4 inch ST7796 touchscreen full working config
Hey you poor bastard trying to add a cheap 4 inch ST7796 touchscreen from Ali/Temu whatever to HA. Hopefully you found this thread sooner rather than later, but in any case, here we go.
So, the screen is weird. To make sure its the same one, here are pics:
It uses an ST7796 driver, but whatever you found so far, at least at the time of this writing, ilixxx drivers do not work.
This Github thread was a good starting point, but I could not make the ilixxx drivers work.
What I ended up doing instead is using the mipi_spi display driver. It’s … not great, but it’s the only one I could wrestle into submission on this panel.
That being, said, the driver is also lacking (or at least I could not find them) proper rotation and mirroring functions, so I had to get a bit … creative in solving some problems. Basically the screen is physically rotated 180 and since the touch coordinates are now wonky, I corrected that in code. If it’s stupid but it works … :man_shrugging:
Anywho, the config gives you:
1: The wiring I used for screen and touch, just read the pins from the Yaml
2: A fully functional, but wonky, screen
3: Fully functioning touch functionality with entities that show in HA the coords where a touch occurred.
globals:
  - id: last_color
    type: std::string
    initial_value: "\"\""
font:
  - file: "gfonts://Roboto"
spi:
  - id: spi_tft
    clk_pin: 18
    mosi_pin: 23
    miso_pin: 19
  - id: spi_touch
    clk_pin: 25
    mosi_pin: 32
    miso_pin: 34
display:
  - platform: mipi_spi
    model: st7796
    spi_id: spi_tft
    cs_pin: 5
    dc_pin: 17
    reset_pin: 16
    rotation: 90
    spi_mode: 3
    color_order: bgr
    pixel_mode: 16bit
    auto_clear_enabled: true
    lambda: |-
      it.fill(Color(0, 0, 0));
      // ---- CORNER COLOR BOXES ----
      it.filled_rectangle(0, 0, 40, 40, Color(255, 0, 0));                               // RED TL
      it.filled_rectangle(it.get_width()-40, 0, 40, 40, Color(0, 255, 0));               // GREEN TR
      it.filled_rectangle(0, it.get_height()-40, 40, 40, Color(0, 0, 255));              // BLUE BL
      it.filled_rectangle(it.get_width()-40, it.get_height()-40, 40, 40, Color(255,255,0)); // YELLOW BR
      // ---- ARROWS + LABELS ----
      int cx = it.get_width() / 2;
      int cy = it.get_height() / 2;
      // UP ↑
      it.line(cx, cy, cx, cy-60, Color(255,255,255));
      it.line(cx, cy-60, cx-10, cy-50, Color(255,255,255));
      it.line(cx, cy-60, cx+10, cy-50, Color(255,255,255));
      it.printf(cx, cy-80, id(default_font), Color(255,255,255), TextAlign::CENTER, "UP");
      // DOWN ↓
      it.line(cx, cy, cx, cy+60, Color(255,255,255));
      it.line(cx, cy+60, cx-10, cy+50, Color(255,255,255));
      it.line(cx, cy+60, cx+10, cy+50, Color(255,255,255));
      it.printf(cx, cy+80, id(default_font), Color(255,255,255), TextAlign::CENTER, "DOWN");
      // LEFT ←
      it.line(cx, cy, cx-60, cy, Color(255,255,255));
      it.line(cx-60, cy, cx-50, cy-10, Color(255,255,255));
      it.line(cx-60, cy, cx-50, cy+10, Color(255,255,255));
      it.printf(cx-90, cy, id(default_font), Color(255,255,255), TextAlign::CENTER, "LEFT");
      // RIGHT →
      it.line(cx, cy, cx+60, cy, Color(255,255,255));
      it.line(cx+60, cy, cx+50, cy-10, Color(255,255,255));
      it.line(cx+60, cy, cx+50, cy+10, Color(255,255,255));
      it.printf(cx+90, cy, id(default_font), Color(255,255,255), TextAlign::CENTER, "RIGHT");
      // ---- Touch readout as text ----
      if(id(last_color) != "") {
        it.printf(cx, cy+120, id(default_font), Color(255,255,255), TextAlign::CENTER, "%s", id(last_color).c_str());
output:
  - platform: ledc
    pin: 21
    frequency: 20000 Hz
light:
  - platform: monochromatic
    output: tft_bl
    restore_mode: ALWAYS_ON
text_sensor:
    name: "Touch Raw X"
    update_interval: never
    name: "Touch Raw Y"
    name: "Touch Raw X Numeric"
    update_interval: 50ms
    lambda: |-
      return id(raw_x).state != "" ? atof(id(raw_x).state.c_str()) : 0;
    name: "Touch Raw Y Numeric"
    lambda: |-
      return id(raw_y).state != "" ? atof(id(raw_y).state.c_str()) : 0;
touchscreen:
  - platform: xpt2046
    spi_id: spi_touch
    cs_pin: 22
    calibration:
      x_min: 300
      x_max: 3900
      y_min: 300
      y_max: 3900
    transform:
      swap_xy: true
    on_touch:
      then:
        - lambda: |-
            int X = touch.x_raw;
            int Y = touch.y_raw;
            // 🔥 FIXED MAPPING — TR <-> BL swap corrected
            if (X > 3300 && Y > 3300) id(last_color) = "RED (TL)";
            else if (X < 900  && Y > 3300) id(last_color) = "GREEN (TR)";  // swapped here
            else if (X > 3300 && Y < 900)  id(last_color) = "BLUE (BL)";   // swapped here
            else if (X < 900  && Y < 900)  id(last_color) = "YELLOW (BR)";
            else id(last_color) = "CENTER";
Once on the WROOM, and I think it’s kind of a must for it to be a WROOM from what I understood from the Github post, you should get this on the screen:
Touch functionality can be tested by clicking on the colored squares. When you click on a square, it should write on the screen the color of the square and it’s location (TL - top left). Exact touch coordinates from the screen can be seen in logs.
Hope this helps someone out and avoids the hours and hours of LLM prompting to get this running.
Hi, I used your code with a 3.5 capactive screen ST7796.
Screen show the square colors, but change to yellow on start and when I touch screen nothing happens.
On logs show many times the same code…
[21:38:18.576][D][sensor:133]: 'Touch Raw Y Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.576][D][sensor:133]: 'Touch Raw X Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.588][D][xpt2046:055]: Touchscreen Update [0, 0], z = 4095
[21:38:18.627][D][sensor:133]: 'Touch Raw Y Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.630][D][sensor:133]: 'Touch Raw X Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.641][D][xpt2046:055]: Touchscreen Update [0, 0], z = 4095
[21:38:18.678][D][sensor:133]: 'Touch Raw Y Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.680][D][sensor:133]: 'Touch Raw X Numeric': Sending state 0.00000 with 1 decimals of accuracy
[21:38:18.694][D][xpt2046:055]: Touchscreen Update [0, 0], z = 4095
From the logs, seems like you did not wire the touch pins correctly. It’s basically giving you the same coordinates. Either that, or your screen is using a different touch driver. Look further up the logs and see if the touch driver actually gets loaded correctly. Also, be very careful with the screen. Besides being just extremely slow, it’s also extremely sensitive. By the time I finished creating the screen I wanted, I gave up on it, kept running out of memory buffer and restarting so I just gave up.
