1 Home Assistant Green, New Home
Hi! - I have a Home Assistant Green (awesome) and need to take it and install it at a now home.
Can I just shut it down, unplug it (power / ethernet) - take it to the new property and plug it in? and let it scan the network for devices (this is a new vacation property).
Or do I need to remove the ‘found’ devices from the system?
Or… (hopefully not) - do I need to wipe clean the Home Assistant Green (I’d have to buy a microSD card, reader, etc.)
thoughts? thanks! Chad
You can power it down and move it to the vacation home:
  • Remove devices that aren’t going with you. It won’t kill you to keep them in the system but you will likely get errors because they cannot be found
  • Make sure the new network will be the same as the old one, otherwise reconfigure your static IP address on the HA system (it really should be static)
