2026.9 - Homematic button not working after the update
After updating Home Assistant Core from 2026.8.3 to 2026.9.0 / 2026.9.1, the devices (HmIP-PS-2 9YM — outlet / S60ZBTPF — outlet) no longer work via the Homematic button, and the automations are no longer triggered.
Automation / connection as follows:
HmIP-WRC6 Homematic button connected via openCCU (CCU3 Homematic)
S60ZBTPF from SONOFF connected via Home Assistant Connect ZBT-2 (ZigBee)
After rolling back to Home Assistant Core 2026.8.3, the button works without any issues.
I hope the issue will be fixed in the next update.
Share the automation, maybe we can see the problem.
Chances that an update broke a zigbee device and not the whole zigbee integration are pretty low. More than likely it’s something in the automation that will no longer work, and if that’s the case, there will be no fix.
Automation 1:
alias: Steckdose Couch R (S3) (EIN/AUS)
description: ''
triggers:
  - domain: homematicip_local
    device_id:
    event_type: homematic.keypress
    interface_id: CCU3-HmIP-RF
    model: HmIP-WRC6
    value: null
    type: press_long_start
    subtype: 4
    address:
    trigger: device
conditions: []
actions:
  - type: toggle
    device_id:
    entity_id:
    domain: switch
mode: single
Automation 2:
alias: Beleuchtung Vitrine (EIN/AUS)
description: ''
triggers:
    device_id:
    model: HmIP-WRC6
    value: null
    type: press_short
    subtype: 3
    address:
    trigger: device
conditions: []
actions:
  - type: toggle
    device_id:
    entity_id:
    domain: switch
mode: single
Hopping in here aswell since all my HmIP-WRC2 have stopped working after the update. I can see the indicator showing Orange → Green that shows they can reach the OpenCCU. A sample trigger:
triggers:
device_id: a2025eef3029a1297b95eb2eababa741
address: 0041E0C9B04DE9
model: HmIP-WRC2-A
interface_id: RaspberryMatic-HmIP-RF
type: press_short
subtype: 1
trigger: device
Have a read through this No Homatic Keypress Events - #7 by Boxx
Thank you. In case anyone needs it, this is what it fixed it for me:
triggers:
trigger: event.received
entity_id: event.taster_wohnzimmer_ch2
options:
event_type:
- press_short
