403 Error ip_bans.yaml EMPTY Core 2024.6.2
I’m able to connect with my android companion app but not able to connect locally with laptop or through my reverse proxy through my Synology DS420+ even though I can connect to the other reverse proxies with all other FQDN’s. I’ve had the same installation for years and keep everything up to date. ip_bans.yaml is empty.
I’m running HA on the Home Assistant Blue ODROID N2/N2+ with Core 2024.6.2, Supervisor2024.06.0, OS 12.2, and front end 20240610.0. This just started last night.
My configuration.yaml has not changed and the only http entries below:
http:
  use_x_forwarded_for: true
  trusted_proxies: !secret "my_proxy"
  ip_ban_enabled: true
  login_attempts_threshold: 8
Trying to login with my desktop PC with the local ip:8123 I get this error and cannot start over:
Screenshot 2024-06-12 084746
Does anyone have any ideas?
[SOLUTION] I restored from last backup and now working
