### Describe the issue you are experiencing
Tuya device not working post HA upgโฆrade :
Installation method
Home Assistant OS
Core 2026.5.1
Supervisor 2026.04.2
Operating System 17.3
Frontend 20260429.3
No issues found for search term 'tuya'
2026-05-09 03:06:32.585 ERROR (SyncWorker_0) [homeassistant.util.package] Installed version for tuya-device-handlers resolved to None
2026-05-09 03:06:33.149 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-handlers==0.0.18: ร Failed to read `tuya-device-handlers==0.0.18`
โ `tuya-device-handlers==0.0.18`
โ `/usr/local/lib/python3.14/site-packages/tuya_device_handlers-0.0.18.dist-info/METADATA`
2026-05-09 03:06:33.714 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-handlers==0.0.18: ร Failed to read `tuya-device-handlers==0.0.18`
2026-05-09 03:06:34.279 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-handlers==0.0.18: ร Failed to read `tuya-device-handlers==0.0.18`
2026-05-09 03:06:34.281 ERROR (SyncWorker_0) [homeassistant.util.package] Installed version for tuya-device-sharing-sdk resolved to None
2026-05-09 03:06:34.842 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-sharing-sdk==0.2.8: ร Failed to read `tuya-device-sharing-sdk==0.2.8`
โ `tuya-device-sharing-sdk==0.2.8`
โ `/usr/local/lib/python3.14/site-packages/tuya_device_sharing_sdk-0.2.8.dist-info/METADATA`
2026-05-09 03:06:35.413 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-sharing-sdk==0.2.8: ร Failed to read `tuya-device-sharing-sdk==0.2.8`
2026-05-09 03:06:35.978 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package tuya-device-sharing-sdk==0.2.8: ร Failed to read `tuya-device-sharing-sdk==0.2.8`
2026-05-09 03:06:35.978 ERROR (MainThread) [homeassistant.setup] Setup failed for 'tuya': Requirements for tuya not found: ['tuya-device-handlers==0.0.18', 'tuya-device-sharing-sdk==0.2.8'].
Other message :
The following integrations and platforms could not be set up:
[wled](https://www.home-assistant.io/integrations/wled) ([Show logs](https://monupurohit.com/config/logs?filter=wled))
[homeassistant_hardware](https://www.home-assistant.io/integrations/homeassistant_hardware) ([Show logs](https://monupurohit.com/config/logs?filter=homeassistant_hardware))
[zha](https://www.home-assistant.io/integrations/zha) ([Show logs](https://monupurohit.com/config/logs?filter=zha))
[openai_conversation](https://www.home-assistant.io/integrations/openai_conversation) ([Show logs](https://monupurohit.com/config/logs?filter=openai_conversation))
[tuya](https://www.home-assistant.io/integrations/tuya) ([Show logs](https://monupurohit.com/config/logs?filter=tuya))
[wyoming](https://www.home-assistant.io/integrations/wyoming) ([Show logs](https://monupurohit.com/config/logs?filter=wyoming))
### What operating system image do you use?
generic-x86-64 (Generic UEFI capable x86-64 systems)
### What version of Home Assistant Operating System is installed?
Home Assistant OS 17.3
### Did the problem occur after upgrading the Operating System?
No
### Hardware details
On Windows machine installed on Oracle Virtual Box
### Steps to reproduce the issue
1. Post upgrade to Core 2026.5.1, Tyua devices are not integrated
### Anything in the Supervisor logs that might be useful for us?
```txt
โโโถ Failed to parse METADATA file:
โฐโโถ Metadata field Name not found
โโโถ Failed to read metadata from installed package
2026-05-09 03:06:35.983 ERROR (SyncWorker_5) [homeassistant.util.package] Installed version for wyoming resolved to None
2026-05-09 03:06:36.550 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package wyoming==1.7.2: ร Failed to read `wyoming==1.7.2`
โโโถ Failed to read metadata from installed package `wyoming==1.7.2`
โ `/usr/local/lib/python3.14/site-packages/wyoming-1.7.2.dist-info/METADATA`
2026-05-09 03:06:37.108 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package wyoming==1.7.2: ร Failed to read `wyoming==1.7.2`
2026-05-09 03:06:37.674 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package wyoming==1.7.2: ร Failed to read `wyoming==1.7.2`
2026-05-09 03:06:37.675 ERROR (MainThread) [homeassistant.setup] Setup failed for 'wyoming': Requirements for wyoming not found: ['wyoming==1.7.2'].
