2025.12 template change issues
I have previously used very simple template to calculate so called heating number, which I use for certain energy related optimizations. However, 2025.12 version of Home Assistant changed the way statistics are collected and saved, and changes were made to templates too, if I have understood it correctly.
The code below output float before 2025.12. After 2025.12, it outputs string and messes rest of template, because one can’t perform math operations with strings, which is logical:
{% set temp_ave = states('sensor.24h_average_outdoor_temp') | default(0) | float %}
sensor.24h_average_outdoor_temp likely to float, because it’s source is HomeAssistant’s builtin Filter (moving average), which in turn receives temp from my EcoWitt weather staion in float/measurement form.
I have tried to study how to correct the code line above to work with current versions. I have tried float/default commands in different order in dev tools, only result being different errors. This is propably very simple thing to fix, but I just don’t know, how to change that line of code. Any help is greatly appreciated!
EDIT
complete template below, as well as error:
      {% if now().month <= 6 and states('sensor.24h_average_outdoor_temp') | float >= 10 %}
        0
      {% elif now().month <= 6 and states('sensor.24h_average_outdoor_tempa') | float < 10 %}
        {{ 17 - temp_ave }}
      {% elif now().month >= 7 and states('sensor.24h_average_outdoor_temp') | float >= 12 %}
        0
      {% else %}
        {{ 17 - temp_ave }}
      {% endif %}
produces error:
ValueError: Template error: float got invalid input ‘unknown’ when rendering template ‘{% if now().month <= 6 and states(‘sensor.24h_average_outdoor_temp’) | float >= 10 %} 0 {% elif now().month <= 6 and states(‘sensor.24h_average_outdoor_tempa’) | float < 10 %} {{ 17 - temp_ave }} {% elif now().month >= 7 and states(‘sensor.24h_average_outdoor_temp’) | float >= 12 %} 0 {% else %} {{ 17 - temp_ave }} {% endif %}’ but no default was specified
What exactly are the error messages that you’re getting? I tried this with your template and |typeof returned float, so it should be working with any valid numeric string.
{% set temp_ave = '21.5' | default(0) | float %}
{{ temp_ave|typeof }}
It would be more helpful if you shared the whole template/config that is having issues rather than a single line.
There’s nothing particularly wrong with the template you shared, but it would be better to use the default option in the float filter…
{% set temp_ave = states('sensor.24h_average_outdoor_temp') | float(0) %}
Is that a typo, the others don’t have an “a” at the end…?
If it is, you could reduce your template quite a bit and make it a little bit more efficient using a couple variables:
{% set 24h_avg = states('sensor.24h_average_outdoor_temp') | float(0) %}
{% set month = now().month %}
{% if (month <= 6 and 24h_avg >= 10) or (month >= 7 and 24h_avg >= 12) %}
  0
{% else %}
  {{ 17 - temp_ave }}
{% endif %}
There was a typo too, but at the end, float(0) instead of float did the trick!
FYI, float with a default has been a requirement for almost 3 years now. Not sure how you’re just getting this error now.
My issue seems related but also has been resolved. I just want to share the issue/fix.
I had multiple templates comparing 2 temperatures. This worked fine until recently and might have been broken by the 2025.12 update (I didn’t have an opportunity to look at it earlier).
The template used to look like this (used to work until it didn’t):
{{ states('sensor.floor_surface_thermostat_temperature_2') + 1.0 | float(0) <
states('input_number.floor_surface_temperature_setting') | float(0) }}
I changed it to (works just fine):
 {{ float(states('sensor.floor_surface_thermostat_temperature_2')) + 1.0 | float(0) <
 float(states('input_number.floor_surface_temperature_setting')) | float(0) }}
There are two possibilities: either there was a change in the Home Assistant handling the code, or I have had a major brain glitch, and I changed the templates to the wrong coding. Both are equally likely :grimacing:
Bye,
Rudi
Yeah, that first template should have never worked because you’re attempting to add a number with a string.
The | float(0) is doing nothing because it’s attached to the 1.0 which is already a float.
FYI your template should be:
{{ states('sensor.floor_surface_thermostat_temperature_2') | float(0) + 1.0 <
