Continue Discussion 26 replies
June 26
francisp
Could use a better title.
1 reply
June 26 ▶ francisp
MissyQ
what do you mean this is perfectly normal
:grimacing:
Edited to add: We’re working on fixing this, clicky the link at the bottom of the OP to read the blog post for now.
One more edit: TITLE FIXED!
June 26
arturpragacz
Vacuums without the ability to clean specified rooms are not very useful to me. Roborocks can do it. It would be nice if that was added to the local Bluetooth Switchbot integration as well.
June 26
s00500
It would be AMAZING if you guys could look into using the contact sensors button, having this device officially supported but missing one of its coolest features feels sad :-/ especially since there already has been a PR and effort to fix this previously that got lost…
1 reply
June 26 ▶ s00500
Miranda-GB
Hey Lukas, thanks for the feedback, have passed this on to the SwitchBot team.
1 reply
June 26 ▶ arturpragacz
Miranda-GB
Thanks for the feedback, the Bluetooth integration is being continually improved but we’ll be sure to pass this on.
June 26
s00500
Awesome! Great to hear!
June 26
git-damien
Wonderful news. New Works with Home Assistant partners are my favorite type of announcement, especially when it is one of the big names like SwitchBot.
June 26
markusressel
This is great!
Really liked the original Curtains and bought the Curtain 3 recently. Not exactly an upgrade in every way (especially the noise level at standard speed), and the magnetic end stops don’t work for me at all, but still seems like a solid upgrade hardware wise if you dont have them already.
Would be even better if it was possible to set a custom speed for the curtain Integration without the need to rely on a third party project.
Also: What about the SwitchBot Remote Control? Shouldn’t be too hard to add support for a simple BLE button, right?
Thx for reading, hope for a response!
June 27 ▶ Miranda-GB
guilster
But Miranda, if a device doesn’t “have full functionality within Home Assistant” it shouldn’t be listed here.
The button in the Switchbot contact sensor doesn’t work in HA. The same goes for the button in the Aqara P2 contact sensor.
This isn’t a matter of passing feedback to the certified company, it’s a matter of delisting devices that lack full functionality.
1 reply
June 27 ▶ guilster
Miranda-GB
Hey there, absolutely, it’s also a case of I need to know internally what was missed here first. Thanks for flagging about the Aqara sensor also. I’ll take a look at that one.
1 reply
June 27 ▶ markusressel
Miranda-GB
Hey there, thanks for this. Remote controls are a kind of odd device in the ‘Works with’ context because badging it can create confusion as to what use case they’d actually fulfill. It is something I’m looking at though and even if it’s not a good candidate for ‘Works with’ SwitchBot have it in their list for development. Cheers!
guilster
Thanks a million for following up!
June 27
Holdestmade
Also, the ability to show the correct state and not “Cleaning” all the time. Github issue SwitchBot Vacuum K10 status incorrect · Issue #145851 · home-assistant/core · GitHub was raised but Switchbot replied the firmware will only show “Cleaning” state or “Docked” state. Problem is, once docked and charged, it goes back to “Cleaning”. I’ve gone back to the addon, it works there.
1 reply
June 27
Edwin_D Regular
The only reason I know why speed control is not implemented in the official integration is because there is an architecture discussion about how it should be implemented in covers that is left dormant for years. So this is op to the HA team to make up their mind.
A PR to implement is was not approved because of the open discussion.
I now have seven template covers calling scripts to look at either input selects or input numbers for speed. It is not just Switchbot, Somfy and other integrations have the same problems.
1 reply
June 27 ▶ Edwin_D
shanecosgrove14
As others have said the ‘integration’ is very limited compared to what can be done via their own app (e.g. their robot can be set to clean a specific room in the app but not via HA).
Their contact sensor doesn’t seem to play nice with the Bluetooth proxy network in terms of it operating outside the range of their own Bluetooth devices like hub.
Also, it’s a shame that their Bluetooth devices aren’t able to act as Bluetooth proxies in the way Shelly has allowed.
Good progress , but I won’t be buying more Switchbot until they up their game and truly Integrate into HA.
June 28
Hedda
@Miranda-GB @MissyQ @synesthesiam would be a good idea if you could time all announcements on the Home Assistant blog to space them out more, as lately you dropped news posts practically the day after each other which mmakes prevouis blog post drop down and thus is easier to miss. Suggest that if you for example plan to drop 4 blog posts in a month then space out posting them with at least 7 days between them. Now you guys just posted three blog posts the days after each other, so chance is less than people will miss seeing them all. This is not new but almost the norm.
June 30
SiriosDev
The truly groundbreaking update will be the ability to integrate IR devices (trough the hubs) via Matter-over-(anything, as long as it’s local) rather than via Matter-over-internet (or better, matter-over-internet-over-ir lol). Even just the ability to send IR signals manually would suffice if there is no way to disconnect the commands from the cloud.
July 1 ▶ Holdestmade
sdaltons
Sorry…which addon?
1 reply
July 1
Holdestmade
This one:
1 reply
July 2 ▶ Holdestmade
sdaltons
Thanks. I remember trying that awhile back and thinking it was kind of weird the way some devices were implemented. Maybe I will give it another look.
July 8
Dxcv
Does the Matter certification also means it works locally? About 6 months ago I came across information that using their hub required an internet connection for the devices to work.
Been considering the BLE integration though.
July 12
takiainen
When will Switchbot add full bluetooth integration support for Keypad Vision ? I don’t want to use any cloud / internet based solutions when adding temporary passcodes for eg.
Also the Keypad has a doorbell button, which could be integrated into home assistant to trigger what ever automation you can imagine.
Currently my bluetooth proxy can see keypad vision, but since it is not supported by the integration, I cannot connect to it. I dont have a hub, nor will I ever get one.
Things must be local, simple as that.
July 16
rplunkett
Bought my first switchbot product, and wow am I disappointed. The garage door opener just presents as a switch, and you can’t view the status. It should present as a cover entity. The switchbot app doesn’t have this limitation. How can a company be part of this program, but their new products have terrible home assistant integration?
July 17
Idaho947
Yeah keypad vision support will be very coool.
For the fan vertical move on off switch, light and led indicator switch will be very nice too.
July 18
Rice_Eater
Add me to the list as someone who really wants to see the Keypad Vision added to the Switchbot Bluetooth integration please.
At the very least give us access to the doorbell button. If I don’t have a good idea for it then I’ll just use it as a more convenient lock button despite the keypad already having one lol.
