2024.1: Happy automating!
My system monitor has now 430 entities. 14 that i use and 416 inactive.
I will try your suggestion to remove and install again the integration.
What i miss, is setting the scan-interval via the ui like in yaml before.
- platform: systemmonitor
  scan_interval:
    seconds: 301
Edit: done, system monitor entities decreased to 174
Some really good additions, but not a fan of the new automation editor. Appreciate it needs to be made easier for new users, but the building blocks provides necessary division. Have everything under a single menu please to avoid additional clicks!
I am back up and running after a few weeks with hassle on the thermostat card and the Sonoff integration but as it seems everything is back as I like to have it and stable! Thanks and well done guys!!
Crap i didn’t made a backup before updating, 10 Shelly are dead
 :cry:
just ‘update’ back to 2024.1.0 via the terminal
Thank you, i didn’t know those commands.
did you have updated your shelly devices firmware ?
on my side, half of my shelly are broken ( even updated with last firmware )
It was mentioned in the bug ticket by the developers it depends on the timing the Gen1 devices were added to HA.
If after the support to Gen2 was introduced they will work, if before they won’t (it’s because of a ‘gen’ param that was added and is being stored and was missing before that moment).
I see a PR is being approved to fix this.
Integration has been fixed. Update sonoff in HACS
Weird how being critical of this release gets your comments removed.
I spoke with frustration yes and I apologies for that, but with the amount is issues arose with this release breaking major things, did I say anything wrong.
Yes, some issues are fixed now, but compatibility fixes should’ve been released at beta stage, not after a public release.
Since 2024.1.1: :expressionless:
Something really screwed up my installation :woozy_face:
Invalid config
The following integrations and platforms could not be set up:
Please check your config and logs.
17 seconden geleden
Logger: homeassistant.setup
Source: setup.py:403
First occurred: 00:32:28 (16 occurrences)
Last logged: 00:33:03
Unable to prepare setup for platform 'template.sensor': Unable to set up component.
Unable to prepare setup for platform 'buienradar.sensor': Platform not found (cannot import name 'vincenty' from 'vincenty' (/usr/local/lib/python3.11/site-packages/vincenty/__init__.py)).
Unable to prepare setup for platform 'buienradar.weather': Platform not found (cannot import name 'vincenty' from 'vincenty' (/usr/local/lib/python3.11/site-packages/vincenty/__init__.py)).
Unable to prepare setup for platform 'template.switch': Unable to set up component.
Source: setup.py:221
First occurred: 00:32:28 (1 occurrences)
Last logged: 00:32:28
Setup failed for 'template': Invalid config.
Source: setup.py:251
First occurred: 00:33:03 (2 occurrences)
Last logged: 00:33:10
Setup failed for 'conversation': Unable to import component: cannot import name 'RbnfEngine' from 'unicode_rbnf' (/usr/local/lib/python3.11/site-packages/unicode_rbnf/__init__.py)
Setup failed for 'mobile_app': Unable to import component: cannot import name 'RbnfEngine' from 'unicode_rbnf' (/usr/local/lib/python3.11/site-packages/unicode_rbnf/__init__.py)
And much more errors
 Anyone else got issues like this?
Everything worked just before updating
Well, it think there was a glitch in the matrix/rpi4/ssd drrive going to die(?)
 restored a backup
 updated again to latest and everything is fine.
In other words
 backups are the key :joy::+1::ok_hand:
What can I say, sorry, my fault
No need to apologise @Bieniu
Debugging can only confirm no bug was detected (or the identified ones were fixed), not that there is no bug.
I see a PR is already being approved to fix this. :wink:
Also broken here. Will have a closer look and create an issue on GitHub.
After an upgrade from 2023.12.4 directly to 2024.1.1 my Shelly integration reports some issues. I have not found any information about breaking changes regarding to Shelly integration in the release notes.
All my Shelly devices have the latest firmware available and are accessible in the local network as usual.
What happened and how to fix that?
I have same issue when updating from 2024.1.0 to 2024.1.1
Same issue here
Same here, Homematic IP HACS integration was failing with error “not loaded” and exception “Unexpected exception importing component custom_components.homematicip_local”, update of Homematic solved it. I was unable to restore 2023.12.3 from 2024.1.1
The update went smooth with no issues. Impressed by the ease to remove the systemmonitor from config. I was prepared that my entities would have new id’s, but no.
Thanks to the devs!
Please consider to install the update 1.52.0 that is available for 2 weeks now.
