I am looking for solutions to turn off the water line to the toilet if the leak detecter under the toilet detects water. I am looking for something that is zigbee prefered. I have my leak detecters.
Anybody have any ideas on a zigbee auto shut off valve?
would something like this suit you?
https://vi.aliexpress.com/item/1005008492562351.html?
That would only work with a main shut off 1/4 turn. I am looking for something that will be at each toilet in the house. I need something that will either go inline or something that will turn this valve.
If plumbing and electrics is not your biggest passion, it’s more practical to have actuator on main valve. You can still have your house full of leak detectors.
My thinking was that the motor does a quarter turn and it should be a simple task to adapt the actuating arm for any ¼ turn task.
I expect it will be difficult to find an off the shelf solution for your exact taps.
Karosm’s advice may be your best bet.
So now I’m looking into taking the handle off the valve and using the step motor to make the turn. The only issue is finding a bracket that I can mount to either the wall or the pipe to keep the step motor in place. I will show pictures once I have it complete and test how it works out.
