64GB Samsung SD card
I’m not sure if I have an issue or not here. I have a 64GB micro sd card and want to install Hassio onto the card and use a Pi. I have formatted the card. Downloaded the PI4 32bit img file, extracted and used Win32 DiskManager to install on the card. The installation somehow creates 2 partitions on the card, creating a G and H drive the latter holding the Hassio files. Also the card properties now record only a 32GB card. Can someone assist please as I have no idea what the problem is.
Same story here, but with a Pi3B 64bit.
I first formatted the 64GB micro SD in windows 10
Then I used Balena Etcher to install the Hassio files.
Right after that the windows explorer sends a message that the sd card is not formatted.
In the disk manager I see:
So the process made 2 partitions, of which 1 is not formatted and recognized?
How do I have to solve this?
I read that I have to expand the first partition to the maximum, but I can’t figure out how to do that.
It’s an SDXC memory card. I read that I have to format in exFAT?