2026-05-09 03:06:37.678 ERROR (SyncWorker_3) [homeassistant.util.package] Installed version for zha resolved to None
2026-05-09 03:06:38.258 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package zha==1.3.1: ร Failed to read `zha==1.3.1`
โโโถ Failed to read metadata from installed package `zha==1.3.1`
โ `/usr/local/lib/python3.14/site-packages/zha-1.3.1.dist-info/METADATA`
2026-05-09 03:06:38.799 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package zha==1.3.1: ร Failed to read `zha==1.3.1`
2026-05-09 03:06:39.386 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package zha==1.3.1: ร Failed to read `zha==1.3.1`
2026-05-09 03:06:39.388 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Button1 DP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.389 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Button2 - SP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.390 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Button2 - DP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.391 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'button3 - DP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.392 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'button2 - LP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.396 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'button3 - SP new' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.400 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'button1 - SP new' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.422 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Button 1 New SP' failed to setup triggers and has been disabled: Integration 'zha' could not be loaded
2026-05-09 03:06:39.471 ERROR (MainThread) [homeassistant.components.automation] Platform automation does not generate unique IDs. ID Door - 3 Layer already exists - ignoring automation.door_sensor_3_layer_logic_6
2026-05-09 03:06:47.604 WARNING (MainThread) [custom_components.hacs] You have 'custom-cards/bar-card' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Repository is no longer maintained)
2026-05-09 03:06:50.038 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args ('/config/.storage/header_ytube_music_player.json', 'r') inside the event loop by custom integration 'ytube_music_player' at custom_components/ytube_music_player/const.py, line 273: with open(path, 'r') as f: (offender: /config/custom_components/ytube_music_player/const.py, line 273: with open(path, 'r') as f:), please create a bug report at https://github.com/KoljaWindeler/ytube_music_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 229, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 215, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 289, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 706, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 677, in run_forever
self._run_once()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 2046, in _run_once
handle._run()
File "/usr/local/lib/python3.14/asyncio/events.py", line 94, in _run
self._context.run(self._callback, *self._args)
File "/config/custom_components/ytube_music_player/media_player.py", line 326, in async_startup
await self.async_check_api()
File "/config/custom_components/ytube_music_player/media_player.py", line 350, in async_check_api
[ret, msg, self._api] = await async_try_login(self.hass, self._header_file, self._brand_id, self._api_language,oauth_credentials)
File "/config/custom_components/ytube_music_player/const.py", line 273, in async_try_login
2026-05-09 03:06:50.287 ERROR (MainThread) [custom_components.ytube_music_player.const] HTTP 400 Bad Request error. This is a KNOWN ISSUE with OAuth authentication due to YouTube Music server-side changes (November 2024 - ytmusicapi issues #676, #682). OAuth is currently broken for most users even with valid credentials. RECOMMENDED SOLUTION: Switch to browser-based authentication. See https://ytmusicapi.readthedocs.io/en/stable/setup/browser.html for instructions. To use browser auth: (1) Delete this integration, (2) Extract browser headers using the guide above, (3) Manually create the header file, (4) Reconfigure integration with 'Renew OAuth credentials' unchecked.
2026-05-09 03:06:50.325 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:06:50.409 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.jio_set_top_box_2 does not support any media_player features
2026-05-09 03:06:50.487 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'zha'. Setup failed for dependencies: ['homeassistant_hardware']
2026-05-09 03:06:52.064 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:07:00.580 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:07:03.944 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:07:20.649 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:07:25.413 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:07:27.878 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for water-tank @ 192.168.68.83: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.68.83', port=6053))] (TimeoutAPIError)
2026-05-09 03:07:27.883 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for water-level-sensor @ 192.168.68.57: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.68.57', port=6053))] (TimeoutAPIError)
2026-05-09 03:08:01.094 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:08:06.970 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:09:21.402 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:09:28.723 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:10:41.495 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:10:50.712 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:12:01.750 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:12:12.395 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:13:21.978 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:13:27.590 ERROR (MainThread) [homeassistant.helpers.entity] Update for alarm_control_panel.ezviz_alarm fails
File "/usr/local/lib/python3.14/site-packages/urllib3/connectionpool.py", line 788, in urlopen
response = self._make_request(
conn,
...<10 lines>...
