2 MQTT and alarmo
Hi
I try to install alarmo
I see the capters which ares in the first MQTT instance , but i did’nt see and install capteurs which ares in the second MQTT instance /netword
Is a limitation or should i do something for alarmo to manage two Z2M ?
If you have 2 Zigbee2MQTT networks, both should use the same MQTT broker. And they should use another MQTT topic.
