64gb SD install issues
hey all,
recently got a rpi4, so im going to set that up first, then move over my config from the rpi3b.
i purcahsed a new 64gb SD card (U3, A2: this exact model: https://www.amazon.co.uk/gp/product/B07FCMBLV6/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1)
im unable to get it to work and the screen is always blank when i load hte SD card into the RPI4.
Steps:
format card.
use etcher, fllash image: Raspberry Pi 3 Model B and B+ 32bit
put card into RPi4
whats strange, is that my 32gb SD, with NOOBS on it, works fine in the RPI4, so i know its not the hardware.
Where am i going wrong with putting hassio install on this 64gb card?
Read what you wrote:
And think about it.
gotcha, did i then wrongly assume (from another post) that i can use this image on an rpi4?
Yep. You can install it using the docker method. Install raspian first, then this method should work:
thanks a lot - quite obvious really…
i assume in the near future, there would be a hassio for rpi4 released?
Yeah I pretty sure I read somewhere that pvizeli is on to it.