**response_kw,
File "/usr/local/lib/python3.14/site-packages/urllib3/connectionpool.py", line 534, in _make_request
response = conn.getresponse()
File "/usr/local/lib/python3.14/site-packages/urllib3/connection.py", line 571, in getresponse
httplib_response = super().getresponse()
File "/usr/local/lib/python3.14/http/client.py", line 1450, in getresponse
response.begin()
File "/usr/local/lib/python3.14/http/client.py", line 336, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.14/http/client.py", line 305, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
" response")
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.14/site-packages/requests/adapters.py", line 645, in send
resp = conn.urlopen(
method=request.method,
...<9 lines>...
chunked=chunked,
File "/usr/local/lib/python3.14/site-packages/urllib3/connectionpool.py", line 842, in urlopen
retries = retries.increment(
method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.14/site-packages/urllib3/util/retry.py", line 498, in increment
raise reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.14/site-packages/urllib3/util/util.py", line 38, in reraise
raise value.with_traceback(tb)
conn,
...<10 lines>...
**response_kw,
response.begin()
" response")
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 986, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1369, in async_device_update
await hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 86, in run
result = ctx.run(self.task)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 73, in run
return fn(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/ezviz/alarm_control_panel.py", line 138, in update
self.coordinator.ezviz_client.get_group_defence_mode()
File "/usr/local/lib/python3.14/site-packages/pyezvizapi/client.py", line 1131, in get_group_defence_mode
req = self._session.get(
url=f"https://{self._token['api_url']}{API_ENDPOINT_GROUP_DEFENCE_MODE}",
...<3 lines>...
timeout=self._timeout,
File "/usr/local/lib/python3.14/site-packages/requests/sessions.py", line 605, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.14/site-packages/requests/sessions.py", line 592, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.14/site-packages/requests/sessions.py", line 706, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.14/site-packages/requests/adapters.py", line 660, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2026-05-09 03:13:34.445 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:14:42.173 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:14:56.265 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:16:02.546 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:16:17.995 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:17:22.810 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:17:39.804 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
2026-05-09 03:18:42.902 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://192.168.68.75:8095/ws: Cannot connect to host 192.168.68.75:8095 ssl:False [Connect call failed ('192.168.68.75', 8095)]
2026-05-09 03:19:01.677 ERROR (MainThread) [music_assistant_client.connection] Failed to connect to ws://d5369777-music-assistant:8094/ws: Cannot connect to host d5369777-music-assistant:8094 ssl:False [Timeout while contacting DNS servers]
### Anything in the Host logs that might be useful for us?
```txt
2026-05-08 21:34:24.468 homeassistant dockerd[567]: time="2026-05-09T03:04:24.468188749+05:30" level=info msg="sbJoin: gwep4 ''->'b07549f82041', gwep6 ''->'b07549f82041'" eid=b07549f82041 ep=addon_core_piper net=hassio nid=fe8621ff6d79
2026-05-08 21:34:24.744 homeassistant systemd[1]: var-lib-docker-overlay2-37f65987b16b653cc23a13ac652c01a322f15d739b79786050788102a9bf230f\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:34:24.744 homeassistant systemd[1]: mnt-data-docker-overlay2-37f65987b16b653cc23a13ac652c01a322f15d739b79786050788102a9bf230f\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:34:24.893 homeassistant containerd[526]: time="2026-05-09T03:04:24.892975379+05:30" level=info msg="connecting to shim 711463b0a6cc80030ff96a5f1d2c3c92d608003b586ce86cc2e6c9d6c3609685" address="unix:///run/containerd/s/589ca92a017d26d98668a62040b0ef43865f985db8bc6222f9b335fec18841ff" namespace=moby protocol=ttrpc version=3
2026-05-08 21:34:24.962 homeassistant systemd[1]: Started libcontainer container 711463b0a6cc80030ff96a5f1d2c3c92d608003b586ce86cc2e6c9d6c3609685.
