A blueprint to play chimes or make announcements on Sonos
Currently I use it with my window sensors. It uses announce: true so the music doesn’t get interrupted.
You can choose to play an existing audio file (due to HA restrictions you’ll have to select the media player again), or make announcements with TTS.
I don’t think it would work with other brands, since it’s a Sonos-exclusive feature. Feel free to report bugs if you encounter any.
blueprint:
  name: Sonos Announcement
  description: Play audio files or TTS messages on Sonos when the state of entity changes, without interrupting current music.
  domain: automation
  input:
    trigger_entities:
      description: Select one or more entities with ON/OFF states (e.g., binary_sensors, switches, lights).
      selector:
        entity:
          multiple: true
    sonos_speakers:
      description: Select one or more Sonos speakers to play the announcement.
      selector:
        entity:
          domain: media_player
          integration: sonos
          multiple: true
    announce_volume:
      description: Independent volume level for the announcement (0.1 to 1.0).
      default: 0.5
      selector:
        number:
          min: 0.1
          max: 1.0
          step: 0.05
    tts_provider:
      name: TTS Provider Entity
      description: Select your TTS entity (e.g., tts.google_en_com, tts.piper). Used if TTS is selected for either action.
      default: tts.google_translate_en_com
      selector:
        entity:
          domain: tts
    # ================= ON ACTION CONFIGURATION =================
    on_action_type:
      name: "ON Action Type"
      description: Choose what to do when an entity turns ON.
      default: audio
      selector:
        select:
          options:
            - label: "Audio File"
              value: "audio"
            - label: "Text-to-Speech"
              value: "tts"
            - label: "Disabled"
              value: "disabled"
    chime_media_on:
      name: "ON Audio Selector"
      description: Select an audio file played when an entity turns ON.
      default: ""
      selector:
        media: {}
    tts_message_on:
      name: "ON TTS Message"
      description: The text spoken when an entity turns ON.
      default: ""
      selector:
        text: {}
    # ================= OFF ACTION CONFIGURATION =================
    off_action_type:
      name: "OFF Action Type"
      description: Choose what to do when an entity turns OFF.
      default: audio
      selector:
        select:
          options:
              value: "audio"
              value: "tts"
            - label: "Disabled"
              value: "disabled"
    chime_media_off:
      name: "OFF Audio Selector"
      description: Select an audio file played when an entity turns OFF.
      default: ""
      selector:
        media: {}
    tts_message_off:
      name: "OFF TTS Message"
      description: The text spoken when an entity turns OFF.
      default: ""
      selector:
        text: {}
mode: queued
max: 10
# Map blueprint inputs to variables for Jinja2 template evaluation
variables:
  tts_provider: !input tts_provider
  on_action_type: !input on_action_type
  chime_media_on: !input chime_media_on
  tts_message_on: !input tts_message_on
  off_action_type: !input off_action_type
  chime_media_off: !input chime_media_off
  tts_message_off: !input tts_message_off
  # Trigger ID "turned_on" when any selected entity goes from off to on
  - trigger: state
    entity_id: !input trigger_entities
    to: "on"
  # Trigger ID "turned_off" when any selected entity goes from on to off
  - trigger: state
    to: "off"
  - choose:
      # ----------------- CASE 1: ENTITY TURNED ON -----------------
      - conditions:
          - condition: trigger
        sequence:
          - choose:
              - conditions:
                  - condition: template
                    value_template: "{{ on_action_type == 'audio' }}"
                sequence:
                  - action: media_player.play_media
                      entity_id: !input sonos_speakers
                      media_content_id: "{{ chime_media_on.get('media_content_id', '') if chime_media_on is mapping else chime_media_on }}"
                      media_content_type: "{{ chime_media_on.get('media_content_type', 'music') if chime_media_on is mapping else 'music' }}"
                      announce: true
                      extra:
                        volume_level: !input announce_volume
              - conditions:
                    value_template: "{{ on_action_type == 'tts' }}"
                sequence:
                      media_content_id: "{{ 'media-source://tts/' ~ tts_provider ~ '?message=' ~ (tts_message_on | urlencode) }}"
                      media_content_type: "music"
                      announce: true
                      extra:
      # ----------------- CASE 2: ENTITY TURNED OFF -----------------
      - conditions:
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ off_action_type == 'audio' }}"
                sequence:
                      media_content_id: "{{ chime_media_off.get('media_content_id', '') if chime_media_off is mapping else chime_media_off }}"
                      media_content_type: "{{ chime_media_off.get('media_content_type', 'music') if chime_media_off is mapping else 'music' }}"
                      announce: true
                      extra:
              - conditions:
                    value_template: "{{ off_action_type == 'tts' }}"
                sequence:
                      media_content_id: "{{ 'media-source://tts/' ~ tts_provider ~ '?message=' ~ (tts_message_off | urlencode) }}"
                      announce: true
                      extra:
Hello BrushXue,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
