I’ve been using this layout for around a year – we all love it in this household, so thank you very much.
I decided to update some code today and I’ve run into an issue which is over my head. For context I use several Fire Tabs around the house which have a landscape screen width of 1280px.
Previously I’d setup and new breakpoint for this screen and everything worked un-touched for said year.
Here’s what the custom breakpoint looks like:
#landscape
"(max-width: 1200px)":
grid-gap: var(--custom-layout-card-padding)
grid-template-columns: repeat(4, 1fr) 0
grid-template-rows: 0 repeat(1, fit-content(100%)) 0fr
grid-template-areas: |
"sidebar . . . ."
"sidebar lounge studio bedroom ."
"sidebar other media home ."
"sidebar footer footer footer ."
"sidebar . . . .";
Now, I’ve run into a problem with the new footer which isn’t displaying at that size. It looks something like this and they’ve falling way below the bottom the cards:
Ideally the buttons would be sitting neatly under the ‘Other Media Home’ buttons. I cannot figure out why they’re dropping to that specific level in the view-port.
If any one has any suggestions for bringing them back up for this specific break-point/screen size I’d really appreciate it.
Currently focussing on this section of code in the themes.yaml
# FOOTER #
grid-layout$hui-horizontal-stack-card:
#root {
flex-wrap: wrap;
justify-content: center;
overflow: visible;
margin-top: 1vh;
padding-bottom: 2.5em;
@media screen and (min-width: 1200px) {
#root {
flex-wrap: nowrap;
justify-content: space-between;
margin-top: -1.6vh;
padding-bottom: 0;
card-mod-card: |
.header .card-header {
letter-spacing: 0.005em;
font-size: 1.6em;
font-weight: 500;
padding: 1em 0 0 1.38em;
line-height: initial;
cursor: default;
.content .card-content {
padding: var(--card-content-padding);
letter-spacing: normal;
However it’s highly likely I’m in the wrong place!
Thanks again,
EDIT: I’m guessing it’s something related to the hui-grid-card
which is forcing the footer down?
pimp1310
(Pimp1310)
March 30, 2022, 7:10am
2987
i made a little watched / unwatched overlay for the card
anarion
(Anarion)
March 30, 2022, 9:27am
2988
Very neat! Can you share the code for the Klima popup? Or better yet - your github fork?
pimp1310
(Pimp1310)
March 31, 2022, 5:10am
2989
@Mattias_Persson
hi
i tried to add the icons that have the color of the light, but i had two problems, first when i shut the light off its still black, and he doenst change the icon color based of the light color. perhaps you can look at it?
type: custom:button-card
template: light_circle
show_icon: false
styles:
variables:
state_on: >
[[[ return ['on', 'home', 'cool', 'fan_only', 'playing'].indexOf(entity === undefined || entity.state) !== -1; ]]]
timeout: >
[[[ return entity === undefined || Date.now() - Date.parse(entity.last_changed); ]]]
extra_styles: >
if (entity) {
let hs = entity.attributes.hs_color === undefined,
h = hs || entity.attributes.hs_color[0],
s = hs || entity.attributes.hs_color[1],
l_min = 28,
l_max = 48,
l_calc = entity.attributes.brightness / 2.54 * (l_max - l_min) / 100 + l_min;
var light_color = entity.attributes.color_mode === 'color_temp' || entity.attributes.color_mode === 'brightness'
? `hsl(204, 58%, ${l_calc}%);`
: `hsl(${h}, ${s}%, ${l_calc}%);`;
return `
svg {
--light-color:
${ variables.state_on && entity.attributes.brightness !== undefined
? light_color
: variables.state_on && entity.attributes.brightness === undefined
? '#3182b7;'
: '#9da0a2;'
entity: light.led_stripe_kueche
custom_fields:
icon: >
let state = variables.state_on && variables.timeout < 2000 ? 'on' : null;
return `
<svg viewBox="0 0 50 50">
<style>
@keyframes on {
0% {
transform: scale(0.85);
20% {
transform: scale(1.1);
40% {
transform: scale(0.95);
60% {
transform: scale(1.03);
80% {
transform: scale(0.97);
100% {
transform: scale(1);
.on {
animation: on 0.8s;
transform-origin: center;
</style>
<path fill="#9da0a2" d="M27.4 47.3h-4.9s-.7.1-.7.8.4.9.7.9h4.9c.3 0 .7-.1.7-.9s-.7-.8-.7-.8zm3.3-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-3H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9s-.9-.8-.9-.8zm5.2-23.2c-3.3-5.3-7-5.6-10.9-5.6-3.8 0-8.4.4-10.9 5.6-.1.1-.1.3.1.7.4.8 3.3 7.2 3.2 18.8 0 1.1-.1 1.6 0 1.7 0 .1 0 .7 1.1.7h13c1 0 1-.5 1.1-.7v-1.7c-.1-11.6 2.8-18 3.2-18.8.1-.4.1-.5.1-.7"/>
<path class="${state}" fill="var(--light-color)" d="M14.1 15.3c3.4-.3 7-.4 10.9-.4 3.8 0 7.5.2 10.9.4.4-.4.7-.8.9-1.1C39 8.5 38.9 6.5 38.9 6c-.2-4.4-8.4-5-12.1-5h0-3.4c-3.7 0-12 .5-12.1 5 0 .5-.1 2.5 2.1 8.2 0 .3.3.8.7 1.1z"/>
</svg>
ring: |
[[[ if (entity.state == 'on' && entity.attributes.brightness) {
const brightness = Math.round(entity.attributes.brightness/2.55);
const radius = 20.5; const circumference = radius * 2 * Math.PI;
return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="${radius}"
stroke=gray stroke-width="2" fill="none"
style="transform: rotate(-90deg); transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - brightness / 100 * circumference};" />
<text x="50%" y="56%" fill=gray font-size="16" font-weight= "bold"
text-anchor="middle" alignment-baseline="middle">
${brightness}<tspan font-size="10">°</tspan></text></svg>`;}
show_state: true
my light has hs attributes
something is missing here, but i dont know what, has it to do with “fill=“var(–light-color)”” under extra_styles?
nullae
(null)
March 31, 2022, 5:33am
2990
Bit of a weird request if anyone has the understanding,
I broke the media icon location on this card (since corrected) by creating an icon with the following code:
icon_speaker:
styles:
custom_fields:
icon:
- width: 73%
- margin-left: -9%
custom_fields:
icon_break: >
With this second instance of icon
renamed to icon_break
I get this result:
I happen to really like the size and location, and have been trying to understand how I could make this work correctly. I know nothing of these things but figure maybe a z-index thing? No idea where I’d put that tho…
Anyone have any clues for me to figure this out?
pimp1310
(Pimp1310)
March 31, 2022, 7:48am
2991
use you the complete code from matthias?
perhaps your grid layout or position of the title.
post the complete styles part.
Z-Index is for the layout priority to display something.
nullae
(null)
March 31, 2022, 9:20am
2992
I am using the complete code, everything working perfectly.
To clarify, the image is how I would like the icon on the conditional media card to display.
I just can’t figure out how to get it there.
The code pasted is me just removing the icon template by renaming it, by coincidence it puts the icon in a spot I like.
I can see the positioning is set universally using a grid layout. Being universal, I can’t go modifying it’s position there, so I’m stuck for ideas.
You can use position: absolute
to place the icon wherever
https://developer.mozilla.org/en-US/docs/Web/CSS/position
I can have a look if you share your ui-lovelace.yaml
pimp1310:
extra_styles
should not be put in variables
and you haven’t closed the template code block
template:
# SELECT #
- select:
- name: conditional_media
state: >
{% set recently_added = 'Senast tillagt' %}
{% set paused_timeout_minutes = 15 %}
{% set media_players = [
states.media_player.vardagsrum,
states.media_player.sovrum,
states.media_player.spotify,
states.media_player.kok ] %}
{% macro media(state) %}
I don’t know, see open issues. RomRider maintains button-card
This code places the blur outside the button-card container (so it doesn’t get the 3d tilt effect), so there’s no need to adjust z-index
blur_overlay: >
setTimeout(() => {
let elt = this.shadowRoot,
card = elt.getElementById('card'),
container = elt.getElementById('container'),
blur_overlay = elt.getElementById('blur_overlay');
if (elt && card && container && blur_overlay) {
card.insertBefore(blur_overlay, container);
}, 0);
return ' ';
pimp1310
(Pimp1310)
March 31, 2022, 1:55pm
2999
@Mattias_Persson
i tried now a fresh install and your code, i know that i must change all entitys and more but why is the design so different from that you posted above?
Kind of you, thanks. Here’s the ui-lovelace.yaml
button_card_templates: !include button_card_templates.yaml
kiosk_mode:
hide_header: true
- type: custom:grid-layout
path: 0
layout:
#default
margin: 0
grid-template-rows: 0 repeat(2, fit-content(100%)) 0fr
"sidebar . . . ."
mediaquery:
#phone
"(max-width: 800px)":
grid-gap: calc(var(--custom-layout-card-padding) * 1.7)
grid-template-columns: 0 repeat(2, 1fr) 0
grid-template-rows: 0 repeat(5, fit-content(100%)) 0fr
". sidebar sidebar ."
". lounge bedroom ."
". studio other ."
". media home ."
". footer footer ."
# #portrait
# "(max-width: 1200px)":
# grid-gap: var(--custom-layout-card-padding)
# grid-template-columns: repeat(3, 1fr) 0
# grid-template-rows: 0 repeat(3, fit-content(100%)) 0fr
# grid-template-areas: |
# "sidebar . . ."
# "sidebar lounge bedroom ."
# "sidebar studio other ."
# "sidebar media home ."
# "sidebar footer footer ."
# "sidebar . . ."
#landscape
"sidebar . . . ."
"sidebar . . . .";
cards:
- type: custom:button-card #extra_styles fix
styles: {card: [display: none]}
# SIDEBAR #
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
entity: sensor.template_sidebar
template: sidebar
- type: conditional
conditions:
- entity: input_boolean.laundry_display
state: 'on'
card:
entity: timer.laundry
template: laundry
# - type: grid
# cards:
# - type: button
# icon: mdi:home-lightbulb-outline
# tap_action:
# !include popup/lighting_popup.yaml
# hold_action:
# action: none
# - type: button
# icon: mdi:information-outline
# tap_action:
# !include popup/sidebar_information.yaml
# hold_action:
# action: none
# - type: button
# icon: mdi:arrow-up-bold-circle-outline
# tap_action:
# !include popup/sidebar_update.yaml
# hold_action:
# action: call-service
# service: homeassistant.update_entity
# service_data:
# entity_id: sensor.hacs
# lounge #
- type: grid
title: Living Room
view_layout:
grid-area: lounge
columns: 2
cards:
entity: light.rgb_lounge
#entity: light.living_room_lights #lounge group
template:
- light
- icon_hue
entity: climate.wiser_main_thermostat
tap_action: !include popup/bedroom_klimat.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
return entity.state == 'current_temperature' ?
entity.attributes.temperature :
entity.attributes.current_temperature;
entity: light.osram_orange_lamp
template:
- base
- icon_hue
# - type: custom:button-card
# entity: #binary_sensor.motion_hall_occupancy
# name: Motion
# template:
# - base
# - circle
# variables:
# circle_input: >
# [[[ return states['sensor.hall_motion_xmins'].state; ]]]
entity: media_player.living_room_tv_2
hold_action: !include popup/bedroom_tv2.yaml
template:
- base
- icon_tv
- loader
# STUDIO #
- type: grid
title: Office
view_layout:
grid-area: studio
columns: 2
cards:
entity: light.office_lights
tap_action: !include popup/office_lighting.yaml
template:
- light
- icon_hue
tap_action: !include popup/bedroom_office.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
[[[ return states['sensor.temp_office_temperature'].state; ]]]
entity: binary_sensor.macbook_pro_active
hold_action: !include popup/studio_dator.yaml
template:
- base
- icon_imac
- loader
- lock
entity: switch.amplifier
hold_action: !include popup/studio_monitorer.yaml
template:
- base
- icon_monitors
- circle
- loader
variables:
circle_input: >
[[[ return states['sensor.office_hifi_volume2'].state; ]]]
# bedroom #
- type: grid
title: Bedroom
view_layout:
grid-area: bedroom
columns: 2
cards:
entity: light.rgb_bedroom
template:
- light
- icon_hue
tap_action: !include popup/climate_bedroom.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
[[[ return states['sensor.temp_bedroom_temperature'].state; ]]]
entity: input_boolean.bedroom_radio
tap_action: !include popup/bedroom_radio.yaml
template:
- base
- icon_monitors
entity: media_player.samsung_tv
template:
- base
- icon_tv
- loader
# MEDIA #
- type: grid
title: Media
view_layout:
grid-area: media
columns: 1
cards:
- type: custom:swipe-card
start_card: 1
parameters:
roundLengths: true
effect: coverflow
speed: 650
spaceBetween: 20
threshold: 7
coverflowEffect:
rotate: 80
depth: 300
cards:
- type: grid
columns: 2
cards:
entity: media_player.office
template:
- media
- icon_monitors
tap_action: !include popup/kitchen_radio_full.yaml
entity: media_player.kitchen_stereo
template:
- base
- icon_monitors
#- circle
entity: media_player.spotify
template:
- media
- icon_spotify
entity: switch.playstation_5
hold_action: !include popup/lounge_playstation.yaml
template:
- base
- icon_ps5
- loader
- type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: input_select.conditional_media
state: Last downloaded
card:
entity: sensor.plex_recently_added
tap_action:
action: none
template:
- conditional_media
- recently_downloaded
- icon_plex
# other #
- type: grid
title: Other
view_layout:
grid-area: other
columns: 2
cards:
entity: input_boolean.all_lights
tap_action: !include popup/lighting_popup.yaml #popup/all_lighting.yaml
template:
- base
- icon_hue
entity: light.kitchen_lights #group
template:
- light
- icon_hue
entity: camera.office_camera
tap_action: !include popup/cameras.yaml
template:
- base
- icon_camera
entity: fan.studio_wemo
hold_action: !include popup/other_lighting.yaml
template:
- base
- icon_fan2
- loader
# home #
- type: grid
title: Home
view_layout:
grid-area: home
columns: 2
cards:
entity: person.tom
tap_action: !include popup/home_tom.yaml
hold_action:
action: none
template: person
entity: person.charlotte
tap_action: !include popup/home_charlotte.yaml
hold_action:
action: none
template: person
entity: script.home_leave
hold_action:
action: none
template:
- base
- icon_away
entity: script.home_arrive
hold_action:
action: none
template:
- base
- icon_home
# FOOTER #
view_layout:
grid-area: footer
cards:
<ha-icon icon="mdi:cog"></ha-icon> Info
tap_action:
template: footer
<ha-icon icon="mdi:home-lightbulb-outline"></ha-icon> Lights
tap_action:
template: footer
<ha-icon icon="mdi:home-lightbulb-outline"></ha-icon> Test
tap_action:
!include popup/popups/test_popup.yaml
template: footer
tap_action:
template: footer
tap_action:
template: footer
tap_action:
template: footer
# - type: grid
# cards:
# - type: button
# tap_action:
# hold_action:
# action: none
# - type: button
# tap_action:
# hold_action:
# action: none
# - type: button
# tap_action:
# hold_action:
# service_data:
Looks good here
Have you had a look in the browser console?
recently_downloaded
was recently merged into conditional_media
damn, that was indeed the culprit – thanks so much. I owe you a beer, that’s for sure
pimp1310
(Pimp1310)
March 31, 2022, 3:48pm
3004
@Mattias_Persson
maybe it’s a bit naïve, but now always has to edit the ui-lovelace.yaml in notepadd++? so you don’t see his changes at all?
or gives a edior with preview what i do?
Anyone has an idea what just happened? The alignment of the full home assistant environment is going nuts!
Or is this an april fools day joke from the Home Assistant team?
