2 devices 1 ApI encryption code
So i made a booboo. In my haste to configure a second bulb off another’s custom yaml, I copied over the API encryption code and jacked up both bulbs. Is there anyway to fix this without ripping the bulbs and reflashing the bulb by serial??
Do you mean you don’t know the API encryption key? The same key can be used for multiple devices.
You don’t have the web server enabled?
