0.33: New Calendar component, Wink thermostats and Cisco IOS
For this release we put a lot of focus on finishing our async upgrade and fix a bunch of bugs in the process.
But a new release wouldn’t be awesome if it didn’t had some new goodies and this release is no different. This release includes a new calendar component by @mnestor. It comes now with Google Calendar support, which should allow you to automate things based on your calendar events!
Changes
Release 0.33.1 - November 20
Release 0.33.2 - November 22
Release 0.33.3 - November 23
  • Update Yr.no entities every hour (@kellerza)
  • Bump Netdisco to 0.7.7 (fixes discovery on Synology)
  • Fix discovery race condition (most obvious in Wemo) (@balloob)
Release 0.33.4 - November 24
  • Set executor pool size to 10 (as intended) (@pvizeli)
This should fix occasional performance problems that some people have reported.
Breaking changes
  • We have included a fix that impacts how we generate entity ids. This only impacts devices with accented characters. Instead of being stripped out, they are now replaced with the non-accented version. So now Tèst Mörê will become test_more instead of tst_mr.
  • Command line switches will now use the specified object ID for their entity ID instead of basing it off the name.
Reporting issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2016/11/20/calendar-wink-thermostats-cisco-ios/
