Excellent friend. I work perfect. Thank you very much
The only thing I don’t understand is where the color of the line comes from
You can just add the color parameter at the css styling
- color: '#html_color_code_here'
@Mattias_Persson how did you get it sorted to get the slide animation? Like, when you slide in your gif it has some depth to it. Mine just staticly slides from left to right.
If I don’t change it in the repository, it has it as you want.
I was trying with line-color. Thank you
add effect: ‘coverflow’ to the parameters of the swipe card in ui-lovelace.yaml
- type: custom:swipe-card
parameters:
effect: 'coverflow'
speed: 550
spaceBetween: 40
threshold: 5
here is the thread with examples
could you show an example were to place the color option in the code?
thx
Just don’t include something like a slider on your card , or do you have a solution for that? I mostly gave up on swiper because I could not have a slider that would not also cause swiping and my wife said “forget it”
Like input_number slider in a card which you can say “I am sliding that and not the card” … I gave up. Gave her a hold_action
I don’t understand exactly what you mean?
I just answered a question from @henkkeumus and provided the solution for the slide effect with deep.
here is my working example
I know. What I meant was that inside your slider you cannot include something like a volume control input_number input … or at least I have never found a “decent” way that functions properly.
Given your example, what if I had this inside the slider?
Try then to change the volume. You can, clicking certainly. Sliding the volume control, kludgy at best. I tried many/most of the slider card parameters from slider.js and cannot get it to act like I would want it. Because sliding the volume control also slides the panel.
Oh and in testing again, implementing something with a hold-action seems to not work. I had a series of remote controls for my TVs and changed from swiper card to vertical stack and all hold actions now work (they do not on a PC with swiper).
Too bad because it is pretty … but pretty non-functional too for many cases.
Yes, that’s right, the swiper card is unfortunately very bitchy and hasn’t been developed further for ages.
but I think I would have done it when I had read the thread and tried everything possible.
It was never perfect but I think it was possible to get what you’re trying to do.
If I find the time again, I’ll try the whole thing again and then give you feedback.
EDIT
this can be a solution
allowTouchMove: false
How to add double arrow?
Thanks for the suggestion. In the end I went with collapse cards as they provided a GUI my wife and kids would use. They click to open the remote control and then do as they desire. No sliding involved and everything works.
For Anyone wanting it I created an Octoprint 3D Printer card to use with Matthias’s UI style:
button_card_templates.yaml code:
printer:
template:
- base
aspect_ratio: 1/1
show_state: true
show_icon: false
show_name: true
show_current_temperature: true
show_control: true
state:
- operator: template
value: sensor.octoprint_print_state
custom_fields:
circle: >
if (Math.round(states['sensor.octoprint_percentage_complete'].state) > 0 && states['sensor.octoprint_percentage_complete'].state < 100) {
const input = states['sensor.octoprint_percentage_complete'].state
const radius = 20.5;
const circumference = radius * 2 * Math.PI;
return `
<svg viewBox="0 0 50 50">
<style>
circle {
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - input / 100 * circumference};
tspan {
font-size: 10px;
</style>
<circle cx="25" cy="25" r="${radius}" stroke="#b2b2b2" stroke-width="1.5" fill="none" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${input}<tspan font-size="10">%</tspan></text>
</svg>
Modify the line below in the “base” template to include “Printing” as an “on” state:
Note: This is what controls when a card’s background turns white for future reference…
base:
template:
- settings
variables:
state_on: >
[[[ return ['on', 'home', 'cool', 'fan_only', 'playing','Printing'].indexOf(entity === undefined || entity.state) !== -1; ]]]
state: >
#Rest of base template
Icon Code (to be added to the bottom of button_card_templates.yaml):
icon_3dprinter:
styles:
custom_fields:
icon:
- width: 77%
- margin-left: 1%
- margin-top: 5%
custom_fields:
icon: >
<svg viewBox="0 0 90 73">
<<g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g><rect fill="#9da0a2" x="0" y="63" width="90" height="10" rx="3"></rect><rect fill="#9da0a2" transform="translate(10.000000, 33.000000) rotate(90.000000) translate(-10.000000, -33.000000) " x="-23" y="30" width="66" height="6" rx="3"></rect><rect fill="#9da0a2" transform="translate(78.000000, 34.000000) rotate(90.000000) translate(-78.000000, -34.000000) " x="44" y="31" width="68" height="6" rx="3"></rect><path d="M7,3 C7,1.34314575 8.34757814,6.41357826e-15 9.99253964,6.2593707e-15 L78.0074604,-1.16714867e-16 C79.6601944,-2.71651068e-16 81,1.34651712 81,3 L81,3 C81,4.65685425 79.6524219,6 78.0074604,6 L9.99253964,6 C8.33980564,6 7,4.65348288 7,3 L7,3 Z" fill="#9da0a2"></path><rect fill="#9da0a2" x="16" y="56" width="56" height="3"></rect><rect fill="#9da0a2" transform="translate(44.000000, 26.500000) scale(1, -1) translate(-44.000000, -26.500000) " x="12" y="25" width="64" height="3"></rect><rect fill="#9da0a2" transform="translate(44.000000, 19.500000) scale(1, -1) translate(-44.000000, -19.500000) " x="12" y="18" width="64" height="3"></rect><rect fill="#9da0a2" x="25" y="23" width="15" height="10"></rect><rect fill="#9da0a2" x="31" y="31" width="3" height="4"></rect></g></g>>
</svg>
lovelace.yaml code: add this to where you want the card to live in your dashboard
- type: custom:button-card
entity: sensor.octoprint_print_state
tap_action: !include popup/Printer.yaml
template:
- base
- printer
- icon_3dprinter
and popup/Printer.yaml code: (this requires the threedy card from HACS)
action: fire-dom-event
browser_mod:
command: popup
title: Printer
style:
:host .content {
width: calc(385px + 510px);
max-width: 90vw;
threedy-card div div div:nth-child(2) {
height: auto !important;
opacity: 1 !important;
transform: none !important;
layout-card$grid-layout:
hui-vertical-stack-card {
animation: border 1s forwards;
@keyframes border {
0%, 100% {
border-right: 1.5px solid rgba(0, 0, 0, 0.2);
/* phone */
@media screen and (max-width: 800px) {
border-bottom: 1.5px solid rgba(0, 0, 0, 0.2);
padding-right: 0;
animation: none;
$hui-vertical-stack-card:
hui-horizontal-stack-card {
padding: 0em 2em 2.3em 2em;
$hui-entities-card$: |
.card-content {
padding: var(--card-content-padding);
$hui-horizontal-stack-card$: |
#root {
justify-content: space-evenly;
card:
type: custom:threedy-card
base_entity: sensor.octoprint
monitored:
- Status
- ETA
- Elapsed
- Hotend
- Bed
- Remaining
printer_type: I3
name: Prusa Mk2.5S Bear
theme: Default
temperature_unit: C
NOTE: using this card requires you to add the following template sensors:
template:
- sensor:
- unique_id: OctoPrint Time Elapsed
name: "OctoPrint Time Elapsed"
unit_of_measurement: "s"
availability: >
{{ not is_state('sensor.octoprint_start_time', 'unavailable') }}
state: >
{% set start = as_timestamp(states('sensor.octoprint_start_time')) %}
{% if is_number(start) %}
{{ (as_timestamp(now()) - start) | int }}
unknown
attributes:
start_time: "states('sensor.octoprint_start_time')"
- unique_id: OctoPrint Time Remaining
name: "OctoPrint Time Remaining"
availability: >
{{ not is_state('sensor.octoprint_estimated_finish_time', 'unavailable') }}
state: >
{% set finish = as_timestamp(states('sensor.octoprint_estimated_finish_time')) %}
{% if is_number(finish) %}
{{ (finish - as_timestamp(now())) | int }}
unknown
attributes:
start_time: "states('sensor.octoprint_estimated_finish_time')"
- unique_id: OctoPrint Percentage complete
name: "OctoPrint Percentage Complete"
unit_of_measurement: "%"
state: >
{{ states['sensor.octoprint_job_percentage'].state | round(0)}}
- unique_id: OctoPrint Print State
name: "OctoPrint Print State"
state: >
{% if is_state('sensor.octoprint_current_state', 'Operational') %}
idle
{% elif is_state('sensor.octoprint_current_state', 'Printing from SD') %}
Printing
{% elif is_state('sensor.octoprint_current_state', 'Starting print from SD') %}
Printing
Down
Threedy Card can be found here although be warned it seems to be a dead project:
https://github.com/dangreco/threedy
BE WARNED: The pop-up card does not currently scale to mobile resolutions as the code above stands… I’m not an expert by any means but I THINK it’s because the threedy card does not support it but if someone wants to swing by the thread and see if I messed up the scaling somewhere along the way let me know…
you mean behind the name?
