Hey, everybody. I made a blueprint that allows you to set a circadian‑rhythm‑type lighting based on a time range. The idea is to change the lights over the course of the day and also change the color throughout the day. I’m not sure if something like this exists, but I felt I needed to share it with people.
The reason I made this is because I have ADHD and trouble getting to bed, so I decided to create a light schedule for my office lights. I hope it helps anyone.
The code is below
blueprint:
name: Circadian Kelvin Ramp
description: >
Gradually ramps selected lights across a color temperature range over a
configurable time window.
Defaults ramp from 6535K (cool) at 4:00 AM down to 2000K (warm) at 5:00 PM.
Swap the start/end kelvin values to invert the direction.
Safety guard: if ANY selected light that is currently ON has a color outside
the guard range — including any light in an RGB/HS/XY color mode, which has
no kelvin value at all — the entire run is skipped and no light is touched.
Lights that are OFF are ignored by the guard and are never turned on by this
automation.
Outside the time window the automation does nothing; lights hold whatever
value they last had.
domain: automation
input:
lights:
description: The lights to ramp. Only lights that are already on will be adjusted.
selector:
entity:
multiple: true
filter:
- domain: light
start_time:
description: When the ramp begins.
default: "04:00:00"
selector:
time: {}
end_time:
description: >
When the ramp finishes. If this is earlier than the start time, the
window is treated as crossing midnight (e.g. 18:00 to 06:00).
default: "17:00:00"
selector:
time: {}
start_kelvin:
description: Color temperature at the start of the window.
default: 6535
selector:
number:
min: 2000
max: 6535
step: 1
unit_of_measurement: K
mode: slider
end_kelvin:
description: Color temperature at the end of the window.
default: 2000
selector:
number:
min: 2000
max: 6535
step: 1
mode: slider
guard_min_kelvin:
name: Guard minimum kelvin
description: >
If any selected light is on and below this value, the whole run is
skipped.
default: 2000
selector:
number:
min: 1000
max: 10000
step: 1
mode: box
guard_max_kelvin:
name: Guard maximum kelvin
description: >
If any selected light is on and above this value, the whole run is
skipped.
default: 6535
selector:
number:
min: 1000
max: 10000
step: 1
mode: box
update_interval:
description: >
How often the lights are recalculated. Shorter is smoother but adds
more network traffic.
default: "/5"
selector:
select:
options:
- label: Every minute
value: "/1"
- label: Every 5 minutes
value: "/5"
- label: Every 10 minutes
value: "/10"
- label: Every 15 minutes
value: "/15"
transition:
description: >
Fade duration in seconds for each update. Setting this at or near the
update interval makes the change continuous rather than stepped. Set to
0 for lights that do not support transitions.
default: 300
selector:
number:
min: 0
max: 900
step: 1
unit_of_measurement: s
mode: box
mode: single
max_exceeded: silent
variables:
lights: !input lights
start_t: !input start_time
end_t: !input end_time
start_k: !input start_kelvin
end_k: !input end_kelvin
guard_min: !input guard_min_kelvin
guard_max: !input guard_max_kelvin
ents: >
{{ lights if lights is not string else [lights] }}
lights_on: >
{{ expand(ents)
| selectattr('state', 'eq', 'on')
| map(attribute='entity_id')
| list }}
triggers:
- trigger: time_pattern
minutes: !input update_interval
conditions:
# 1. Only run inside the configured window. This condition handles
# cross-midnight windows on its own.
- condition: time
after: !input start_time
before: !input end_time
# 2. At least one selected light is on. Nothing to do otherwise.
- condition: template
value_template: "{{ lights_on | count > 0 }}"
# 3. Guard. Abort the whole run if any light that is on sits outside the
# kelvin range, or is in a color mode that has no kelvin value at all.
value_template: >
{% set ns = namespace(ok = true) %}
{% for e in lights_on %}
{% set k = state_attr(e, 'color_temp_kelvin') %}
{% if k is none or k < guard_min or k > guard_max %}
{% set ns.ok = false %}
{% endif %}
{% endfor %}
{{ ns.ok }}
actions:
- variables:
target_kelvin: >
{% set t = namespace(s = today_at(start_t), e = today_at(end_t)) %}
{% if t.e <= t.s %}
{# Window crosses midnight. Decide which side of it we are on. #}
{% if now() < t.e %}
{% set t.s = t.s - timedelta(days=1) %}
{% else %}
{% set t.e = t.e + timedelta(days=1) %}
{% endif %}
{% endif %}
{% set total = (t.e - t.s).total_seconds() %}
{% set raw = (now() - t.s).total_seconds() / total %}
{% set frac = [[raw, 0] | max, 1] | min %}
{{ (start_k + (end_k - start_k) * frac) | round | int }}
- action: light.turn_on
entity_id: "{{ lights_on }}"
color_temp_kelvin: "{{ target_kelvin }}"
transition: !input transition```
