Dear all,
I have a Raspberry Pi5, used the Raspberry Pi Imager to write Home Assistant on the SD card.
After I started, switched on the Advanced Mode, and configured the basics, I tried to install MOSQUITTO BROKER from the Add-on store.
Everytime I get the following error:
2025-05-18 20:10:18.279 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_mosquitto/install - Can’t install homeassistant/aarch64-addon-mosquitto:6.5.1: 500 Server Error for http+docker://localhost/v1.48/images/create?tag=6.5.1&fromImage=homeassistant%2Faarch64-addon-mosquitto&platform=linux%2Farm64: Internal Server Error (“received unexpected HTTP status: 500 Server Error”)
I wiped the SD-card and redid the whole process, again. No success.
Reason why I started over the Configuration, was that I also had this error when I tried to update Terminal & SSH, and later other Add-ons. I believed that with a fresh install, it all would be better.
During my search, I read an answer that possibly the device had no internet connection. I confirm that internet is live.
I am looking forward to your reply. Your help is much appreciated.
