically, the ability to rename nodes.
If anyone who can do something about it is listening, I’m asking to reconsider your decision.
I understand that you want to streamline things but removing functioning operations that lots of people use doesn’t sound right to me.
I’ve been in several threads recently involving this and many people agree with my views that it should be left in.
One thread was talking about the person having 20 z wave devices (fibaro) and each device spawned up to 13 entities. To require them to edit all 260 entities is asinine considering it could be WAY more easily done with working functionality that was just arbitrarily removed.
I personally don’t see the problem leaving it in. No one is saying we have to use the z wave config to change things. If you want to edit your entity_registry file manually then go ahead. It makes sense to leave the other option available for people who want to use that way as well.
1 reply
August 2018 ▶ finity
teachingbirds
Have you also read about the new device registry? I’m guessing this will have similar functionality to what is removed
1 reply
finity
No i haven’t. Where is that information? I skimmed the blog but didn’t see anything about a device registry, just an entity registry GUI.
1 reply
teachingbirds
It’s in the upcoming release for this week! There’s stuff to read about it but I don’t remember where unfortunately. But hang tight until it’s released I say, maybe it’s exactly what you thought you’d miss!
1 reply
finity
Hopefully…
fingers crossed
September 2018 ▶ nickrout
BTC
Hi Nick,
If I read the breaking changes correctly, I still need the Velbus component, followed by using discovery for velbus.
However, the old definition of the velbus component, which worked on 0.6x doesn’t anymore.
So, it seems that I have a problem.
I switched back to 0.6x.
Have you any advice for me?
Ward
September 2018
LarsAC
Is the database migration backwards compatible ? I.e. can I go back to a previous version after the db was migrated ?
Lars
