0.51: Did the one thing I wasn't suppose to do... Restarted HA during database upgrade
I saw the warning. Did the upgrade. Forgot about the warning. Restarted home assistant. smfh
Now HS is stating:
Invalid config
The following components and platforms could not be set up:
history
recorder
logbook
Please check your config
How can I resolve this?
If you were using the default database setup, try removing the homeassistant.sqlite file.
I have everything as default but I don’t see a homeassistant.sqlite file.
Fixed.
Renamed the .db files
Log been showing this for about an hour now - no change. “2017-08-13 09:50:34 INFO (Thread-7) [homeassistant.util.package] Attempting install of sqlalchemy==1.1.13”
@grantc - did you restart HA during the database upgrade too - or do you have a different problem that should have it’s own thread?
Hi, no, did not do anything - let it run for a good hour and still nothing, In the end just renamed the .db file and was all fine after. Cheers
Lol why do people keep hijacking threads. :roll_eyes:
Lol, settle petal
