It’s time for 0.46! This release does not have too many new integrations, instead it focussed on bug fixes.
New platforms
- Template light (@cribbstechnologies - #7657) (light.template docs) (new-platform)
- Support for GE Zwave fan controller (@armills - #7767) (zwave docs) (fan.zwave docs) (new-platform)
- Rachio (Sprinklers) (@Klikini - #7600) (switch.rachio docs) (new-platform)
- Introduced support to Netgear Arlo Cameras (@tchellomello - #7826) (arlo docs) (camera.arlo docs) (sensor.arlo docs) (new-platform)
Release 0.46.1 - June 9
- Support for renaming ZWave values (@armills - #7780) (zwave docs)
- Dsmr5 revert (@aequitas - #7900) (sensor.dsmr docs)
- Fix typos in Wunderground component (Percipitation -> Precipitation) (@mje-nz - #7901) (sensor.wunderground docs)
- Mqtt cover: Making command topic optional and add ability to set up/down position including ability to template the value (@cribbstechnologies - #7841) (cover.mqtt docs)
- Media Player - OpenHome: Fixed metadata issue (@bazwilliams - #7932) (media_player.openhome docs)
- Sensor - MetOffice: Fix last updated date (@cyberjacob - #7965) (sensor.metoffice docs)
- Prevent Roku doing I/O in event loop (@balloob - #7969) (media_player.roku docs)
Breaking changes
- The USPS sensor entity names have changed as there are now two. One for packages and one for mail. Config will now also use
scan_interval
instead ofupdate_interval
(@happyleavesaoc - #7655) (sensor.usps docs) (breaking change) - Automation state trigger: From/to checks will now ignore state changes that are just attribute changess (@amelchio - #7651) (automation.state docs) (breaking change)
- Redesign monitored variables for hp_ilo sensor.
monitored_variables
is now a list ofname
andsensor_type
values (@Juggels - #7534) (sensor.hp_ilo docs) (breaking change)
- platform: hp_ilo
host: IP_ADDRESS or HOSTNAME
username: USERNAME
password: PASSWORD
monitored_variables:
- name: SENSOR NAME
sensor_type: SENSOR TYPE
- Automation - time: The
after
keyword for time triggers (not conditions) has been deprecated in favor of theat
keyword. This resembles better what it does (old one still works, gives a warning) (@armills - #7846) (automation.time docs) (breaking change) - Automation - numeric_state:
above
andbelow
will no longer trigger if it is equal. (@armills - #7857) (breaking change) - Broadlink switches: Entity ids will change for switches that don’t have a default name set. In this case the object_id is now used. (@abmantis - #7845) (switch.broadlink docs) (breaking change)
- Disallow ambiguous color descriptors in the light.turn_on schema. This means that you can no longer specify both
xy_color
andrgb_color
. (@amelchio - #7765) (breaking change)
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
All changes
- Align with OpenALPR platform for naming conf variables (@fabaff - #7650) (image_processing.seven_segments docs)
- Added support to Amcrest camera to feed using RTSP via ffmpeg (@tchellomello - #7646) (camera.amcrest docs) (sensor.amcrest docs)
- bump fedex version (@happyleavesaoc - #7653) (sensor.fedex docs)
- bump ups version (@happyleavesaoc - #7654)
- update usps (@happyleavesaoc - #7655) (sensor.usps docs) (breaking change)
- Final tweaks for Zwave panel (@turbokongen - #7652) (zwave docs)
- Add network_key as a config option (@robbiet480 - #7637) (zwave docs)
- Bugfix #7586 (@turbokongen - #7661) (lock.zwave docs)
- Fix tests (@balloob - #7659)
- Change line endings to LN (@fabaff - #7660) (calendar.demo docs) (calendar.google docs) (camera.synology docs) (climate.tado docs) (remote.harmony docs) (sensor.synologydsm docs)
