Check two PRs of dcapslock which broke styles for entities card. Changing Frontend in favor of card-mod…
Why not provide urls to these " Resentful " accusations , i mean that is your point , right … provide a solution/cause to the " Issue "
Why not opening pull requests on GitHub and filter?
Don’t find those PRs in the repo.
https://github.com/iantrich/config-template-card/pulls
Can you gibe more details?
In ha frontend repo.
He proposed changes for padding-top which caused its removal under some conditions. And it mainly touched when Entities card was wrapped into another card.
Hm. But then I cannot see a help for me, only the reason, can I? That there was a change, I saw it. I search for help to fix it in this card. If there were a PN in the repo of the this card, I would appriciate much, because I would be able to adapt without a release. But changes in frontend, no, I cannot fix it.
For now, you will have to use cardmod. I may propose a fix in ha frontend - but I very doubt that I can explain it by “custom card does not work”. Need to figure out a way of another fix…
But thanks for the hint. As this is the only card in my HA, then I will modify the card source to bring back fixed padding top and then it is working without card-mod.
Arganto, can you check if other cases are affected?
Restriction card, tabbed-card, stack-in-card.
For restriction card I don’t see problems in my dashboards. Tabbed card not in use. Stack in card neither. Still using a modified vertical-stack-in-card.
The padding top is missing only when the Entities card has no title. Will check again how to mitigate this. The initial PR was definitely not thoroughly reviewed.
Btw, meanwhile there is a workaround for you.
Use CTC for a ROW.
Also, Arganto, can you check with card-mod 3.x?
What to check? If it is a frontend change problem. Ofc I would be able to set the padding, but I don’t want this. Will try via row.
It could be related to “card_mod” element automatically prepended. A need to place this element in the beginning of DOM structure was a reason why those mentioned PRs were issued. That is why I suggested you to check with 3.x. I could do it myself, I am just away from a PC, that is why I am asking you, sorry!
I am not replicating this. Can you see if clearing Frontend cache helps?
For transparency for this discussion, the 2 PRs referred to are Fix ha-card styling of .card-content when not first element but not following .card-header by dcapslock · Pull Request #28935 · home-assistant/frontend · GitHub and Fix CSS minification issue for ha-card by dcapslock · Pull Request #29354 · home-assistant/frontend · GitHub, the 2nd PR being required due to a CSS minification bug with the CSS minification tool being used by Home Assistant.
The first PR updates the CSS for ha-card such that the .card-content class only sets no top padding and negative margin when it is not the first element of .card-content or .card-header. Before this it was setting if not first child, giving rise to an issue if any other element made its way into DOM, card-mod auto prepend or otherwise.
What you show suggests that its a combination of card-mod 4.2.x and old frontend CSS for ha-card being used, which is not expected, hence the request to clear Frontend cache.
If there is any issue with Frontend PRs submitted by myself, I will provide follow up and resolution if required. Case in point being the 2nd PR being a third party tooling bug which took many hours to uncover and which I expidited prior to final release of 2026.2.0.
No, it is not a cache topic: HA 2026.1.3 with card-mod 4.2.1
But I changed now to ROW-approach and this solved to problem. Thanks again Ildar for the hint.
Confirming you are running 2026.1.3?. Card-mod 4.2.0+ requires Home Assistant 2026.2.0 or above for 2 reasons. 1) Specifically this issue so the updated ha-card CSS is used and 2) For yaml theme loading due to the developer tools route change.
Yes. As discussed in the other topic. HACS did the update without a blocking.
But as said. Solved with row-option and currently I’m in that way blocked, that I cannnot test other approaches. But thanks again for your help as well.
Thank you for confirming as it explains why you were having the padding issue.
