Thank you for the suggestion @CaptTom
After having a failed restore from backup, I tried to get this corrupt file off the server but it had vanished!
I am also getting errors when trying to restore the backup
It seems to be complaining that it cannot remove /data/homeassistant/tts
I’ve never use text to speech on this install so I will try removing that directory manually and running the restore again
2025-03-06 20:36:41.923 INFO (MainThread) [supervisor.backups.manager] Partial-Restore 5bdd9a0e start
2025-03-06 20:36:42.717 INFO (MainThread) [supervisor.backups.manager] Restore 5bdd9a0e starting stage folders
2025-03-06 20:36:42.723 INFO (SyncWorker_4) [supervisor.backups.backup] Restore folder ssl
2025-03-06 20:36:42.728 INFO (SyncWorker_4) [supervisor.backups.backup] Restore folder ssl done
2025-03-06 20:36:42.728 INFO (MainThread) [supervisor.backups.manager] Restore 5bdd9a0e starting stage home_assistant
2025-03-06 20:36:42.736 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant application
2025-03-06 20:36:42.903 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for a0d7b954_vscode closed
2025-03-06 20:36:43.691 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from a0d7b954_ssh
2025-03-06 20:36:49.751 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant application
2025-03-06 20:36:52.160 INFO (SyncWorker_0) [supervisor.homeassistant.module] Restore Home Assistant Core config folder
2025-03-06 20:36:52.271 CRITICAL (SyncWorker_0) [supervisor.utils] Can't remove folder /data/homeassistant: find: ‘/data/homeassistant/tts’: Bad message
find: cannot delete ‘/data/homeassistant/tts’: Bad message
find: cannot delete ‘/data/homeassistant’: Directory not empty
2025-03-06 20:36:54.616 ERROR (SyncWorker_0) [supervisor.homeassistant.module] Can't restore origin data: [('/data/tmp/tmpgi7omal9/data/tts', '/data/homeassistant/tts', "[Errno 74] Bad message: '/data/homeassistant/tts'")]
2025-03-06 20:36:54.710 ERROR (MainThread) [supervisor.backups.manager] Restore 5bdd9a0e error
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 497, in _restore_home_assistant
shutil.copytree(
temp_data,
...<2 lines>...
dirs_exist_ok=True,
File "/usr/local/lib/python3.13/shutil.py", line 593, in copytree
return _copytree(entries=entries, src=src, dst=dst, symlinks=symlinks,
ignore=ignore, copy_function=copy_function,
ignore_dangling_symlinks=ignore_dangling_symlinks,
dirs_exist_ok=dirs_exist_ok)
File "/usr/local/lib/python3.13/shutil.py", line 547, in _copytree
raise Error(errors)
shutil.Error: [('/data/tmp/tmpgi7omal9/data/tts', '/data/homeassistant/tts', "[Errno 74] Bad message: '/data/homeassistant/tts'")]
File "/usr/src/supervisor/supervisor/backups/manager.py", line 697, in _do_restore
task_hass = await backup.restore_homeassistant()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 312, in wrapper
raise err
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 304, in wrapper
return await self._method(obj, *args, **kwargs)
File "/usr/src/supervisor/supervisor/backups/backup.py", line 864, in restore_homeassistant
await self.sys_homeassistant.restore(
homeassistant_file, self.homeassistant_exclude_database
raise err
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 522, in restore
data = await self.sys_run_in_executor(_restore_home_assistant)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 504, in _restore_home_assistant
raise HomeAssistantError(
f"Can't restore origin data: {err}", _LOGGER.error
) from err
supervisor.exceptions.HomeAssistantError: Can't restore origin data: [('/data/tmp/tmpgi7omal9/data/tts', '/data/homeassistant/tts', "[Errno 74] Bad message: '/data/homeassistant/tts'")]
2025-03-06 20:36:54.735 INFO (MainThread) [supervisor.backups.manager] Restore 5bdd9a0e starting stage await_home_assistant_restart
2025-03-06 20:36:54.749 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-03-06 20:36:55.145 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version 2025.2.4
2025-03-06 20:36:55.146 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-03-06 20:36:59.257 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state freeze
2025-03-06 20:36:59.257 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-06 20:37:00.150 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-03-06 20:37:04.139 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from a0d7b954_ssh
