"176553 (unsupported) (tg43aAXlWMBBqL3T)" (Tuya)
I connected a Hama Wifi Door-/Window-Contact but in Home Assistant it shows 176553 (unsupported) (tg43aAXlWMBBqL3T)
Is ther a way to fix it?
The Diagnostik is here:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2025.4.1”,
“dev”: false,
“home assistant OS”: true,
“virtualenv”: false,
“python_version”: “3.13.2”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “Europe/Berlin”,
“os_name”: “Linux”,
“os_version”: “6.12.20-haos”,
“supervisor”: “2025.03.4”,
“host_os”: “Home Assistant OS 15.1”,
“docker_version”: “28.0.4”,
“chassis”: “vm”,
“run_as_root”: true
“custom_components”: {},
“integration_manifest”: {
“domain”: “tuya”,
“name”: “Tuya”,
“codeowners”: [
“Tuya”,
“zlinoliver”
“config_flow”: true,
“dependencies”: [
“ffmpeg”
“dhcp”: [
“macaddress”: “105A17*”
“macaddress”: “10D561*”
“macaddress”: “1869D8*”
“macaddress”: “381F8D*”
“macaddress”: “508A06*”
“macaddress”: “68572D*”
“macaddress”: “708976*”
“macaddress”: “7CF666*”
“macaddress”: “84E342*”
“macaddress”: “D4A651*”
“macaddress”: “D81F12*”
“documentation”: “Tuya - Home Assistant”,
“integration_type”: “hub”,
“iot_class”: “cloud_push”,
“loggers”: [
“tuya_iot”
“requirements”: [
“tuya-device-sharing-sdk==0.2.1”
“is_built_in”: true,
“overwrites_built_in”: false
“setup_times”: {
“null”: {
“setup”: 2.312099968548864e-05
“01JQVFQX4XHG5H8AETK2TMXT1H”: {
“wait_import_platforms”: -2.7152418129999205,
“wait_base_component”: -0.0006498650000139605,
“config_entry_setup”: 6.211220920999949
“data”: {
“endpoint”: “https://apigw.tuyaeu.com”,
“terminal_id”: “1743605462001r4dzvO”,
“mqtt_connected”: true,
“disabled_by”: null,
“disabled_polling”: false,
“id”: “00806020a4cf12a41c68”,
“name”: “Fenster Rechts Hannes”,
“category”: “qt”,
“product_id”: “tg43aAXlWMBBqL3T”,
“product_name”: “176553”,
“online”: true,
“sub”: false,
“time_zone”: “+01:00”,
“active_time”: “2025-04-09T18:30:12+00:00”,
“create_time”: “2025-04-09T18:30:12+00:00”,
“update_time”: “2025-04-09T18:30:12+00:00”,
“function”: {},
“status_range”: {},
“status”: {},
“home_assistant”: {
“name_by_user”: null,
“disabled”: false,
“entities”:
“set_up”: false,
“support_local”: true
https://www.home-assistant.io/integrations/zha/#how-to-add-support-for-new-and-unsupported-devices
Have you found a solution in the meantime? I have exactly the same problem.
