Hey everyone,
I ran “Check Home Assistant configuration” before updating from 2021.7.4 to 2021.8.1.
It gives me the following error and I cant find any reference to it:
[12:08:14] INFO: Installed Home Assistant 2021.8.1
[12:08:14] INFO: Making a copy of your configuration for checking...
[12:08:14] INFO: Checking your configuration against this version...
[12:11:20] ERROR: The configuration check did not pass!
[12:11:20] ERROR: See the output below for more details.
Testing configuration at /tmp/config
grep: write error: Broken pipe
ERROR:homeassistant.config:Invalid config for [automation]: Integration 'zha' not found (See ?, line ?).
File "/usr/local/lib/python3.9/site-packages/homeassistant/components/device_automation/__init__.py", line 84, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/local/lib/python3.9/site-packages/homeassistant/requirements.py", line 76, in async_get_integration_with_requirements
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration 'zha' not found.
File "/usr/local/lib/python3.9/site-packages/homeassistant/components/automation/config.py", line 104, in _try_async_validate_config_item
config = await async_validate_config_item(hass, config, full_config)
File "/usr/local/lib/python3.9/site-packages/homeassistant/components/automation/config.py", line 72, in async_validate_config_item
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting
What do I do? should I upgrade or wait for a fix?
