2D Floorplan
Hi All,
I’m starting to build a 2D floorplan and have some questions that i can’t find an answer for:
  • I want a tekst button to toggle all lights in a room. I’ve managed to get the tekst button but can’t get any space between the prefix and the current state. Also it’s a verry small piece of tekst :).
  - type: state-label
    prefix: Woonkamer
    tap_action:
      action: toggle
    entity: light.woonkamer
    style:
      top: 65%
      left: 10%
  • Is it possible to size the icons on the floorplan?. I find them a bit small.
The floorplan looks as following:
With icons on it:
You should be able to use all CSS related properties like width or height under style. Try
style:
  top: 65%
  left: 10%
  width: 150%
  height: 150%
you can also try to use px as unit if you want absolute values.
patman is right, you can use css, here is an example from my floorplan, which may help you:
- type: state-icon
  entity: light.schlafzimmer_decke
  state_color: false
  tap_action:
    action: toggle
  style:
    top: 20%
    left: 15%
    width: 50px
    height: 50px
    line-height: 50px
    border-radius: 50%
    transform: scale(1.5,1.5)
    text-align: center
    background-color: "rgba(255, 255, 255, 0.3)"
which finally looks like this:
For more complex texts on my floorplan I use template sensors which concatenate things as I like and then use the state-label.
Thanks for the replies, but this doesn’t change my icon size.
If i change the width and height only the outer circle gets larger. The icon inside stays the same size.
  - type: state-icon
    tap_action:
      action: toggle
    entity: light.nanoleaf_dressoir
    icon: 'mdi:led-strip'
    style:
      top: 94%
      left: 71%
      width: 90px
      height: 90px
      line-height: 50px
      border-radius: 50%
      transform: 'scale(1.5,1.5)'
      text-align: center
      background-color: 'rgba(255, 255, 255, 0.3)'
When you like it even bigger, then leave width and height property at 50px and try a bigger scale, like this:
  - type: state-icon
    tap_action:
      action: toggle
    style:
      top: 94%
      left: 71%
      width: 50px
      height: 50px
      line-height: 50px
      border-radius: 50%
      transform: 'scale(3,3)'
      text-align: center
Thanks!. That did the trick :slight_smile:
Do you perhaps know something about a text box on the side.
I have a text box that turns off all lights at the same time, but it looks silly.
I want it like the text on the bottom. Bigger, bold and with a space between the room name and the current state.
Woops. Figured it out myself.
I need to start reading some more before asking :wink:
      font-weight: bold
What program did you use for making this 2D floorplan?
I used: https://www.homestyler.com/floorplan/
Thanks. I like the subtle floorplan. Gonna take a look and see if I can make myself one