2026-05-08 21:34:25.003 homeassistant kernel: hassio: port 16(veth0ea3b59) entered blocking state
2026-05-08 21:34:25.003 homeassistant kernel: hassio: port 16(veth0ea3b59) entered disabled state
2026-05-08 21:34:25.003 homeassistant kernel: veth0ea3b59: entered allmulticast mode
2026-05-08 21:34:25.003 homeassistant kernel: veth0ea3b59: entered promiscuous mode
2026-05-08 21:34:25.004 homeassistant NetworkManager[450]: <info> [1778276065.0038] manager: (veth0ea3b59): new Veth device (/org/freedesktop/NetworkManager/Devices/21)
2026-05-08 21:34:25.041 homeassistant kernel: eth0: renamed from vetheb59010
2026-05-08 21:34:25.046 homeassistant kernel: hassio: port 16(veth0ea3b59) entered blocking state
2026-05-08 21:34:25.046 homeassistant kernel: hassio: port 16(veth0ea3b59) entered forwarding state
2026-05-08 21:34:25.046 homeassistant NetworkManager[450]: <info> [1778276065.0454] device (veth0ea3b59): carrier: link connected
2026-05-08 21:34:25.049 homeassistant dockerd[567]: time="2026-05-09T03:04:25.049298506+05:30" level=info msg="Skipping check for route to send NA, EMSGSIZE" eid=fde86edb935e ep=addon_core_whisper net=hassio nid=fe8621ff6d79
2026-05-08 21:34:25.055 homeassistant dockerd[567]: time="2026-05-09T03:04:25.055185268+05:30" level=info msg="sbJoin: gwep4 ''->'fde86edb935e', gwep6 ''->'fde86edb935e'" eid=fde86edb935e ep=addon_core_whisper net=hassio nid=fe8621ff6d79
2026-05-08 21:34:25.444 homeassistant systemd[1]: var-lib-docker-overlay2-61e72469592e2bc094481dbf05981b25dc00e39c6b14592356175511455f83d7\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:34:25.445 homeassistant systemd[1]: mnt-data-docker-overlay2-61e72469592e2bc094481dbf05981b25dc00e39c6b14592356175511455f83d7\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:34:25.816 homeassistant containerd[526]: time="2026-05-09T03:04:25.816179985+05:30" level=info msg="connecting to shim ab6841530428debb0bd55845d88cf1efa60f123afea4032a43ef750ee77ed51c" address="unix:///run/containerd/s/cfeac383810d64852b30bd01fd6517f2f1a44e31e16918a87f32dcbfaa46ffaf" namespace=moby protocol=ttrpc version=3
2026-05-08 21:34:25.867 homeassistant systemd[1]: Started libcontainer container ab6841530428debb0bd55845d88cf1efa60f123afea4032a43ef750ee77ed51c.
2026-05-08 21:34:25.936 homeassistant kernel: hassio: port 17(vethea26626) entered blocking state
2026-05-08 21:34:25.936 homeassistant kernel: hassio: port 17(vethea26626) entered disabled state
2026-05-08 21:34:25.936 homeassistant kernel: vethea26626: entered allmulticast mode
2026-05-08 21:34:25.936 homeassistant kernel: vethea26626: entered promiscuous mode
2026-05-08 21:34:25.940 homeassistant NetworkManager[450]: <info> [1778276065.9390] manager: (vethea26626): new Veth device (/org/freedesktop/NetworkManager/Devices/22)
2026-05-08 21:34:25.984 homeassistant kernel: eth0: renamed from vethae8318e
2026-05-08 21:34:25.984 homeassistant kernel: hassio: port 17(vethea26626) entered blocking state
2026-05-08 21:34:25.984 homeassistant kernel: hassio: port 17(vethea26626) entered forwarding state
2026-05-08 21:34:25.984 homeassistant dockerd[567]: time="2026-05-09T03:04:25.983366624+05:30" level=info msg="Skipping check for route to send NA, EMSGSIZE" eid=c8aa0be37fee ep=addon_core_openwakeword net=hassio nid=fe8621ff6d79
2026-05-08 21:34:25.984 homeassistant NetworkManager[450]: <info> [1778276065.9839] device (vethea26626): carrier: link connected
2026-05-08 21:34:25.986 homeassistant dockerd[567]: time="2026-05-09T03:04:25.986774198+05:30" level=info msg="sbJoin: gwep4 ''->'c8aa0be37fee', gwep6 ''->'c8aa0be37fee'" eid=c8aa0be37fee ep=addon_core_openwakeword net=hassio nid=fe8621ff6d79
2026-05-08 21:34:26.478 homeassistant containerd[526]: time="2026-05-09T03:04:26.478341718+05:30" level=info msg="connecting to shim e0e880c33d83597da9bf90806b8140b26e0ff74ae7e030be58008202d140cb7f" address="unix:///run/containerd/s/ba6988c90a9aaa900334efce6a1bff5c26e25c09e626fc16954602d6c3600166" namespace=moby protocol=ttrpc version=3
2026-05-08 21:34:26.512 homeassistant systemd[1]: Started libcontainer container e0e880c33d83597da9bf90806b8140b26e0ff74ae7e030be58008202d140cb7f.
