4 Channel Smart Relay display
Hi all,
I have a 4 channel Zigbee smart relay which I have integrated into HA via ZHA. The device in HA has 4 light entities and has a configuration open to activate interlock, meaning that when you active one relay, the others switch off. (aka only one of the contacts can be on at any moment in time).
What’s the best way to display such a “interlock 4 way switch” in a dashboard? Currently it’s showing as 4 individual buttons and if you press one, any of the other buttons which may have been on previously on, switches off due to the interlock setting. Works but doesn’t look very great. Kind of envisioning a slider or something similar.
Also: Starting looking at the new Areas Dashboard. Wondering what the best way would be for the question above in context of the Areas Dashboard. Looks like I would need to create a virtual device of some type so that it gets rendered as one control (and not 4 individual ones like right now)
I would use Mushroom chips, and with some templating and card_mod injected css is possible to achieve almost any kind of look and behavior.
