Here is my modified OneWire sensor.py file. Not sure if it’s the best quality code as python is not my thing.
"""Support for 1-Wire counter for a utility meter."""
# this is heavily modified to support DS2423 counters and the DS18S20 Temperature Sensors
# with the USB DS9490R one wire interface. If you use any other method this probably will need modifying.
# the DS2423 report the count at Kilo Watts as I use them on an electricity meter.
from glob import glob
import logging
import os
import time
import voluptuous as vol
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import (
TEMP_CELSIUS,
POWER_KILO_WATT,
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.entity import Entity
_LOGGER = logging.getLogger(__name__)
CONF_MOUNT_DIR = "mount_dir"
CONF_NAMES = "names"
CONF_COUNT_KW ="kwhrs_count"
DEFAULT_MOUNT_DIR = "/sys/bus/w1/devices/"
DEVICE_SENSORS = {
# Family : SensorType
"1d": "power",
"10": "temperature",
SENSOR_TYPES = {
# SensorType: [ Measured unit, Unit ]
"power": ["power", POWER_KILO_WATT],
"temperature": ["temperature", TEMP_CELSIUS],
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Optional(CONF_NAMES): {cv.string: cv.string},
vol.Optional(CONF_MOUNT_DIR, default=DEFAULT_MOUNT_DIR): cv.string,
vol.Optional(CONF_COUNT_KW, default=1000): cv.positive_int, #seems to be a standard that 1000 flashes = 1kWh
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the one wire Sensors."""
base_dir = config[CONF_MOUNT_DIR]
kw_count = config[CONF_COUNT_KW]
_LOGGER.debug("Initializing using %s", base_dir)
devs = []
device_names = {}
if CONF_NAMES in config:
if isinstance(config[CONF_NAMES], dict):
device_names = config[CONF_NAMES]
# We have a raw GPIO ow sensor on a Pi
for device_family in DEVICE_SENSORS:
for device_folder in glob(os.path.join(base_dir, f"{device_family}[.-]*")):
sensor_id = os.path.split(device_folder)[1]
device_file = os.path.join(device_folder, "w1_slave")
_LOGGER.debug("OneWire2 Found Dev %s",sensor_id)
_LOGGER.debug("OneWire def family -> %s,debug1-> %s",device_family,DEVICE_SENSORS.get(device_family))
devs.append(
OneWire2Direct(
device_names.get(sensor_id, sensor_id),
device_file,
DEVICE_SENSORS.get(device_family),
kw_count,
if devs == []:
_LOGGER.error(
"No onewire sensor found. Check if dtoverlay=w1-gpio "
"is in your /boot/config.txt. "
"or the DS9490R USB interface is connected"
return
else:
_LOGGER.debug("OneWire2 devices %s",devs)
add_entities(devs, True)
class OneWire2(Entity):
"""Implementation of an One wire Sensor."""
def __init__(self, name, device_file, sensor_type,kw_count):
"""Initialize the sensor."""
self._name = f"{name} {sensor_type.capitalize()}"
self._device_file = device_file
self._unit_of_measurement = SENSOR_TYPES[sensor_type][1]
self._state = None
self._value_raw = None
self._kw_count = kw_count
def _read_value_raw(self):
"""Read the value as it is returned by the sensor."""
with open(self._device_file) as ds_device_file:
lines = ds_device_file.readlines()
return lines
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def state(self):
"""Return the state of the sensor."""
return float(self._state / self._kw_count)
@property
def unit_of_measurement(self):
"""Return the unit the value is expressed in."""
return self._unit_of_measurement
@property
def device_state_attributes(self):
"""Return the state attributes of the sensor."""
return {"device_file": self._device_file, "raw_value": self._value_raw}
@property
def unique_id(self) -> str:
"""Return a unique ID."""
return self._device_file
class OneWire2Direct(OneWire2):
"""Implementation of an One wire Sensor directly connected to RPI GPIO."""
def update(self):
"""Get the latest data from the device."""
value = None
lines = self._read_value_raw()
if self.unit_of_measurement == POWER_KILO_WATT:
equals_pos = lines[2].find("YES c=")
if equals_pos != -1:
value_string = lines[2][equals_pos + 6 :]
value = int(value_string)
self._value_raw = int(value_string)
self._state = value
else:
while lines[0].strip()[-3:] != "YES":
time.sleep(0.2)
equals_pos = lines[1].find("t=")
value_string = lines[1][equals_pos + 2 :]
value = round(float(value_string) / 1000.0, 1)
self._value_raw = float(value_string)
self._state = value
I placed the code in \config\custom_components\onewire2
with __init__.py
and manifest.json
from the original one wire installation. The code for the original I got from github at https://github.com/home-assistant/core/tree/dev/homeassistant/components/onewire
My configuration.yaml now has the following to use this custom component
- platform: onewire2
kwhrs_count: 1
The kwhrs_count entry is to scale the kWh reading. Most electricity meters have 1000 led flashes = 1kWh. I put the scalling in the sensors.py but decided to do the scalling when reading the data from the database instead.
Hope fully this concludes this episode and I hope this helps out someone in the future.
Next project is integrating a current transformer to measure AC power.