2026-05-08 21:34:26.552 homeassistant NetworkManager[450]: <info> [1778276066.5526] manager: (vethfa1475e): new Veth device (/org/freedesktop/NetworkManager/Devices/23)
2026-05-08 21:34:26.555 homeassistant kernel: hassio: port 18(vethfa1475e) entered blocking state
2026-05-08 21:34:26.555 homeassistant kernel: hassio: port 18(vethfa1475e) entered disabled state
2026-05-08 21:34:26.555 homeassistant kernel: vethfa1475e: entered allmulticast mode
2026-05-08 21:34:26.555 homeassistant kernel: vethfa1475e: entered promiscuous mode
2026-05-08 21:34:26.595 homeassistant kernel: eth0: renamed from veth499039c
2026-05-08 21:34:26.597 homeassistant kernel: hassio: port 18(vethfa1475e) entered blocking state
2026-05-08 21:34:26.597 homeassistant kernel: hassio: port 18(vethfa1475e) entered forwarding state
2026-05-08 21:34:26.597 homeassistant NetworkManager[450]: <info> [1778276066.5976] device (vethfa1475e): carrier: link connected
2026-05-08 21:34:26.598 homeassistant dockerd[567]: time="2026-05-09T03:04:26.598537129+05:30" level=info msg="Skipping check for route to send NA, EMSGSIZE" eid=7e8c5c6a70fc ep=addon_d5369777_ytm_po_token_generator net=hassio nid=fe8621ff6d79
2026-05-08 21:34:26.613 homeassistant dockerd[567]: time="2026-05-09T03:04:26.613832255+05:30" level=info msg="sbJoin: gwep4 ''->'7e8c5c6a70fc', gwep6 ''->'7e8c5c6a70fc'" eid=7e8c5c6a70fc ep=addon_d5369777_ytm_po_token_generator net=hassio nid=fe8621ff6d79
2026-05-08 21:34:27.248 homeassistant containerd[526]: time="2026-05-09T03:04:27.248029667+05:30" level=info msg="connecting to shim 8f06a51e9d8771e57ba71865a850feaec9d46df1c2670de983bab201e9730a83" address="unix:///run/containerd/s/b1d173058bf5ef9c4641ed2c70b75b6a4775ec36de7fb8ceaa2269948f2fd0fd" namespace=moby protocol=ttrpc version=3
2026-05-08 21:34:27.292 homeassistant systemd[1]: Started libcontainer container 8f06a51e9d8771e57ba71865a850feaec9d46df1c2670de983bab201e9730a83.
2026-05-08 21:34:27.357 homeassistant dockerd[567]: time="2026-05-09T03:04:27.356883554+05:30" level=info msg="sbJoin: gwep4 ''->'', gwep6 ''->''" eid=87b693b5d977 ep=addon_efc01f81_ewelink_smart_home_slug net=host nid=82a9501ad1ca
2026-05-08 21:34:54.202 homeassistant systemd[1]: Starting Hostname Service...
2026-05-08 21:34:54.263 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:34:54.285 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:34:54.320 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:34:54.344 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:34:54.577 homeassistant systemd[1]: Started Hostname Service.
