Continue Discussion 275 replies
December 2024
IoSonoAndreaZ
about the “prefer handling commands locally” setting, I just found a drawback.
This is my test:
This is just an example, but it breaks conversations.
December 2024 ▶ IoSonoAndreaZ
IoSonoAndreaZ
another example:
Turn on kitchen light
(it turns the light on)
What was the last command you did?
(it reports the latest command done using chatgpt, not the one about kitchen light)
December 2024
pops106
Upgraded my test box without any issues, does feel snappier.
December 2024
poudenes
Seems Alexa Mdia Player is broken with this version.
December 2024 ▶ poudenes
demig
Yep broken for me as well. Nothing tremendously useful in the logs that I can see
1 reply
December 2024
parautenbach
You can read all about it in the WTH announcement blog
@frenck this link gives me a 404.
FrancoLoco1234
(1) Beta 2024.12.0b0 breaks amp · Issue #2698 · alandtse/alexa_media_player
Error loading Alexa Media Player integration on the latest HA beta release 2024.12.0b0 which requires aiofiles>=24.1.0 (#33) · Issues · Keaton / alexapy · GitLab
1 reply
NathanCu
Yeahhh this would be completely breaking for me. I assume we can turn it off?
1 reply
December 2024
gavinpbennett
Silly question: After updating, I do not see any way to get to the Scene > Review Mode. Scenes still launch when I try and view the scene. What am I missing?
1 reply
December 2024 ▶ gavinpbennett
mcarty
Did you clear your cache or ctrl-F5?
1 reply
December 2024 ▶ mcarty
gavinpbennett
I did
 Problem solved :man_facepalming:
Thanks.
December 2024
rsonke
The stookwijzer integration is really nice now. Though the website of Atlas leefomgeving also gives a prediction of the next hours. Is that on the roadmap to be made visible (in attrributes or so)? It would be helpful that it remains oke for the rest of the evening for example.
1 reply
December 2024
durd
This update seems to have deleted my configuration.yaml :confused:
Supervisor doesn’t seem to start properly either
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:1176
integration: Recorder (documentation, issues)
First occurred: 21:57:14 (156 occurrences)
Last logged: 22:04:22
Error in database connectivity during commit: Error executing query: (sqlite3.OperationalError) unable to open database file (Background on this error at: https://sqlalche.me/e/20/e3q8). (retrying in 3 seconds)
and
Source: util/loop.py:200
First occurred: 22:00:09 (9 occurrences)
Last logged: 22:04:09
Error doing job: Task exception was never retrieved (None)
  File "src/habluetooth/scanner.py", line 514, in _async_restart_scanner
  File "src/habluetooth/scanner.py", line 526, in habluetooth.scanner.HaScanner._async_restart_scanner
  File "src/habluetooth/scanner.py", line 542, in _async_reset_adapter
  File "/usr/local/lib/python3.12/site-packages/habluetooth/util.py", line 13, in async_reset_adapter
  File "/usr/local/lib/python3.12/site-packages/bluetooth_auto_recovery/__init__.py", line 24, in recover_adapter
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1322, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 1262, in _find_spec
  File "<frozen importlib._bootstrap_external>", line 1528, in find_spec
  File "<frozen importlib._bootstrap_external>", line 1502, in _get_spec
  File "<frozen importlib._bootstrap_external>", line 1605, in find_spec
  File "<frozen importlib._bootstrap_external>", line 1648, in _fill_cache
OSError: [Errno 5] I/O error: '/usr/local/lib/python3.12/site-packages/bluetooth_auto_recovery'
and
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:202
First occurred: 21:57:09 (168 occurrences)
Last logged: 22:04:07
and
Source: components/recorder/core.py:882
First occurred: 21:57:09 (1 occurrences)
Last logged: 21:57:09
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: INSERT INTO states (entity_id, state, attributes, event_id, last_changed, last_changed_ts, last_reported_ts, last_updated, last_updated_ts, old_state_id, attributes_id, context_id, context_user_id, context_parent_id, origin_idx, context_id_bin, context_user_id_bin, context_parent_id_bin, metadata_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) RETURNING state_id] [parameters: (None, '-48', None, None, None, None, None, None, 1733345829.3116176, 39025954, 46266, None, None, None, 0, <memory at 0x7f4c49b7c0>, None, None, 1067)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2116, in _exec_insertmany_context
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 924, in do_execute
sqlite3.DatabaseError: database disk image is malformed
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 882, in _process_one_task_or_event_or_recover
  File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 297, in run
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1174, in _commit_event_session_or_retry
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1210, in _commit_event_session
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2017, in commit
  File "<string>", line 2, in commit
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/state_changes.py", line 139, in _go
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 1302, in commit
  File "<string>", line 2, in _prepare_impl
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 1277, in _prepare_impl
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4341, in flush
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4476, in _flush
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/util/langhelpers.py", line 146, in __exit__
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 4437, in _flush
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/unitofwork.py", line 466, in execute
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/unitofwork.py", line 642, in execute
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/persistence.py", line 93, in save_obj
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/persistence.py", line 1143, in _emit_insert_statements
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1418, in execute
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/elements.py", line 515, in _execute_on_connection
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1640, in _execute_clauseelement
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1844, in _execute_context
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2124, in _exec_insertmany_context
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
Among other sensor/integration errors.
Reboot/shutdown via GUI doesn’t work. Pulled the power of the rpi5 with no difference.
Can’t access backups to restore because supervisor doesn’t start (properly?).
Any ideas?
December 2024 ▶ durd
durd
Hm, after the 2nd forced restart it seems to be working again.
Had the update available again, installing it this time worked.
:person_shrugging:
1 reply
December 2024
tom_l
Check if you have any history data.
1 reply
December 2024 ▶ tom_l
durd
I have history back until the 27th of november. Before that it’s empty :frowning:
It seems I have certain history data earlier. Like temperature data, but state seems to only be available since the 27th.
1 reply
December 2024
maumaumau
for what ever reason my knx secure tunneling connection does not work anymore.
Routing is no options, since I do not get any values.
1 reply
December 2024 ▶ FrancoLoco1234
sdaltons
Glad I saw this before updating to 12.0. Following.
jaalperin
Yup. Went back to Core 2024.11.3. Want Alexa Media Player more than new features. Sounds like this could be an extended issue.
December 2024
Emiel86
After updating to 2024.12 my Tado integration doesn’t load my “Tado X” anymore.
I get this error when reloading it:
How to solve this?
Logger: homeassistant.config_entries
Source: config_entries.py:640
First occurred: 23:25:18 (4 events)
Last logged: 23:32:51
Error setting up entry Home for tado
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 640, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 84, in async_setup_entry
    await hass.async_add_executor_job(tadoconnector.update)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 184, in wrapper
    result = method(*args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/tado/tado_connector.py", line 79, in update
    self.update_devices()
  File "/usr/src/homeassistant/homeassistant/components/tado/tado_connector.py", line 142, in update_devices
    device_short_serial_no = device["shortSerialNo"]
KeyError: 'shortSerialNo'
December 2024
bwduncan
I’m not a HA internals expert but as a linux admin my first suggestion would be to check you haven’t run out of disk space.
1 reply
petro Great contributor
Another release, another AMP failure
Sorry, I probably should have made an announcement but I forgot.
December 2024 ▶ bwduncan
durd
Is there a setting for how long I want to save state history?
Recently switched to an NVMe HAT for the rpi5 and an 500GB NVMe.
Not sure how much I was using before, but after the upgrade/issues I’m using 2.5%.
