0.106.0 custom:mini-graph-card, blank UI editor
I updated to 0.106.0 this evening. All of my previously defined custom:mini-graph-card elements are no longer displaying. When I click the Configure UI button, all elements disappear. If I click Raw configuration editor, I can see everything defined, but they still do not appear via the UI editor. Essentially a blank screen with the header at the top and side menu.
I confirmed the /local/mini-graph-card-bundle.js?v=0.9.2 file still exists and it does. My custom:simple-thermostat seems to be working fine, so maybe something is amiss with the mini-graph-card? Not sure why this would come up now though and do not see anything specific in the release notes which would cause this.
[Update] Removed all the references to custom:mini-graph-card, now the UI paints and the editor works as anticipated. Must be something with the graph card, but this seems odd.
No problems here. Updated from 0.105.2 to 0.106.0. All my mini-graph-cards are working, thankfully.
Did you manually install the mini-graph-card or use HACS?
Long time ago I manually installed. But about 6 months ago, I removed all manually installed items and switched to HACS. I keep it updated regularly.
I manually installed, so that may be the difference. Will try HACS and see how that goes. Appreciate the help.
Sure, I just checked, the HACS version of the card is at 0.9.3.
I was able to get the custom:mini-graph-card working by installing HACS, then installing the plugin. Feels much cleaner this way anyhow vs the manual install.
Hi guys,
had exactly the same problem. It appeared that initially I had custom:mini-graph-card installed manually, then switched to HACS, but the config line referring to local path of bundle.js was still there. I cleared the config, uninstalled and installed the card via HACS again and now it works like a charm.
Anyway, this place is where I found solution to my problem - thanks!
