Hello! I am getting a 401 error every time i try to call Home Assistant from my local voice assistant. I think the problem is in the long access token expiring as it works at first and then becomes sporadic. Has anyone else had similar issues or know how to fix this? It is fundamental for me to be able to call Home Assistant so i can use its features…
Could you provide a little more detail about your setup & what you mean when you say ‘call home assistant from your local voice assistant’?
Some more context will be helpful.
Cheers
Nick
