I see the message in the logs to remove the base_url, what specifically am I removing just that piece? So in my configuration.yaml I have:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://<URL>
server_port: 8123
ssl_certificate: /ssl/<URL>-chain.pem
ssl_key: /ssl/<URL>-key.pem
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- 192.168.0.14
Thanks, so right now in the external URL it just shows https://<URL> without the port grayed out of course at the moment. Should I then assume I remove base_url from configuration.yaml and leave the rest including the port as is?
So if right now using fake values I have:
http:
base_url: https://joe.whatever.net
server_port: 8123
ssl_certificate: /ssl/joe.whatever.net-chain.pem
ssl_key: /ssl/joe.whatever.net-key.pem
trusted_proxies:
- 127.0.0.1
- 192.168.0.14
I would change it to:
http:
server_port: 8123
trusted_proxies:
- 127.0.0.1
- 192.168.0.14
and under Configuration > General under External URL put:
