must be missing the obvious,
but what is wrong in:
## https://home-assistant.io/components/sensor.systemmonitor/
- platform: systemmonitor
resources:
- type: disk_use
arg: /home
- type: disk_use_percent
arg: /home
- type: disk_free
arg: /home
- type: network_in
arg: eth0
- type: network_out
arg: eth0
- type: packets_in
arg: eth0
- type: packets_out
arg: eth0
- type: load_1m
- type: load_5m
- type: load_15m
- type: processor_use
- type: memory_free
- type: memory_use_percent
- type: memory_use
- type: swap_use_percent
- type: swap_use
- type: swap_free
- type: last_boot
- type: ipv4_address
arg: eth0
when it says this https://rc.home-assistant.io/blog/2020/09/29/release-116/#breaking-changes for the changes?
I get this in the log:
Mandatory 'arg' is missing for sensor type 'swap_free'. for dictionary value @ data['resources'].
but in the docs, there’s no mandatory arg??
this is probably the bug…
"swap_free": ["Swap free", DATA_MEBIBYTES, "mdi:harddisk", None, True],
