So I read this in the change logs:
Breaking Changes
Previously, esphomelib would by default only publish every 15th sensor value in order to provide averaged values. However, that often confused users and I now decided to remove it and set the default update interval of all components to 60s instead of the previous 15s. You can get back the old behavior by setting
- platform: ... # enter platform here
# other settings
update_interval: 15s
filters:
- sliding_window_moving_average:
So I updated my config accordingly:
- platform: wifi_signal
name: "Master Bed Sensor WiFi Signal"
filters:
- platform: adc
pin: A0
name: "Master Bed Sensor"
filters:
- multiply: 3.25
Only now the configuration is invalid:
INFO Reading configuration...
Failed config
sensor.wifi_signal: [source /config/esphomeyaml/master_bed.yaml:31]
name: Master Bed Sensor WiFi Signal
filters: [source /config/esphomeyaml/master_bed.yaml:35]
- [source /config/esphomeyaml/master_bed.yaml:35]
expected a dictionary.
sensor.adc: [source /config/esphomeyaml/master_bed.yaml:37]
platform: adc
pin: A0
filters: [source /config/esphomeyaml/master_bed.yaml:42]
- multiply: 3.25
- [source /config/esphomeyaml/master_bed.yaml:43]
It seems what is actually required to get the original behaviour is this:
filters:
window_size: 15
send_every: 15
- platform: adc
pin: A0
filters:
- multiply: 3.25
window_size: 15
send_every: 15
Not only that but the invalid configuration actually uploaded and made the ESP unresponsive to OTA updates. It was only when I tried a "clean build’ that the error became apparent.
The sensor is connected to a strain gauge glued under one of my bed slats so this is going to be a F%&*ing PITA to get out to connect via USB.
