433mhz tasmota, button learn, not able to turn on device
Hi All,
I have a simple holiday outlet that uses a 433mhz remote, i am able to successfully learn a button (in the tasmota interface) by doing rfkey1 2 (to learn button 1), it successfully learns it but when I push “1” it does not activate the device. i notice that “Low” and “High” numbers are never the same when I push the button on the remote but when I review the “learn” it has a static number for “low” and “high”, could this be the culprit? If so can I compensate for that, it seems to increment down both numbers by 10 on every use.
