2022.8: You can fix it!
Great release team!!
Out of curiosity if anyone is able to answer it:
With a potential future integration build, could it be possible for a raspberry 4 with Hass to act as a bridge for a Nuki smart lock? Or acting as a bridge is not the intended use here?
Looking forward to hear any expert opinions :slight_smile:
Cheers!
def the repairs my watchman report is like war and peace !
most of it due to "key master "
any chance of a good zwave lock integration ?
In what way?
Ahh yeah I forgot about the other integration
 and since we’re talking about it, if ever tried the musicCast one, how does the 2 compare each other? Are there any benefits using the Network rather than the MusicCast ?
Hi, is it just me that does not get the update notification on my install? First time in years this has happened.
They have that already. Your don’t have to take every core update.
waited a bit, but now I read the release notes again on the homeassistant_alerts feeding relevant alerts from https://alerts.home-assistant.io to the new repairs menu item, shouldn’t I be seeing the oldest one on the list there, on Dark sky, given the fact I have that installed?
Maybe it’s not that pressing, but hey, just for testing purposes I wonder why its not displayed, and I have nothing to fix.
Not using default: but having that integration listed in the configuration.yaml
I mean on one hand I have many integrations / 200 devices and I got on at the first beta, no issues for me everything was happy.
On the other hand, if you “just want a stable system” then why did you update already? It’s not like there’s anything making you update at all.
Mi Home advert has annoying 1 decimal for humidity, which I am not sure can be changed in the entity definition.
And since I use it e.g. in the picture_elements cards I prefer it in rounded (as ATC advertising does, who really needs this digit here not to mention its reliability
I know I can probably use a template entity just for this, exclude the original entity from recorder etc, but It was such a drag (and considering I have 5 of these devices) it was easier to go with ATC :stuck_out_tongue:
Didn’t realise you could do that, can’t see it in the docs/app but all my other sensors (Aqara mostly) have 1 decimal place as well (in fact some have 2). I guess you’ll have to wait until the ATC advertising is working with HA.
EDIT: just found in Z2M I can change the number of dec places
Can you ping the camera? (Is it connecting to WiFi?)
Hi Yes, I can also view it on the Hikvision DVR, camera is hard wired POE.
I have even gone as far as removing the Amcrest Integration (in yaml) still the same?
Same here RM 4 PRO, tried reloading as others have said but doesn’t fix it for me
Every time you restart home assistant you must reload broadlink integration to be working again
Well, that sucks.
Luckily not here: The Broadlink Integration works just fine here on 22.0.x with 12 Broadlink RM4 RM4c minis. No hiccups at all after coming from 2022.7.
I have the exact same issue, can’t find any answers on the forums. Same “404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2022.8.1/json” every time
@chriselera
Turns out it was a storage space issue for me, the logs just don’t make that clear at all. I logged in over SSH and tried manually pulling the image, and got a much more specific error about not having enough free space on the drive.
Logged into ESXi, turned the VM off, increased the VMDK size, and booted back up and the update worked via the UI. Hope this helps you too!
Nice! Should be fixed in 2022.8.2 :+1:
Custom addons have to keep up with supervisor, not the other way around.
Hum
 I’ve got 2 identical model of Xiaomi BLE sensors, should be pretty common as you can buy them in groups.
How do I tell which is which when trying to enter encryption keys? it feels rather stupid that it’s not showing MAC addresses for it.
–edit: wrong key’s aren’t accepted. So just try all the keys until one is accepted.
Also, how do I retrieve the encryption key for future use?? Thanks to Passive BLE monitor which shows encryption key so I was able to easily retrieve it.