- Point pylutron to pypi (@thecynic - #7664) (lutron docs)
- Upgrade Openhome library (@bazwilliams - #7671) (media_player.openhome docs)
- Ignore attribute changes in automation trigger from/to (@amelchio - #7651) (automation.state docs) (breaking change)
- Switch pymodbus to pypi (@andrey-git - #7677) (modbus docs)
- zoneminder: fix incorrect use of logging.exception. (@tobygray - #7675) (zoneminder docs)
- Zwave: Apply refresh_node workaround on 1st instance only (@andrey-git - #7579) (zwave docs)
- Guard against new and removed state change events (@balloob - #7687) (automation.state docs)
- ZWave: Add reset service to meters (@turbokongen - #7676) (zwave docs)
- Remove defunct INSTALL_OPENZWAVE from Dockerfile (@armills - #7697)
- Fix telegram chats (@azogue - #7689) (notify.telegram docs)
- Fix playback control of web streams (@cgtobi - #7683) (media_player.volumio docs)
- Sort entities in default groups by name (@amelchio - #7681)
- Continue tracking device over dhcp lease table if wireless adapter not installed (@LvivEchoes - #7690) (device_tracker.mikrotik docs)
- device_tracker.ubus: Handle empty results (@tobygray - #7673) (device_tracker.ubus docs)
- Bump pyEight version (@mezz64 - #7701) (eight_sleep docs)
- Upgrade python-telegram-bot to 6.0.1 (@fabaff - #7704)
- Make ‘sender’ as requirement for the config (fixes #7698) (@fabaff - #7706) (notify.smtp docs)
- Allow fetching hass.io panel without auth (@balloob - #7714) (hassio docs)
- update apcacccess used in apcupsd to 0.0.10, which fixes random file drop from apcaccess (@infamy - #7722) (apcupsd docs)
- Constrain requests to a version (@balloob - #7725)
- Asuswrt continuous ssh (@aronsky - #7728)
- Ensure https base_url in telegram bot (@bzillins - #7726) (telegram_bot.webhooks docs)
- Prevent the random template filter from caching its output. Fixes #5678 (@antsar - #7716)
- Don’t initialize mqtt components which have already been discovered (@nordeep - #7625) (mqtt.discovery docs)
- LIFX: disable color features for white-only bulbs (@amelchio - #7742) (light.lifx docs)
- Don’t block startup more than 60 seconds while waiting for components. (@antsar - #7739)
- Always return rgb color of bulbs (@w1ll1am23 - #7743) (light.wink docs)
- Redesign monitored variables for hp_ilo sensor (@Juggels - #7534) (sensor.hp_ilo docs) (breaking change)
- Fix time_date sensor to update at predictable intervals (@stu-gott - #7644) (sensor.time_date docs)
- Added new commands and functionality to the harmony remote component. (@everix1992 - #7113) (remote docs) (remote.harmony docs) (remote.services.yaml docs)
- Exclude filter for event types (@amigian74 - #7627)
- Change setup script to use pip install instead of setup.py develop (@hoh - #7756)
- Add icons to device tracker. (@antsar - #7759)
- Rename of the zwave hass.data constants (@armills - #7768) (zwave docs) (cover.zwave docs) (lock.zwave docs)
- Get rid of mock http component app (@balloob - #7775)
- Remove usage of event_loop fixture (@balloob - #7776)
- assertEquals is deprecated (@balloob - #7777)
- Replace executor with async_add_job (@balloob - #7658)
- Fix Telegram Bot send file to multiple targets, snapshots of HA cameras, variable templating, digest auth (@azogue - #7771)
- Fix more deprecation warnings (@balloob - #7778)
- Powerview to async (@sander76 - #7682) (scene.hunterdouglas_powerview docs)
- Fix home/stay in concord232 (@CTLS - #7789) (alarm_control_panel.concord232 docs)