2026-05-08 21:34:54.596 homeassistant systemd[1]: Starting Time & Date Service...
2026-05-08 21:34:54.622 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:34:54.641 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:34:54.912 homeassistant systemd[1]: Started Time & Date Service.
2026-05-08 21:35:24.614 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2026-05-08 21:35:24.953 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
2026-05-08 21:35:55.263 homeassistant systemd[1]: docker-d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a.scope: Deactivated successfully.
2026-05-08 21:35:55.266 homeassistant systemd[1]: docker-d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a.scope: Consumed 34.856s CPU time, 1.2G memory peak, 4K memory swap peak, 481.4M read from disk, 13.4M written to disk.
2026-05-08 21:35:55.290 homeassistant dockerd[567]: time="2026-05-09T03:05:55.290158838+05:30" level=info msg="received task-delete event from containerd" container=d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
2026-05-08 21:35:55.295 homeassistant containerd[526]: time="2026-05-09T03:05:55.293531214+05:30" level=info msg="shim disconnected" id=d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a namespace=moby
2026-05-08 21:35:55.295 homeassistant containerd[526]: time="2026-05-09T03:05:55.295039672+05:30" level=info msg="cleaning up after shim disconnected" id=d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a namespace=moby
2026-05-08 21:35:55.303 homeassistant containerd[526]: time="2026-05-09T03:05:55.295052097+05:30" level=info msg="cleaning up dead shim" id=d39d49cd3f7eb58827cca6d5c6bec414b838cdee7b3b1663a9861e3d052c228a namespace=moby
2026-05-08 21:35:55.383 homeassistant systemd[1]: var-lib-docker-overlay2-f726969fbaef7c3734d9283d654685448c3ea2223831700754e4a54f37875461-merged.mount: Deactivated successfully.
2026-05-08 21:35:55.383 homeassistant systemd[1]: mnt-data-docker-overlay2-f726969fbaef7c3734d9283d654685448c3ea2223831700754e4a54f37875461-merged.mount: Deactivated successfully.
2026-05-08 21:35:56.602 homeassistant systemd[1]: var-lib-docker-overlay2-8ea5e6e44d335582302458978215177e209da56ef0590fd4ff76deb65b96b11c\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:35:56.603 homeassistant systemd[1]: mnt-data-docker-overlay2-8ea5e6e44d335582302458978215177e209da56ef0590fd4ff76deb65b96b11c\x2dinit-merged.mount: Deactivated successfully.
2026-05-08 21:35:56.695 homeassistant containerd[526]: time="2026-05-09T03:05:56.695654865+05:30" level=info msg="connecting to shim 1b2e322f8588da48f9b04ed6bda5c0a1f3ec79f63a49356227c70f0d9ce9c0b1" address="unix:///run/containerd/s/49e2bbad552fa5d2ef09381dfd32265b88140fde7edd0acf0e34a34b797463c9" namespace=moby protocol=ttrpc version=3
2026-05-08 21:35:56.728 homeassistant systemd[1]: Started libcontainer container 1b2e322f8588da48f9b04ed6bda5c0a1f3ec79f63a49356227c70f0d9ce9c0b1.
2026-05-08 21:35:56.764 homeassistant dockerd[567]: time="2026-05-09T03:05:56.763299598+05:30" level=info msg="sbJoin: gwep4 ''->'', gwep6 ''->''" eid=0b4abe609c7c ep=homeassistant net=host nid=82a9501ad1ca
2026-05-08 21:36:11.560 homeassistant systemd[1]: Starting Bluetooth service...
2026-05-08 21:36:11.596 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:36:11.623 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:36:11.853 homeassistant bluetoothd[8984]: Bluetooth daemon 5.85
2026-05-08 21:36:11.859 homeassistant systemd[1]: Started Bluetooth service.
2026-05-08 21:36:11.859 homeassistant bluetoothd[8984]: Starting SDP server
2026-05-08 21:36:11.864 homeassistant kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
2026-05-08 21:36:11.864 homeassistant kernel: Bluetooth: BNEP filters: protocol multicast
2026-05-08 21:36:11.864 homeassistant kernel: Bluetooth: BNEP socket layer initialized
2026-05-08 21:36:11.865 homeassistant bluetoothd[8984]: Bluetooth management interface 1.23 initialized
2026-05-08 21:36:11.874 homeassistant systemd[1]: Starting Hostname Service...