title: Wohnzimmer ↔
easy copy it here and paste it in your ui-lovelace.yaml behind the name
anyone else having issue with sidebar not showing after update to Home Assistant 2022.7.0 my sensor.template_sidebar doesn’t exsist anymore the state list
Mine is working fine. Did you check the update blog to see what breaking changes they did? They did some changes to Google Calendars so maybe that might be affecting you.
Indeed! I have it too.
Thought it was the sonoff update at first but maybe its the version update… ill rollback the backup from yesterday.
Hello. How do I identify if it is the battery percentage or the lock, what I want to see in the upper right space.
Because the circle is configured with a width of 45 and so the padlock looks good but the percentage does not. Since the two share the same configuration. Do I have a way to put a condition to know who I am setting that width for? Thank you
lock:
tap_action:
loader: |
let elt = this.shadowRoot;
if (variables.state_on && variables.lock === 'locked') {
elt.getElementById('lock').classList.add('locked');
window.setTimeout(() => {
elt.getElementById('lock').classList.remove('locked');
}, 1100);
} else {
let loader = (id, style, timeout) => {
elt.getElementById(id) && (elt.getElementById(id).style.display = style,
elt.getElementById('loader').style.display = 'none'
}, 20000))
loader('circle', 'none', 'initial'),
loader('loader', 'initial', 'none');
custom_fields:
circle: >
if(entity) {
let state = states[entity.entity_id + '_estado_de_sesion'].state.toLowerCase();
if (state === 'locked') {
return `
<style>
@keyframes locked {
from,
to {
transform: translateX(0);
10%,
30%,
50%,
70%,
90% {
transform: translateX(-8%);
20%,
40%,
60%,
80% {
transform: translateX(8%);
.locked {
animation: locked 1.1s;
</style>
<path id="lock" class="${state}" d="M8.2 22.6h2.4v-7.2C10.6 7.5 17.1 1 25 1s14.4 6.4 14.4 14.4v7.2h2.4V49H8.2m26.4-26.4v-7.2c0-5.3-4.3-9.6-9.6-9.6s-9.6 4.3-9.6 9.6v7.2"/>
</svg>
} else {
let bateria = "";
const stroke_color = '#b2b2b2';
const fill_color = 'none';
if(entity.state == 'online') {
if(entity.entity_id == 'sensor.pc_florencia')
bateria = states['sensor.pc_florencia_bateria_charge_remaining_percentage'].state + "%";
if(entity.entity_id == 'sensor.pc_milena')
return;
let stroke_color = '#b2b2b2';
let fill_color = 'rgba(255,255,255,0.04)';
return `
<circle cx="29" cy="21" r="20.5" stroke="${stroke_color}" stroke-width="1.5" fill="${fill_color}" />
<text x="60%" y="45%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${bateria}</text>
</svg>
styles:
custom_fields:
circle:
- width: 45%
- fill: var(--state-icon-color)
- margin: 1% 2% 0 0
- justify-self: end
- opacity: 1
- display: grid
Hey Lars,
I’ve restored a backup from yesterday. This backup is on the latest version 2022.7.0 and sidebar works.
I’m now going to update the Sonoff LAN intergration from HACS as that was something I updated too as the intergration broke yesterday due to an issue with an ID hidden in the code.
… Maybe that breaks it… I’ll report back in a min
