2 services in an automation
I’m trying to add both services to an automation but for some reason it’s not working… I’ve tried adding a delay in between them but it only ever fires the 1st service and never the second… I’m thinking it should be possible but haven’t even found a working example and no matter what I’ve tried it’s a no go…
Anyone doing this also? If so how did you get it to work? I currently have it rem’ed out because it’s not working anyway…
Thank you!!
- alias: 26 - All Doors and Windows
  id: 26 - All Doors and Windows
    - platform: state
      entity_id: device_tracker.john_s_z_fold3
      to: "not_home"
  condition:
    - condition: state
      entity_id: group.all_doors
      state: "on"
    - service: notify.mobile_app_sm_f926u1
        message: "TTS"
        title: "Attention! The following doors or windows are open.   {{ expand('group.all_doors') | selectattr('state','eq','on') | map(attribute='name') | list | join(', ') }}"
          channel: alarm_stream_max
          ttl: 0
          priority: high
    #- delay: "00:00:15"
    #- service: media_player.volume_set
    #  data:
    #    volume_level: 0.59
    #  target:
    #    entity_id: media_player.sonos_five
    #- service: tts.cloud_say
    #  data:
    #    channel: alarm_stream_max
    #    ttl: 0
    #    priority: high
    #    title: "Attention! The following doors or windows are open.   {{ expand('group.all_doors') | selectattr('state','eq','on') | map(attribute='name') | list | join(', ') }}"
I know the second service works as I use it in another automation…and will work if I rem the 1st one out…
