Hi @Filip_Kotian sorry for the late reply.
No, I abandoned the Blueprint, couldnāt fix it
Iāve noticed the same, is there a solution for it?
Hi everyone. I am having problems for the configuration of controlers Ikea TrƤdfi and Philips Hue Dimmer switch. It is not working on zigbee2mqtt.
Am I the only one with this issue?
Yeah ok, so this is dead?
Its so weird, the guy puts so much effort into it, the blueprints, the doco. Then just abandons it a few months later. Strange!
Hope hes ok
Hi. Iām using the Ikea dimmer switch (E1743), and I absolutely cannot get it to dim the lights. If I add the controller blueprint, without any actyions, and then add the hook, i can turn the lights on/off, but dimming doesnt work. ?
Hi, I have the exact same problem with Hue dimmer switches. Yesterday I switched my Zigbee Adapter and had to re-pair everything. Thankfully the friendly_names were recovered, so it was not that big of a problem. But now my hue switches are not working anymore (the ikea and opple one have no problem).
I had this settings set already before the migration. So this should be set for all devices. Maybe someone else has a idea?
device_options:
transition: 1
legacy: false
EDIT: just some more information, they are connected to the network and i can see the click action in HA. The automation trace is the same as from @Jay-uk.
I think I have found the solution.
device_options:
legacy: false
With this setting, all my actions had underscores instead of dashes. The blueprint awaits actions with dashes.
I have now added legacy: true to the dimmer switch and the dashes are back
Where are you exactly changing these lines? I would try your idea
Long press doesnāt work on up and down any more, seems a bigger change is needed (as implemented in ZHA - IKEA four button remote (Styrbar) for lights (E2001, E2002) )
hey Iām currently trying to setup my ikea tradfri using zigbee2mqtt. but i always fail at creating the lighting hook.
this is the error that I get:
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:280
Integration: Automation (documentation, issues)
First occurred: 10:34:40 PM (7 occurrences)
Last logged: 10:34:40 PM
Blueprint Hook - Light generated invalid automation with inputs OrderedDict([('controller_device', '7464982375cc468d627a7cf45fc77902'), ('controller_entity', 'sensor.lichtschalter_esstisch_action'), ('controller_model', 'IKEA E2001/E2002 STYRBAR Remote control (#2)'), ('light', 'light.testbirne_esstisch'), ('light_color_mode', 'Color Temperature')]): extra keys not allowed @ data['action'][1]['choose'][10]['sequence'][0]['choose'][1]['sequence'][0]['repeat']['sequence'][1]['milliseconds']. Got None
Blueprint Hook - Light generated invalid automation with inputs OrderedDict([('controller_device', '7464982375cc468d627a7cf45fc77902'), ('controller_entity', 'sensor.lichtschalter_esstisch_action'), ('controller_model', 'IKEA E2001/E2002 STYRBAR Remote control (#2)'), ('light', 'light.testbirne_esstisch')]): extra keys not allowed @ data['action'][1]['choose'][10]['sequence'][0]['choose'][1]['sequence'][0]['repeat']['sequence'][1]['milliseconds']. Got None
Blueprint Hook - Light generated invalid automation with inputs OrderedDict([('controller_device', '7464982375cc468d627a7cf45fc77902'), ('controller_entity', 'sensor.lichtschalter_esstisch_action'), ('controller_model', 'IKEA E2001/E2002 STYRBAR Remote control (#2)'), ('light', 'light.testbirne_esstisch'), ('max_brightness', 174)]): extra keys not allowed @ data['action'][1]['choose'][10]['sequence'][0]['choose'][1]['sequence'][0]['repeat']['sequence'][1]['milliseconds']. Got None
Blueprint Hook - Light generated invalid automation with inputs OrderedDict([('controller_entity', 'sensor.lichtschalter_esstisch_action'), ('controller_model', 'IKEA E2001/E2002 STYRBAR Remote control (#2)'), ('light', 'light.panel_esstisch')]): extra keys not allowed @ data['action'][1]['choose'][10]['sequence'][0]['choose'][1]['sequence'][0]['repeat']['sequence'][1]['milliseconds']. Got None
