I am running Jeedom today and will probably move to Home Assistant.
I have plenty of 1wire stuff and want to continue to use it.
2 Raspberry running OWFS with around 25 devices on total, temp and relays mainly.
I get it working straight forward with OWFS HA integration, but several devices do not appear in HA.
They are present on OWFS and can be switched on/off
Old ones like DS2405. Is the a way to edit something to add it ?
Thanks in advance !
PS: no 1wire tag available in the forum, perhaps this can be added
DS2405 works a bit differently, as PIO change mode from ON to OFF or OFF to ON.
And sensed value is 1 for status OFF and 0 for Status On
So code needs a bit more change to handle ON/OFF commands, looking first for sensed value, then sending 1 to PIO or not.
Sensed value need probably to be added in sensor.py. I need to look closer at all that.
Brand new in HA and not so much time available so I will need some time to figure that
But that’s part of fun
Hi, 1wire is working perfecly on HA for all that time on my HA, stable.
Just uses OWFS integration and it’s fine.
On my side I used 2 raspberry with USB Controler DS9490R to avoid too long wire, OWFS installed locally on each Raspberry (didtn used 1wire native controller on raspberry as I already had the 2x DS9490R…)
But honestly, I have less and less 1wire, using now Zigbee with sonoff USB adpater + Zigbee2MQTT, and its perfect for T°, Relays, Switch, door, radar…
thank you for your fast answer! Sorry for my bad english!
On my Raspi i used in a former installation without Homeassistant the temperature sensors DS18B20!
Now i use the complete image from Homeassistant - I allready installed owfs - but I think the gpio inputs are not yet activated - no 1wire sensors appearing?
i am new here
have fhem since 7 years
with some 1wire temperature sensosrs
looking for information how to integrate it in HA.
i am windows user and Linux i a total different world for me
like this it is in my fhem integration:
my HA system is running on a Intel nuc
docker
my Fritzbox works perfect also my Heishamon,
homeatic will work with HA as i have seen, if i have done the 1wire, i will take all homematic too.
what have i to do, to install owserver on my Nuc
as easy as the heishamon integration ?
would be great to get an answer here
or directly to my email Franz at tenbrock point de
