@bdraco Any possibility of support for Bluetooth buttons e.g Itag
these come in various sizes and shapes
This was discussed in ESPhome discord too, now since HA has got its own first-class support, will it be supported in HA too?
But if I havenât overridden the name manually in the registry do the names/entity_idâs there get altered?
Thatâs the biggest questionâŚwill the new naming schema change things not manually defined in .storage retroactively or only implement the new naming going forward?
The other stuff could be an annoyance depending on how itâs ultimately handled but if that will be what happens then that is just unacceptable.
We need to know the format of the additional authorization data and where to get it. Unfortunately itâs manufacturer specific.
Itâs possible but someone would need to make an integration for it
How is Home Assistant installed? If it is on an RPi odds are it is linux based
I had zero name changes on any entity. Why donât you try it instead of guessing.
iâm seeing the same issue after upgrading to 2022.8.1
were you able to find a fix for ONVIF?
Couldnât connect to camera âxâ, please verify that the credentials are correct. Error: Invalid data
Latest is not a version.
Anyone know if something like this would work? I donât have this but this is what I need.
Would it be possible for the new Bluetooth integration to use a remote dongle exposing dubs via socat or similar?
Asking because all my antennas are remote with respect to the ha server and located on a raspberry pi at home center .
Would like to add bt too there.
I think it is not so uncommon setup
No joy,
I have two cameras, both POE 1 is Reolink and works fine but not the Amcrest, strange
Since lastest (2022.8.1) version I receive following bluetooth error:
Logger: homeassistant.components.bluetooth_tracker.device_tracker
Source: components/bluetooth_tracker/device_tracker.py:73
Integration: bluetooth_tracker
First occurred: 07:38:17 (362 occurrences)
Last logged: 09:03:56
Couldn't discover bluetooth devices: error communicating with local bluetooth adapter
Does your HA machine have bluetooth?
Thanks for another great release.
Perhaps a little change to the blog text may clarify the repairs topic.
It says the repairs item is in the settings menu, but when looking there, I could not find it.
It turns out it is further down in the system menu.
The repairs dashboard can be found in the settings**/system** menu
Yes, Pi 3 B, it did discover bluetooth devices before.
Yes it is on a rpi 4 with HassOS so you are right. Didnât think about that. Thsnk you!
The Bluetooth device tracker has not been updated to use the new Bluetooth stack. The le one has
Having the same error running speedtest cli
First off, asking questions isnât guessing. itâs asking questions. Big difference.
Besides, I didnât think it was a part of this release so I didnât know it was available to âtry itâ:
In the background, a project has been started to standardize the names of entities and devices. This work is in progress and will take a long time to complete,
And if it is a part of the release I havenât updated yet. The .x number is too low.
Switchbot integration is still broken for me, even after updating to 2022.8.2. Devices are found, but cannot control them:
Switchbot communication failed. Stopping trying
File "/usr/local/lib/python3.10/site-packages/bleak_retry_connector/__init__.py", line 102, in establish_connection
await client.connect(timeout=BLEAK_TIMEOUT)
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/client.py", line 167, in connect
assert_reply(reply)
File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/utils.py", line 22, in assert_reply
raise BleakDBusError(reply.error_name, reply.body)
bleak.exc.BleakDBusError: [org.freedesktop.DBus.Error.UnknownObject] Method "Connect" with signature "" on interface "org.bluez.Device1" doesn't exist
File "/usr/local/lib/python3.10/site-packages/switchbot/devices/device.py", line 81, in _sendcommand
return await self._send_command_locked(key, command)
File "/usr/local/lib/python3.10/site-packages/switchbot/devices/device.py", line 104, in _send_command_locked
client = await establish_connection(
File "/usr/local/lib/python3.10/site-packages/bleak_retry_connector/__init__.py", line 134, in establish_connection
_raise_if_needed(name, exc)
File "/usr/local/lib/python3.10/site-packages/bleak_retry_connector/__init__.py", line 95, in _raise_if_needed
raise BleakConnectionError(msg) from exc
bleak_retry_connector.BleakConnectionError: C4-2B-D3-F8-7D-AE (C4:2B:D3:F8:7D:AE): Failed to connect: [org.freedesktop.DBus.Error.UnknownObject] Method "Connect" with signature "" on interface "org.bluez.Device1" doesn't exist
