2026.3.0 and soft reboot
After upgrade Home Assistant Core to 2026.3.0 reboot of Home Assistant no longer work.
I need to reboot entire HAOS to be able to reboot it.
When looking at the Home Assistant container log i can see this when trying the soft reboot (container restart)
s6-rc: info: service legacy-services: stopping
2026-03-05 12:43:51.148 WARNING (MainThread) [custom_components.tuya_local.device] Shed Light - PIR Spotlight receive loop has terminated
2026-03-05 12:43:51.245 WARNING (MainThread) [homeassistant.core] Task <Task pending name='service homeassistant.restart' coro=<_async_admin_handler() running at /usr/src/homeassistant/homeassistant/helpers/service.py:944> wait_for=<Task pending name='admin service homeassistant.restart' coro=<async_setup.<locals>.async_handle_core_service() running at /usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py:238> wait_for=<Future pending cb=[Task.task_wakeup()]> cb=[set.remove(), Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdown
Found 3 non-daemonic threads.
[11:44:04] INFO: Home Assistant Core finish process exit code 0
[11:44:04] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 229, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 188, in main
    from . import config, runner  # noqa: PLC0415
  File "/usr/src/homeassistant/homeassistant/runner.py", line 27, in <module>
    from . import bootstrap
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 41, in <module>
    from .components import (
    ...<22 lines>...
  File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 17, in <module>
    from homeassistant.components.http import (
    ...<4 lines>...
  File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 50, in <module>
    from homeassistant.helpers.network import NoURLAvailableError, get_url
  File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 10, in <module>
    from hass_nabucasa import remote
  File "/usr/local/lib/python3.14/site-packages/hass_nabucasa/__init__.py", line 87, in <module>
    from .remote import RemoteUI
  File "/usr/local/lib/python3.14/site-packages/hass_nabucasa/remote.py", line 22, in <module>
    from .acme import AcmeClientError, AcmeHandler, AcmeJWSVerificationError
  File "/usr/local/lib/python3.14/site-packages/hass_nabucasa/acme.py", line 15, in <module>
    from acme import challenges, client, crypto_util, errors, messages
  File "/usr/local/lib/python3.14/site-packages/acme/__init__.py", line 15, in <module>
    import josepy as jose # noqa: F401
  File "/usr/local/lib/python3.14/site-packages/josepy/__init__.py", line 71, in <module>
    from josepy.jws import JWS, Header, Signature
  File "/usr/local/lib/python3.14/site-packages/josepy/jws.py", line 52, in <module>
    class Header(json_util.JSONObjectWithFields):
    ...<103 lines>...
                raise errors.DeserializationError(error)
  File "/usr/local/lib/python3.14/site-packages/josepy/json_util.py", line 236, in __new__
    raise ValueError(
        f"Field `{key}` in JSONObject `{name}` has no type annotation."
ValueError: Field `alg` in JSONObject `Header` has no type annotation.
[11:44:08] INFO: Home Assistant Core finish process exit code 1
[11:44:08] INFO: Home Assistant Core service shutdown
I am running HAOS 17.1
HA Core: 2026.3.0
HA Supervisor: 2026.02.3 (I still cannot update it)
Frontend: 20260304.0
Any ideas?
All of your versions are current - including Supervisor 2026.02.3.
I was going to suggest something to do with the update to Python 3.14 but you say you are on HAOS so that should have been handled.
Bare metal or a VM manager?
I’ve seen some comments that Proxmox needs some extra settings, but deliberately avoid virtualisation.
A search for PLC0415 brought up a few similar virtualisation issues such as:
Mine is doing the same, every 10 min approximately. All versions are current. Mine is running in a Yellow…A friend has a Yellow too experimenting the same issue…
I tried also running in safe mode and still the same issue…
I’m having the same issue. Same error in the log. The only workaround is reboot of the host or rebuild the core.
System information
Version core-2026.3.0
Installation type Home Assistant OS
Development false
Supervisor true
Docker true
Container architecture amd64
User root
Virtual environment false
Python version 3.14.2
Operating system family Linux
Operating system version 6.12.67-haos
CPU architecture x86_64
Timezone Europe/Copenhagen
Configuration directory /config
Home Assistant Supervisor
Host operating system Home Assistant OS 17.1
Update channel stable
Supervisor version supervisor-2026.02.3
Agent version 1.8.1
Docker version 29.1.3
I received 3.1 while ago, first restored to 2.3 then update to 3.1 and the rebooting issue still…
I’m seeing the same with mine.
I caught the following error from the ha core logs:
    sys.exit(main())
    ...<22 lines>...
    ...<4 lines>...
    ...<103 lines>...
    raise ValueError(
It’s very frustrating that this keeps happening.
I have same error. Running on proxmox. When i update something and it needs to reboot it doesnt come back up. I need to manully reboot the proxmox VM haos.
This is frustating.
Seems like its the integration of AULA that causes the issue. Update to newest AULA version or deactivate it.
The aula integration’s PyJWT>=2.4.0 requirement pulls in josepy 1.15.0 , which overwrites Home Assistant’s expected josepy 2.2.0 . This breaks the ACME certificate process used by Home Assistant Cloud (Nabu Casa) for remote access.