Blueprint Hook - Light generated invalid automation with inputs OrderedDict([('light_color_mode', 'None'), ('light', 'light.testbirne_esstisch'), ('controller_model', 'IKEA E2001/E2002 STYRBAR Remote control'), ('controller_entity', 'sensor.lichtschalter_esstisch_action')]): extra keys not allowed @ data['action'][1]['choose'][10]['sequence'][0]['choose'][1]['sequence'][0]['repeat']['sequence'][1]['milliseconds']. Got None
the config of the hook looks like this:
alias: Hook - Light
description: ""
use_blueprint:
path: EPMatt/light.yaml
input:
light_color_mode: None
light: light.testbirne_esstisch
controller_model: IKEA E2001/E2002 STYRBAR Remote control
controller_entity: sensor.lichtschalter_esstisch_action
controller_device: 7464982375cc468d627a7cf45fc77902
and the controller config looks like this:
alias: Controller - IKEA E2001/E2002 STYRBAR Remote control
description: ""
use_blueprint:
path: EPMatt/ikea_e2001_e2002.yaml
input:
integration: Zigbee2MQTT
helper_last_controller_event: input_text.lce
help would be really appreciated
Me again after a night of not much sleep I think I fixt the issue by deleting all blueprints and reinstalling all of them.
I canāt get long press to work either with IKEA E1743 TRĆ DFRI On/Off Switch & Dimmer and ZHA unfortunately. Short press works just fine.
I can see that things are written to the helper during long press but itās not performing the actions.
changed to {"a": "stop_with_on_off", "t": 1666158596.421401} triggered by automation Service - FjƤrrkontroll Kontor triggered by event 'zha_event'
07:49:56 - Now
changed to {"a": "move_MoveMode.Down_83_bitmap8.0_bitmap8.0", "t": 1666158587.577765} triggered by automation Service - FjƤrrkontroll Kontor triggered by event 'zha_event'
alias: Service - FjƤrrkontroll Kontor
description: ""
use_blueprint:
path: EPMatt/ikea_e1743.yaml
input:
integration: ZHA
controller_device: 8e435f208be000708423ab179d5c2774
helper_last_controller_event: input_text.remote_kontor
action_button_up_long:
- service: light.turn_on
data: {}
entity_id: light.taklampa_kontor
action_button_down_long:
- service: light.turn_off
data: {}
For ZHA I had to fix the blueprint to make it work. This is how the ZHA part of my YAML for the IKEA 1743 On/Off switch looks like:
zha:
button_up_short:
- "on"
button_up_long:
- "move_with_on_off_MoveMode.Up_83"
button_up_release:
- "stop_with_on_off"
button_down_short:
- "off"
button_down_long:
- move_MoveMode.Down_83_bitmap8.0_bitmap8.0
button_down_release:
- stop_with_on_off
I still donāt get the double taps, but long presses work. Itās similar for the E1812 shortcut remote. Itās a bit unfortunate that @epmatt does not seem to maintain the repo anymore. It looks so promising.
And for completeness the updated blueprint to get long presses with the IKEA shortcut E1812 button:
actions_mapping:
zha:
button_short:
- "on"
button_long:
- move_with_on_off_MoveMode.Up_83
button_release:
- stop_with_on_off
As with the other one, I donāt get double-taps, but the long presses work at least.
Hello! I managed to get the ikea e1812 to work pretty well with zigbee2mqtt. Got the short/double and long press working great. I did my very first Pull Request
[Update ikea_e1812.yaml by ralphrtm Ā· Pull Request #448 Ā· EPMatt/awesome-ha-blueprints Ā· GitHub] (donāt know if it will be merge soon).
Can someone try the fix and see if itās working on your system? Thanks
did you solve this ? At the moment iāam having the same problem ( E1524 remote Z2MQTT)
I never managed to resolve the problem.
Hmm ok thatās strange , this because they speak about this within the blueprint git themselves
Is there anybody who can lead me the way to solve this ? Or do I maybe need oneother blueprint?