December 2024
marisa
Guess I no longer need to maintain my Fallback Conversation agent: m50/ha-fallback-conversation: HomeAssistant Assist Fallback Conversation Agent
December 2024
donaldtrump
Does Music Assistant support Alexa / amazon music yet? Without support for that it’s just not useful.
grillp
The issue has been logged with ‘alexapy’ seems it has a restrictive requirement for aiofiles <= 24.0.0, but with the new release of HA, aiofiles is now at 24.1.0
You can check on the progress here
 seems it was raised 5 or so days ago, but the maintainer is replying strangely
 :person_shrugging:t3:
December 2024
lightsabata
after update to 2024.12, and test fallback agent with an ollama, i have an error with defaut sentences : “Unexpected error during intent recognition”
2024-12-05 01:36:23.253 ERROR (MainThread) [homeassistant.components.assist_pipeline.pipeline] Unexpected error during intent recognition
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 1057, in recognize_intent
    intent_response := await conversation.async_handle_intents(
        self.hass, user_input
  File "/usr/src/homeassistant/homeassistant/components/conversation/__init__.py", line 233, in async_handle_intents
    return await default_agent.async_handle_intents(user_input)
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 1346, in async_handle_intents
    result = await self.async_recognize_intent(user_input, strict_intents_only=True)
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 330, in async_recognize_intent
    result = await self.hass.async_add_executor_job(
    ...<7 lines>...
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 537, in _recognize
    strict_result = self._recognize_strict(
        user_input, lang_intents, slot_lists, intent_context, language
  File "/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py", line 773, in _recognize_strict
    return recognize_best(
        user_input.text,
    ...<5 lines>...
        best_slot_name="name",
  File "/usr/local/lib/python3.13/site-packages/hassil/recognize.py", line 580, in recognize_best
    for result in recognize_all(
        text,
    ...<7 lines>...
        language=language,
  File "/usr/local/lib/python3.13/site-packages/hassil/recognize.py", line 231, in recognize_all
    intent_sentence.compile(match_settings.expansion_rules)
  File "/usr/local/lib/python3.13/site-packages/hassil/expression.py", line 150, in compile
    self._compile_expression(self, pattern_chunks, expansion_rules)
  File "/usr/local/lib/python3.13/site-packages/hassil/expression.py", line 170, in _compile_expression
    self._compile_expression(item, pattern_chunks, rules)
  File "/usr/local/lib/python3.13/site-packages/hassil/expression.py", line 176, in _compile_expression
  File "/usr/local/lib/python3.13/site-packages/hassil/expression.py", line 189, in _compile_expression
    raise ValueError(rule_ref)
ValueError: RuleReference(rule_name='lumieres')
is a specific error on my side ?
December 2024
beaulebens
After this update, I’m seeing the smartweatherudp component fail to load unfortunately. Submitted an issue over here.
December 2024
TomW1605
so is there still no way to actually edit a scene without activating it?
its not that uncommon to know what changes need to be made (especially if it is just adding static lights or changing other things that are on/off or limited options) so still needing to activate the scene to make those changes seemse silly.
the review mode also dosnt show you the actual state of any of the entities in the scene so its pretty useless for review beyond “what devices/entities does this scene use”
you can at least edit it in yaml without activating it now but that is far from ideal. it dosnt seem to make sense to force the scene to be active while editing rather than just having a “preview” mode you can turn on that activates the scene but dosnt change the actual edit capabilaties
1 reply
December 2024
marnau
Do shelly devices are working after this update?
December 2024
myle Guidance Counsellor
Thanks Guys
another 10 out 10
Did my first update while at work ( don’t tell the boss) came home everything was updated and working
December 2024
sparkydave Guidance Counsellor
Has anyone else noticed that ‘sunrise’ based triggers aren’t working with HA 2024.12 ?
This morning I was still on HA 2024.12.b4 (or 5, can’t remember) and none of my sunrise triggers worked
 simply no trigger occurred. I’ve since updated to HA 2024.12.0 stable so will see what happens tomorrow morning.
This simply didn’t trigger:
platform: sun
event: sunrise
offset: '-00:15:00'
which has done perfectly for years.
