@ KennethLavrsen Iād link this to Safari specificallyā¦ Even of my Mac Pro (2013) loading HA in Safari might create issues and be very slow. It was disastrous up to 0.103, is gradually getting better up to 0.105, did not tested it yet with 0.106. On .105 issues I yet face are related to date selector in history view, that do not show up until you click somewhere on calendar and deconz Settings/Gateway page not being displayed. These issues are consistent across Safari browser on all platforms I tested (Mac, iPhone, iPadā¦ not tested with Safari for Windows). None of these issues exist for the very same HA configuration when using Chrome.
@KennethLavrsen I think a github issue would be good for this. (If you have not already done one, if you did, sorry I missed it). Devs are far more likely to address an issue than a forum post.
Going from the code, it looks like the flaps and pets options have been changed so they just take a list of ids rather than a map of id and name but the documentation hasnāt been updated to reflect this (and it wasnāt listed as a breaking change). So your config would probably need to be something like:
surepetcare:
username: !secret sure_petcare_username
password: !secret sure_petcare_password
flaps: [!secret sure_petcare_flaps]
pets: [!secret sure_petcare_pets]
I raised the github right after my first post here. And our beloved dev has already an idea of what the problem is so I am optimistic it will get fixed
āUpdateā Here is a gif
Another Update: Seems to work in Chrome
Iām experiencing issues on my mobile devices.
As stated the custom cards needs to be updated when I want to remove them everything on the page dissapears and I need to Restart HA to get them displayed properly again.
On this page you should see a sensor page (not custom) and a batch of Mini Graph cards. When I end edit mode they will NOT re-appear
o dear, is this still the case a few hours after updating (sometimes feel the HA instance needs to adjust internally, might nit be true, only gut feeling)
If yes, please file an issue on this so the devās and Balloob know about it. Much went into mitigating Hue errors. This might be an unwanted side effect, or, lets hope, simply overlookedā¦
I noticed the ādarkā attribute of my IKEA motion sensors is gone after the update. Maybe I interpreted #31661 wrong, but I did not expect this to happen.
I connect the sensors using deConz specifically for this attribute. I hope to see it back again.
Has anyone tested the Melcloud integration?
Iāve tried to add it (used the custom component before), but after clicking on the Melcloud integration the window closes.
Also, trying to figure out where is this token:
ā The required authentication token can be found in X-MitsContextKey
header when logged into the MELCloudā
Yes it āshouldā still work
Thanks Robban.
I noticed I was running deCONZ firmware version 5.1 so updated to 5.3.
The release notes didnāt specify a fix of any kind and it worked fine under v0.105x, but now one of the three sensors shows the attribute. So perhaps a reset fixed it and it seems no HA version issue.
For the record, I did a HA restart and a system reboot before posting.
Worth keeping in mind, itās not like Safari is a known bad browser. It optimizes for energy consumption vs. performance, while Chrome optimizes for performance vs. energy. And Chrome is more aggressive at adopting new standards. But Safari is still widely regarded as a great browser, with good performance characteristics in spite of optimizing for energy efficiency.
So, letās say it is a problem only on Safari. Itās probably not a good idea to dismiss it as Safariās fault, just because it does work on Chrome. Not unless weāre going back to the days of IE vs. Netscape.
Itās worth investigating, what is the problem? Is there a genuine issue with Safari? Maybe. Or is the HTML and JavaScript so inefficient that itās the cause? Maybe. Some of these JavaScript front-end frameworks areā¦not efficient. Or can be inefficient when used sub-optimally.
Might be, itāll be something hard to fix, and the developers move on to other things, and recommend folks use Chrome. But, might be something easy to fix, and in that case, I bet Home Assistant performs better no matter what browser youāre using.
(Iāve been getting Safariās āThis webpage is using significant memory. Closing it may improve the responsiveness of your Mac.ā error message, starting with my first install at .104. Itās been driving me nuts. Chrome, as evidenced by the amount of memory itās using for far fewer tabs, is unconcerned about memory usage. That doesnāt mean Home Assistant pages memory usage isnāt excessive, just that Chrome has gone honeybadger-donāt-care on us.)
ZHA native support for Texas Instruments CC based Zigbee sticks is what Iām personally most excited about!
I personally think that the 0.106 release notes should also have high-lighted/promoted the newly added ZHA support for Texas Instruments CC series based Zigbee coordinator sticks because of their very inexpensive price has the potential of making it a disruptive technology in a positive way for the Home Assistant community.
Pull request #31621 by @sanyatuning adds native support for the same cheap CC2531 Zigbee sticks to Home Assistant, the same Zigbee sticks that the Zigbee2mqtt project has made popular among the community.
Right now the short comment about Texas Instruments CC support was hidden in the list of all changes in the 0.106 Beta release notes, and again I personally think that it was as such was not very informative about the impact that native support for inexpensive Texas Instruments CC based Zigbee coordinator sticks could potentially have.
Maybe it could be mentioned in a community highlight?
Try
Can you link us to the github issue? Iād like to track it
Sure. The Integration paging loading issue on IOS is tracked here
The documentation is only partially updated. It mentions the TI radios, but it does not say you what radio_type you need to add.
zha:
radio_type: ti_cc
usb_path: /dev/ttyACM0
Iāve updated and am not seeing the lovely new sensor card?
Any ideas?
Ctrl + F5
+1
even bought a new MBpro16 for this with 32gb memoryā¦ the Safari popups are by the minute. Well, maybe not the minute. But very abundant.
And yes, Iāve deselected the blockers on the website.
It would be very nice if this were to be investigated more thoroughly. Volunteer to assist in the testing.
Then again I do have a larger config by @KennethLavrsen 's definition so do fear upgrading to 106 somewhat.
No change for me.
