4.2 E-Ink from Makerfab?
I got a 4.2" 3-color e-ink from Makerfab but fail to get it running with ESP-home.
The specs and price look quiet promising.
The product wiki has some info and a config for Arduino IDE.
My config gives me a initial picture and then stays flickering.
Any idea how to get it running? The other drivers dont work at all.
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  platformio_options:
    board_build.flash_mode: dio
    board_build.arduino.memory_type: qio_opi
    build_flags: "-DBOARD_HAS_PSRAM"
    board_upload.maximum_ram_size: 524288
esp32:
# board: weesp32s3_120_16_8-qio_opi
  board: esp32-s3-devkitc-1
  flash_size: 16MB
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
      CONFIG_ESP32S3_DATA_CACHE_64KB: y
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  speed: 80MHz
  mode: octal
spi:
  - id: spi_eink
    clk_pin: GPIO014
    mosi_pin: GPIO13
#    miso_pin: GPIO13
    interface: hardware
display:
  - platform: waveshare_epaper
    spi_id: spi_eink
    cs_pin: GPIO15
    busy_pin: GPIO09
    reset_pin: GPIO10
    dc_pin: GPIO11
    model: 4.20in-bV2-bwr
#    model: gdey042t81
#    model: 4.20in
#    full_update_every: 30
    reset_duration: 10ms
    update_interval: 5ms
This may be the cause of your flickering. It should be in the seconds range (you can even set it to never and update manually), not milliseconds…
changing the reset interval to 150ms and update to 60s did help :wink:
