0.109: New integrations page and weather card, frontend lost weight
Same Issue here with all Tuya Covers on 0.109.0 and 0.109.1. Only Stop Button is available but not functional. Up and Down Buttons are gayed.
In Version 0.108.9 i was able to use all buttons.
Also to @nickrout. It was decided that nighttime conditions be completely removed from all weather platforms, but no dev has implemented it yet.
It took me removing that form the config, then deleting the HACS ISY plugin, then i was able to remove the integration. Neither the build in ISY nor the HACS plugin work any longer though. Very frustrating.
Sorry - forgot that page existed.
It desn’t give anything useful - I tried every single thing in there and averything still executes in MainThread.
I was more thinking of some useful examples to get us going.
Other people manage their deployment differently.
All my sensors are now unresponsive on Homekit. Only lights and switches working.
tried restarting HASS, Router and Homekit bridge (ATV).
I created an issue re ISY Custom Component in GitHub. As I no longer have the error available, additional input to this may be helpful.
Reverting to 0.108.9 was the simplest solution for me for the moment.
For the ISY994 custom component, enable ‘Show Beta’ on the ISY994 integration page in HACS and install 1.3.7 for compatibility with 0.109.0. Later today I’ll finish testing and mark it as a regular release.
From 0.109.0, native HA thermostat integration does not show set temperature for zwave thermostat valve (danfoss,devolo) anymore. Other HACS thermostat intergations do.
For me with 0.109.1, broadlink switches worked fine, however broadlink sensor was broken.
There were many changes in this sensor so I was afraid it was a bug, but I realized the name of the detected sensor entity had changed. New name was sensor.broadlink_temperature, I had to adjust the name where it was used.
Note that they also added a type attribute for broadlink sensor, but for me it is not necessary.
So all good for me with Broadlink RM Pro.
Hi, I have the same result
Synology DSM, broken in .109, I did do the rename, still broken.
I know.
I just don’t think it’s a good idea to deploy my home automation system from my phone, but that’s just my opinion, to each his own.
Same here. No sensors or locks available in HomeKit since 109.
Just updated to 109.1. When I click any of the pages (Automations, Scripts, Scenes, etc) it says “Error while loading page automation.”. I have rebooted several times and cleared cache.
I just tested removing one sensor from homekit.yaml, restarting, re-adding, restarting.
sensor shows up again.
so, basically you need to remove and re-add all sensors and lose all configuration on homekit side. not particularly excited about this when I have over 20 sensors and some shortcut automations…
template sensors are unaffected.
I roll back on 0.108.9 until it is fixed.
I think it has to do with entities card not with tuya.
  • prepi na perimenoume :slight_smile:
I just installed 0.109.1
Broadlink for my broadlink M3 mini is working again
show_forecast: False