2026-05-08 21:36:11.901 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:36:11.926 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:36:11.962 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:36:11.987 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:36:12.225 homeassistant systemd[1]: Started Hostname Service.
2026-05-08 21:36:42.264 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2026-05-08 21:38:59.814 homeassistant systemd[1]: Started Journal Gateway Service.
2026-05-08 21:38:59.826 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:38:59.842 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:38:59.862 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:38:59.885 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:38:59.911 homeassistant systemd-timesyncd[1600]: Network configuration changed, trying to establish connection.
2026-05-08 21:38:59.936 homeassistant systemd-timesyncd[1600]: Contacted time server 162.159.200.1:123 (162.159.200.1).
2026-05-08 21:47:05.876 homeassistant systemd[1]: Starting Cleanup of Temporary Directories...
2026-05-08 21:47:05.918 homeassistant systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
2026-05-08 21:47:05.918 homeassistant systemd[1]: Finished Cleanup of Temporary Directories.
2026-05-08 21:47:05.924 homeassistant systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.service.mount: Deactivated successfully.
### System information
<html>
<body>
<div style="color: rgb(225, 225, 225); font-family: Roboto, Noto, sans-serif; font-size: 14px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: normal; background-color: rgb(28, 28, 28); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial;">
Version | core-2026.5.1
Installation type | Home Assistant OS
Development | false
Supervisor | true
Docker | true
Container architecture | amd64
User | root
Virtual environment | false
Python version | 3.14.2
Operating system family | Linux
Operating system version | 6.12.85-haos
CPU architecture | x86_64
Time zone | Asia/Calcutta
Configuration directory | /config
</div><div style="color: rgb(225, 225, 225); font-family: Roboto, Noto, sans-serif; font-size: 14px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: start; text-indent: 0px; text-transform: none; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: normal; background-color: rgb(28, 28, 28); text-decoration-thickness: initial; text-decoration-style: initial; text-decoration-color: initial;"><h3>Core metrics</h3><ha-metric><ha-settings-row style="display: flex; padding: 0px; align-content: normal; align-self: auto; align-items: center; height: 54px; width: 519.531px;"><div class="prefix-wrap" style="flex: 1 1 0%; display: inline;"><slot name="prefix"></slot><div class="body" two-line="" style="padding: 8px 16px 8px 0px; padding-inline: 0px 16px; overflow: hidden; display: flex; flex-direction: column; justify-content: center; flex: 1 1 0%; min-height: calc(56px);"><slot name="heading"><span slot="heading">Processor usage</span></slot><span class="secondary" style="white-space: normal; display: block; padding-top: 4px; font-family: Roboto, Noto, sans-serif; font-size: 12px; -webkit-font-smoothing: antialiased; font-weight: 400; line-height: normal; color: rgb(155, 155, 155);"><slot name="description"><div slot="description" title="" style="white-space: normal; color: rgb(155, 155, 155); display: flex; justify-content: space-between;"><span class="value" style="width: 48px; padding-right: 4px; padding-inline-end: 4px; padding-inline-start: initial; flex-shrink: 0;"><div style="direction: ltr; text-align: left;">1.9<span> </span>%</div></span><ha-bar class=" " style="--ha-bar-primary-color: #43a047;"><svg><g><rect></rect><rect width="1.9%"></rect></g></svg></ha-bar></div></slot></span></div></div><div class="content" style="display: flex; justify-content: flex-end; flex: 1 1 0%; min-width: 0px; padding: 16px 0px;"><slot></slot></div></ha-settings-row></ha-metric><ha-metric><ha-settings-row style="display: flex; padding: 0px; align-content: normal; align-self: auto; align-items: center; height: 54px; width: 519.531px;"><div class="prefix-wrap" style="flex: 1 1 0%; display: inline;"><slot