2652p2 ethernet coordinator tubeszb disconnect after restart homeassistant
I have a problem with 2652p2 ethernet coordinator from tubeszb in zigbee2mqtt platform.
When restarting homeassistant it hangs and all devices are disconnected.
the only solution I have found is to restart the z2m service after HA starts with an automation…
is there any better option?
Is z2m configured to use the ip or local host name from mdns?
If you configured the device as an esphome entity try disabling all the entities in case that is causing any issues with the restart.
I configured by IP address.
I have delete the device on ESPhome platform and the problem was solved!
Thanks a lot.