- Add Marantz SSDP discovery / Detect error string in AppCommand.xml body (@scarface-4711 - #7779) (media_player.denonavr docs)
- Upgrade Sphinx to 1.6.2 (@fabaff - #7805)
- Upgrade slacker to 0.9.50 (@fabaff - #7797) (notify.slack docs)
- Bump pyenvisalink to version 2.1 (@Cinntax - #7803) (envisalink docs)
- Upgrade pysnmp to 4.3.6 (@fabaff - #7806) (device_tracker.snmp docs) (sensor.snmp docs)
- Rest notify data (@Teagan42 - #7757) (notify.rest docs)
- Added handling of an AssertionError from pxssh failed login (@aronsky - #7750) (device_tracker.asuswrt docs)
- Upgrade sqlalchemy to 1.1.10 (@fabaff - #7807)
- Upgrade mypy to 0.511 (@fabaff - #7809)
- Allow configuring DSMR5 protocol. (@aequitas - #7535) (sensor.dsmr docs)
- Telegram send image: fix mimetype detection (@azogue - #7802)
- Bump aiohttp to 2.1.0 (@mezz64 - #7825)
- Cleanup telegram / Add url to webhook (@pvizeli - #7824) (telegram_bot.polling docs) (telegram_bot.webhooks docs) (breaking change)
- Upgrade pysnmp to 4.3.7 (@fabaff - #7828) (device_tracker.snmp docs) (sensor.snmp docs)
- Flux led fix (@danielhiversen - #7829) (light.flux_led docs)
- update snapcast media player (@happyleavesaoc - #7079) (media_player.services.yaml docs) (media_player.snapcast docs)
- Update docstrings and log messages (@fabaff - #7709)
- Upgrade PyMVGLive to 1.1.4 (@fabaff - #7832) (sensor.mvglive docs)
- Added persistent error message if cover.myq fails to load (@tchellomello - #7700) (cover.myq docs)
- Add initial benchmark framework (@balloob - #7827)
- Downgrade Docker to Python 3.5 to solve Segmentation Faults (@philhawthorne - #7799)
- Allow ‘base_url’ (fixes #7784) (@fabaff - #7796) (upnp docs)
- Expose the node name on the zwave node entity (@armills - #7787) (zwave docs)
- Bumped pyhomematic version (@danielperna84 - #7861) (homematic docs)
- Rename time trigger ‘after’ to ‘at’ (@armills - #7846) (automation.time docs) (breaking change)
- Use expected behvaior for above/below (@armills - #7857) (breaking change)
- log time delay of domain setup in info level (@azogue - #7808)
- Optimize history_stats efficiency and database usage (@bokub - #7858) (sensor.history_stats docs)
- don’t use default for switch name, so that the object id is used (@abmantis - #7845) (switch.broadlink docs) (breaking change)
- Disallow ambiguous color descriptors in the light.turn_on schema (@amelchio - #7765) (breaking change)
- Make monkey patch work in Python 3.6 (@balloob - #7848)
- fix permissions issue for Insteon Local #6558 (@wardcraigj - #7860) (insteon_local docs)
- Start of migration framework, to allow moving of files in the config … (@infamy - #7740) (ios docs) (notify.ios docs) (breaking change)
- Spotify aliases (@Teagan42 - #7702) (media_player.spotify docs)
- Query in InfluxDB sensor is now templatable (@titilambert - #7634) (sensor.influxdb docs)
- fix for https://github.com/home-assistant/home-assistant/issues/7019 (@molobrakos - #7618) (tellduslive docs)
- Check if media commands are actually applicable (@Juggels - #7595) (media_player.sonos docs)
- Quickfix Bug #7384 (@DavidLP - #7582) (media_player.spotify docs)
- Align switch group handling with light. (@aequitas - #7577) (switch.rflink docs)
- Update netdisco (@balloob - #7865)
- Fix telegram_bot (@balloob - #7877) (telegram_bot.polling docs) (telegram_bot.webhooks docs)
- [light.lifx] Update aiolifx (@amelchio - #7882) (light.lifx docs)
- Fix MQTT camera test (@balloob - #7878)
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2017/06/04/release-46/