In the meantime I’ll update the automation to the newer syntax.
December 2024
Protoncek Vseved
Translations are a mess in this update. I have some of my HA in slovenian (like it should be), some in english (well
acceptable) and some in
 Swedish/Finnish/Norwegian (one of those)
??? Yes, i did a total page refresh (with “empty cache and hard reload”).
And, was there any warning about “file” integration changing? After update i’ve got an error about non-existing entity (nofity.export_to_file).
so i’m back to 2024.11.x for now.
December 2024 ▶ sparkydave
pergola.fabio
Hey, i also have a lot of sunrise / sunset automations, not updated yet
 have you found something? what new syntax you mean?
1 reply
Chrisalbertson
The solution, I think, is to always send the command to both placers and then whichever one finishes quickest “wins”.
1 reply
December 2024
Simply that no trigger occurred at sunrise.
The new (a few months ago) syntax for triggers goes from:
trigger:
  - platform: sun
    event: sunrise
    offset: '-00:15:00'
to:
triggers:
  - trigger: sun
    event: sunrise
    offset: '-00:15:00'
I’ll see what happens in the morning.
pergola.fabio
Ok, will update also today
 Maybe it’s the sun integration itself?do you see errors in the log?
1 reply
December 2024
Lugaid
My shelly devices stoped working after this update, anyone else that got t
this problem?
December 2024
janip81
Seems there is a bug here? i got integretation that stopped working with this version
[[homeassistant.setup] Setup failed for custom integration ‘dreame vacuum’: Unable to import component: No module named ‘py_mini_racer’
December 2024 ▶ maumaumau
farmio Great contributor
Hi :wave:!
Try to reconfigure that connection.
If the issue persists, please create a GH issue or a new thread here for that. Feel free to @-ping me in there.
December 2024 ▶ NathanCu
IoSonoAndreaZ
actually it is off by default, you have to edit assist settings to turn it on
December 2024 ▶ janip81
pergola.fabio
report here: Issues · Tasshack/dreame-vacuum · GitHub
1 reply
IoSonoAndreaZ
same setting as you, my whole home assistant container is 1.8gb at the moment, but I never tracked its size
December 2024
DataMeister
It is no secret: our voice hardware will be revealed on 19 December 2024.
What does that mean?
December 2024
tom_l
All mine (sunrise and sunset triggers) have been working.
Check your underlying OS time (not HA system time). Check your HA location has not changed (unlikely).
1 reply
December 2024
Renurios
My zha stoppt working. Downgraded to 2024.11.3 zha worked again.
December 2024
nothing relating to this issue.
1 reply
December 2024
good point
 looking at the Host log it is currently scrolling through log entries saying ~8:45am but it is currently 4:45pm (Perth, West Aus). Is that time supposed to be localised or is that supposed to be GMT? (if it’s GMT then that’s fine)
Time zone setting is fine:
1 reply
December 2024
tom_l
Yes it is.
Thijmen
Seems to be a simple fix, simply add the context of the last few commands or the current conversation into the A.I. Would not be surprised if a developer reads this and adds this in the january release :slight_smile:
December 2024
thewizardfromoz
Do we not get a little teaser or preview of this big hardware announcement?
Mariusthvdb
those shouldnt be causing any change at all because:
this is not a breaking change , and there will be no deprecation
you can forever keep your former syntax, search elsewhere for your trouble
December 2024
ColinRobbins
Please be aware this update breaks the Overkiz local integration.
Details here
1 reply
December 2024
GunterAv
SmartIR are not working in this Version!
I have switched back to version 11.3.
Best regards
Gunter
1 reply
December 2024
CChris
what version of Dreame vacuum (custom component) are you using?
I am on 2.0.0b16 and not noticed any issue with the integration.
If you are still on 1.0.4 I would recommend to switch to the current 2.0 beta version (which is quite stable) - since the 1.0.4 was not updated since may.
Thanks for the update, was a smooth one
 it’s a bit odd, but somehow, I miss the work on adding new design options to my dashboards
 :smiley:
December 2024 ▶ marnau
guidok
With 2024.12.0 core update, my Shelly devices were no longer available in HA. After restoring my HA 2024.11.3 backup, the Shelly devices (Dimmers and Plugs) are available again in HA. I noticed a bug report on GitHub [BUG]update home assistant core to 2024.12.0 breaks em · Issue #782 · StyraHem/ShellyForHASS · GitHub
December 2024 ▶ CChris
pops106
I have 2 HA boxes, one is running 1.0.4 without any issues after the upgrade. Second box I am about to upgrade now.
The map takes a while to load in after a reboot, but that is on both boxes.
1 reply
December 2024 ▶ pops106
CChris
the map will be extracted from the cloud, so I don’t think, that this is a HA or a topic specific for the integration
 :slight_smile:
But glad, that the 1.0.4 is working for you.
That indicates, the issue for janip81 is probably not an issue specific to the dreame integration, but might be a conflict with something else.
December 2024 ▶ guidok
dana_se
ShellyForHass will no longer receive further development updates. This decision stems from the fact that its features and functionality have been seamlessly integrated into Home Assistant, making it redundant to maintain a separate plugin.
https://github.com/StyraHem/ShellyForHASS
Bieniu Shelly Integration Dev
You should migrate to the core Shelly integration.
1 reply
December 2024
Fix is coming
December 2024
janip81
Done!
janip81
I use the version 2.0.0b16 and how tried redownloading integraton too, have no idea why its not working. Only thing that worked for me was to roll back to older container image
December 2024
jurijvi
ZHA and Overkiz are broken by 2024.12, reverting back to 2024.11 and no issues.
December 2024
TimoJ
Change to this updated and maintained version of SmartIR:
HappyCadaver
I have 2 of these and both triggered just fine last night and this morning.
December 2024
refeu
Not the best experience if you are doing some midnight tinkering and accidentally activate a scene that turns on all the lights in the house, waking up everyone.
Damn, it really happened to me exactly like that (not turning on the lights but opening the shutters.
1 reply
December 2024 ▶ Chrisalbertson
Xitee
This would be a solution to the problem that the agent is not aware what the last prompt was but one of the benefits of trying it first locally is that it reduces costs. The LLMs are not (completely) free. For example the Google LLM is free for some amount of requests but if it is exceeded, it will cost you money.
December 2024 ▶ refeu
mcarty
I never tinker or update when its dark. Always wait to next morning! :slight_smile:
vacar
Yeah - that is so annoying. Now it has been stable for a few weeks
 :man_facepalming:
December 2024
mmatesic01
With 2024.12 if HA is set on Slovenian language interface some of the text is in scandinavian language.
1 reply
December 2024
Viking
How come NordPool integration is listed as a “new” integration in 2024.12 ??
I’ve had the Nordpool integration for many years!
December 2024
sd_dracula
Alexa media player still broken in 2024.12?
1 reply
December 2024 ▶ Viking
It was custom before, now it’s built in. I do not know if the feature parity is the same as the custom integration. Your custom integration will overwrite the built in one, so there’s nothing to worry about if you are still using the custom integration.
Michael_Dahl
My guess, not the same developer.
Also looks like different output, but I have not tried the “build in”
1 reply
December 2024 ▶ sd_dracula
Yes, and it’s likely to be broken for some time.
December 2024
erikm
Upgrading hass-core on a Raspberry Pi 3 running Raspbian/Debian Bookworm (i.e.: current stable) breaks on PyAV:
(venv-3.12) pi@hass:~/.homeassistant $ uv pip install -U homeassistant
      AV_CODEC_FLAG2_NO_OUTPUT
      src/av/codec/context.c:15851:48: error: ‘AV_CODEC_FLAG_FRAME_DURATION’
      undeclared (first use in this function); did you mean
      ‘AV_CODEC_CAP_FRAME_THREADS’?