name="prefix"></slot><div class="body" two-line="" style="padding: 8px 16px 8px 0px; padding-inline: 0px 16px; overflow: hidden; display: flex; flex-direction: column; justify-content: center; flex: 1 1 0%; min-height: calc(56px);"><slot name="heading"><span slot="heading">Memory usage</span></slot><span class="secondary" style="white-space: normal; display: block; padding-top: 4px; font-family: Roboto, Noto, sans-serif; font-size: 12px; -webkit-font-smoothing: antialiased; font-weight: 400; line-height: normal; color: rgb(155, 155, 155);"><slot name="description"><div slot="description" title="" style="white-space: normal; color: rgb(155, 155, 155); display: flex; justify-content: space-between;"><span class="value" style="width: 48px; padding-right: 4px; padding-inline-end: 4px; padding-inline-start: initial; flex-shrink: 0;"><div style="direction: ltr; text-align: left;">20.2<span> </span>%</div></span><ha-bar class=" " style="--ha-bar-primary-color: #43a047;"><svg><g><rect></rect><rect width="20.2%"></rect></g></svg></ha-bar></div></slot></span></div></div><div class="content" style="display: flex; justify-content: flex-end; flex: 1 1 0%; min-width: 0px; padding: 16px 0px;"><slot></slot></div></ha-settings-row></ha-metric><h3>Supervisor metrics</h3><ha-metric><ha-settings-row style="display: flex; padding: 0px; align-content: normal; align-self: auto; align-items: center; height: 54px; width: 519.531px;"><div class="prefix-wrap" style="flex: 1 1 0%; display: inline;"><slot name="prefix"></slot><div class="body" two-line="" style="padding: 8px 16px 8px 0px; padding-inline: 0px 16px; overflow: hidden; display: flex; flex-direction: column; justify-content: center; flex: 1 1 0%; min-height: calc(56px);"><slot name="heading"><span slot="heading">Processor usage</span></slot><span class="secondary" style="white-space: normal; display: block; padding-top: 4px; font-family: Roboto, Noto, sans-serif; font-size: 12px; -webkit-font-smoothing: antialiased; font-weight: 400; line-height: normal; color: rgb(155, 155, 155);"><slot name="description"><div slot="description" title="" style="white-space: normal; color: rgb(155, 155, 155); display: flex; justify-content: space-between;"><span class="value" style="width: 48px; padding-right: 4px; padding-inline-end: 4px; padding-inline-start: initial; flex-shrink: 0;"><div style="direction: ltr; text-align: left;">0<span> </span>%</div></span><ha-bar class=" " style="--ha-bar-primary-color: #43a047;"><svg><g><rect></rect><rect width="0%"></rect></g></svg></ha-bar></div></slot></span></div></div><div class="content" style="display: flex; justify-content: flex-end; flex: 1 1 0%; min-width: 0px; padding: 16px 0px;"><slot></slot></div></ha-settings-row></ha-metric><ha-metric><ha-settings-row style="display: flex; padding: 0px; align-content: normal; align-self: auto; align-items: center; height: 54px; width: 519.531px;"><div class="prefix-wrap" style="flex: 1 1 0%; display: inline;"><slot name="prefix"></slot><div class="body" two-line="" style="padding: 8px 16px 8px 0px; padding-inline: 0px 16px; overflow: hidden; display: flex; flex-direction: column; justify-content: center; flex: 1 1 0%; min-height: calc(56px);"><slot name="heading"><span slot="heading">Memory usage</span></slot><span class="secondary" style="white-space: normal; display: block; padding-top: 4px; font-family: Roboto, Noto, sans-serif; font-size: 12px; -webkit-font-smoothing: antialiased; font-weight: 400; line-height: normal; color: rgb(155, 155, 155);"><slot name="description"><div slot="description" title="" style="white-space: normal; color: rgb(155, 155, 155); display: flex; justify-content: space-between;"><span class="value" style="width: 48px; padding-right: 4px; padding-inline-end: 4px; padding-inline-start: initial; flex-shrink: 0;"><div style="direction: ltr; text-align: left;">2.5<span> </span>%</div></span><ha-bar class=" " style="--ha-bar-primary-color: #43a047;"><svg><g><rect></rect><rect width="2.5%"></rect></g></svg></ha-bar></div></slot></span></div></div></ha-settings-row></ha-metric></div><br class="Apple-interchange-newline">
</body>
</html>
### Additional information
_No response_
