0.35 new base_url parameter for http component
I just noticed that there is now a base_url parameter for the http component.
Does this mean, I can run hass on an arbitrary url path now, e.g. even behind an apache reverse proxy like https://myhost.example.com/homeassistant?
How would a correct configuration look like then - I noticed that in 35.2 there has been resolved a conflict with the server_port parameter?
My original config looked like this:
http:
  server_port: 8123
And I had an apache vhost that basically did:
ProxyPass            /api/websocket  ws://localhost:8123/api/websocket
ProxyPassReverse    /api/websocket  ws://localhost:8123/api/websocket
ProxyPass            /                http://127.0.0.1:8123/
ProxyPassReverse    /                http://127.0.0.1:8123/
ProxyPreserveHost    On
So with the base_url parameter, could I do it just like this:
http:
  #server_port: 8123
  base_url: mydomain.example.com:8123/hass
and regarding apache:
<Location /hass>
        ProxyPass               http://127.0.0.1:8123/hass
        ProxyPassReverse        http://127.0.0.1:8123/hass
</Location>
What about the server port with regards to the base_url parameter?
“Release 0.35.2 - December 19
When base url specified, do not combine it with server_port (@balloob)”
Is there a place that provides a little more detail to the release notes, generally speaking?
Other than the component documentation page for the affected component?
Sebastian
Nop, this is not supported.
Ok, thanks.
So this parameter exists only to fix some error with the TTS component?
Sebastian
I too would like to know about this.
The http doc and the 0.35 release notes don’t say what it actually does.
I would like to know if it could help me with redirects/ports on my router. Before I added TTS and LetsEncrypt, I had my main http:// DDNS URL pointing to a web server on PC1 and the same URL:8123 pointing to HA on PC2. Now I have https:// DDNS URL pointing to HA, but http:// DDNS URL is dead and I had to add a subdirectory to my PC1 web server, which I’d rather not have.
Is this base_url something that could help me, or… what does it actually do?
Thanks!
