[2025.5.x Bug - Fibaro Hub Integration] All devices moved its entities as separate
Hi2UAll!
When updated to 2025.5.x the Fibaro Hub Integration all devices moved its entities as a separate entity!
Seems like the Fibaro Hub Integration Master devices are discoupled the slave entities some how. It was working before updating to 2025.5.
This has, for me using a HC2 (old) Fibaro Hub, a big impact on the Energy visualisation and entity location (room) assignment.
Please help!
Hello Domoticon,
If you believe you have found a bug, check here and add if it is new or thumbs up if you also are seeing it…
FYI, an issue is reported:
Just want to share the progress of this issue. I got in contact of the very helpful code owner and it seems to be a dedicated HC2 user account does not have enough rights to get the id 1 (com.fibaro.zwavePrimaryController).
Only the superuser has those rights. Maybe it can be fixed but at this moment I’ll wait and see. If there is any progress I will report it.
Bug is fixed, when updating to 2025.5.3!
A big, big, big thumbs up to the code owner for being so helpful, his commitment, time spend, and speed (within a week!) solving this issue!!! :+1: :clap: :pray:
Impressive and higly appreciated, thank you so much!