      15851 |   __pyx_t_2 =
      __Pyx_PyInt_From___pyx_anon_enum(AV_CODEC_FLAG_FRAME_DURATION); if
      (unlikely(!__pyx_t_2)) __PYX_ERR(0, 76, __pyx_L1_error)
      error: command '/usr/bin/gcc' failed with exit code 1
INFO:homeassistant.util.package:Attempting install of numpy==2.1.3
Incorrect config
  General Warnings:
    - Integration error: default_config - Requirements for stream not found: ['av==13.1.0'].
Successful config (partial)
And apparently we came from the Hass AV fork ha-av 10.1.1 and upgraded to upstream av 13.1.0. Unfortunately that depends on ffpmeg 7.1 while Bookworm comes with version 5.1.6.
There’s no newer ffmpeg version available in Debian Backports, so I might end up building the package from the source package in Debian testing. Now I only need some time
December 2024 ▶ Michael_Dahl
FYI you are correct, they are different developers
December 2024 ▶ mmatesic01
Protoncek Vseved
True. I’ve been told that some swedish guy was translating into slovenian file instead his own
 i changed to english for now. From what i saw on “lokalise” over 3000 words are overwritten, so unless there’s any kind of backup there we’re fu**ed
December 2024 ▶ Bieniu
Waling
How can i migrate to the core Shelly integration?
1 reply
December 2024 ▶ Waling
pergola.fabio
My sunrise/sunset triggers are still working
December 2024 ▶ erikm
erikm
Quick scan, this is going to be dependency hell.
So ffmpeg 7.1 needs libsdl2-dev, which needs libudev-dev, which needs libudev1, and specifially version 252.31-1~deb12u1, but as I already need debian-backports packages for hass core, version 254.16-1 is installed.
But
 I think I can disable the SDL feature for this particular use as SDL is used for native video playback so I’m going to recompile the package without support for SDL
December 2024
cerebrate
Looks like the relevant fix for alexapy just got merged over on Gitlab, so there’s definitely progress happening on the Alexa Media Player front.
Other integrations breaking with 2024.12, FYI: Anniversaries, Frigidaire, Grocy, and Schedule State.
December 2024 ▶ Protoncek
mmatesic01
There has bo be somekind of backup in such cases.
December 2024
robertwigley
Alexa Media Player 5.0.1 is released with the fix for this version and available to download/install/update to.
1 reply
December 2024 ▶ robertwigley
Verified working
nighteyes
yep, same here.
nighteyes
i am using the core integration. none of my shelly devices are working anymore with this update. logbook shows multiple errors with the shellly core integration.
1 reply
December 2024 ▶ nighteyes
Open an issue.
tom_l
The PRs can be reverted.
1 reply
December 2024 ▶ Lugaid
hfeenstra
Had/have exactly the same. So went back to 2024.11.3
Will wait for update
December 2024 ▶ ColinRobbins
hfeenstra
Thanks for the heads up. Beside Shelly another integration that breaks. Just will be patience and wait
hfeenstra
Can we find the steps somewhere in the documents for this transition?
1 reply
December 2024 ▶ hfeenstra
No, HA documentation does not contain information about custom integrations.
1 reply
hfeenstra
Thought you mentioned in an earlier post it moved from custom to full integrated integration?
Just curious where I can find these heads up and the process to this new integration.
Thanks!
1 reply
Mariusthvdb
Had not notice before but experienced the same today. No automatic theme change, which has been reliable for years and years
Haven’t found the trace yet to point to sun trigger 100%, so need to inspect further
1 reply
tilz0R
No issues for me. All works as expected.
December 2024
smarthoo
all shelly are dead with the update. all unavailable. After restore the whole Home Assistant all shelly are working again. This update kills shellys!
1 reply
ShawnP
Same for me. Had to rollback.
