2026.1.3 and... go2rtc?
I upgraded to 2026.1.3 this morning and it was uneventful, except for these new errors:
Logger: homeassistant.setup
Source: setup.py:278
First occurred: 11:48:29 AM (2 occurrences)
Last logged: 11:57:10 AM
Setup failed for 'go2rtc': Integration failed to initialize.
Setup failed for 'default_config': Could not setup dependencies: go2rtc
Logger: homeassistant.components.go2rtc
Source: components/go2rtc/__init__.py:175
integration: go2rtc (documentation, issues)
First occurred: 11:48:28 AM (1 occurrence)
Last logged: 11:48:28 AM
Could not start go2rtc server
  File "/usr/src/homeassistant/homeassistant/components/go2rtc/server.py", line 223, in _start
    await self._startup_complete.wait()
  File "/usr/local/lib/python3.13/asyncio/locks.py", line 213, in wait
    await fut
asyncio.exceptions.CancelledError
  File "/usr/src/homeassistant/homeassistant/components/go2rtc/server.py", line 222, in _start
    async with asyncio.timeout(_SETUP_TIMEOUT):
  File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
  File "/usr/src/homeassistant/homeassistant/components/go2rtc/__init__.py", line 175, in async_setup
    await server.start()
  File "/usr/src/homeassistant/homeassistant/components/go2rtc/server.py", line 190, in start
    await self._start()
  File "/usr/src/homeassistant/homeassistant/components/go2rtc/server.py", line 229, in _start
    raise Go2RTCServerStartError from err
homeassistant.components.go2rtc.server.Go2RTCServerStartError: Go2rtc server didn't start correctly
…but I don’t use go2rtc, nor do I have that integration installed. I see in the version change log this related entry:
Not sure what gives, here. I can’t find anything in my config referencing go2rtc.
Just an FYI, go2rtc is one of those integrations that is sorta hidden and AFAIK is used in conjunction with other streaming camera integrations.
I haven’t upgraded yet, but I seem to recall getting this error once before, and an HA core restart seemed to have fixed it.
